Question about PANDIGITAL (DPF802) Digital Picture Frame
I bought 2 Phillips 8ff2fpb 8'' frames and they're limited to 109
These frames appear limited to 108 pictures before they freeze on #109. This is either random or sequential. I tried two and they were identical. I've loaded a 1Gig SD card (formatted with FAT 32) with 599 pictures, about 650Mb, and I want to randomly see them all. Could it be the format? FAT format stopped me loading the card at around 70 pictures, but the FAT 32 enabled me to load them all.
It's a Phillips!!!!!
2 Suggested Answers
  • 5 Answers
SOURCE: downloading photos from computer to phillips 8ff2fpb photoframe
Your PhotoFrame does not have internal memory acording to the Phillips data sheet, therefore you need to load your pictures directly onto a memory card (one from your camera will proabably work.) If that isn't convenient, you can generally get a good price on a SD memory card which is supported by your PhotoFrame.
If you wnat to transfer pictures from your PC to the memory card and have a card reader, you can transfer the pictures in Windows Explorier from your PC to the memory card and then plug the card into your PhotoFrame. If you do not have a card reader, plug the memory card into the PhotoFrame and connect it to your PC using a USB cable (you may have to buy one as acording to the Phillips data sheet it is not supplied.) When the PhotoFrame is pluged in it will appear in Windows Explorier as a new hard drive, and you can copy your pictures to it.
I hope this helps,
Mike
Posted on Jan 03, 2009
Pictures not showing.
make sure the cards' slide button is in the unlock position..then check to see which size cards the frame can work with..mb sizes like 2/4/6/8/12 etc..
Jan 11, 2014 | Audiovox DPF700 Digital Picture Frame
Why are my pictures blurry on my 8ff2fpb 37
I had the same problem with my photo frame but was happy to find the answer to the problem on the website for my photo frame:
You need a resizing program to resize all your photos to the recommended size for your frame. The program I used is:
http://www.faststone.org/
and here is the step-by-step instructions on how to resize all the pictures at once:
https://nix.zendesk.com/entries/22222492-How-to-Re-Size-Photos-for-your-Digital-Frame
After that all the pictures, even the ones with lower quality displayed perfectly fine on the photo-frame.
Apr 24, 2012 | Cameras
Slideshow freezes during slideshow
I wonder if ALL the pic's are correct Size & Format?
Feb 01, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
I'm told the directory or file canot be created when I try to drag a picture to the pandigital folder even though I've already copied about a 100 images using the same method.
I have a Pandigital too and although I don't think the users guide mentions it (major oversight on their part), the root directory on this thing can only hold a limited # of files/folders (mine is limited to 108) If I understant it correctly, it's due to the fact that the pandigital uses a FAT (file allocation table) storage method - not that the reason matters. The solution is: make folders in the root directory (you could have up to 108 folders on my pandigital) and I believe each subfolder can have an unlimited number of files in it. I just call my subfolders "Dec 2009 additions, Jan 2010 additions, etc). The Pandigital will randomly cycle thru files in each of these subfolders just as if they were in the root directory. Hope this helps.
Dec 25, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
Power seat doesnt work 2005 f150
If you have the memory seats, there are 2 fuses to check, Fuse #3 and Fuse # 109 or 108 ( drivers or pass ). 108 & 109 are for the non memory seat version ( the driver's side seat has the 1 & 2 buttons on it, on the side ).
If both of these check OK, there are 2 routes.
1. Check for power at the power seat module
1.1. Fuse #3 = pin #1, Orange w/ light green stripe wire.
1.2. Fuse # 109 = pin #1 ( on the other connector ) Dark Green wire.
Both are hot at all times, key position does not matter.
The non memory seat version is just fuse #109, Dark green.
Route #2 is some times there is a water leak in the driver's side door sill. There is a wire that is spliced ( 1 in, 2 out ) that can corrode and break. If this happens, there are usually other symptoms ( open door will not shut of radio, power mirrors don't work, etc ).
Lacking other symptoms, Focus on those 2 fuses, and making sure power is under the seat at the connector.
Oct 24, 2009 | 2005 Ford F-150
Purchased camera in March and working great until yesterday. Took a batch of pictures yesterday but was not able to download most of them to my computer. Got computer message "there are no images in the...
Sounds like you're switching the same card between cameras. Rule #1...one card per camera. Format the card in the camera it is to be used in. There is no Rule #2.
Aug 21, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Downloading photos from computer to phillips 8ff2fpb photoframe
I hope this helps,
Mike
Jan 03, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
Phillips Photo Frame does not recognize SanDisk 1 BG SD card
I used a format program from http://www.sdcard.org/consumers/formatter/eula/
Nether Sandisk nor Phillips tells you the card needs to be formatted FIRST if it is
new and out of the package. It works fine now.......... in the Phillips Photo Frame model 8FF2FPB
If you do not format it first - your PC software WILL NOT even know it is inserted into your device!!
I need no further help on this
Thanks
JohninTexas
Dec 29, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
Have a kodak ex811 digital frame
1 utf-8 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Once you connected your EX811 to your computer, and get the message “Use PC interface to copy files.” That means you can start copying files. Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Oct 27, 2008 | Coby DP-888 8-Inch Digital Photo Frame...
PANDIGITAL (DPF802) Digital Picture Frame Logo
362 people viewed this question
Top PANDIGITAL Photography Experts
LP
Bill Eager
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
