Question about Frigidaire GLTF2940ES Front Load Washer
Our front load washer will fill and drain, but won't spin
We have a Frigidaire Gallery Series front load washer that is less than 3 years old. It won't spin, but it will fill at the start of the cycle, then shut off. Then when it is switched to "Drain/spin" it will start to drain, but won't finish the cycle and it never starts spinning. The belt is good. We took the motor off and tested it to see if the motor will go to ground and it doesn't. What can we do to fix this problem?
  • 4 more comments
  • jonogu Nov 25, 2008
    won`t spin
  • jthree Nov 28, 2008
    I have the same issue. The drum does not turn at all. I have replaced the speed control board having been told that was likely the cause but it still does not run.
  • Anonymous Dec 03, 2008
    We bought the same washer in MAR of 2005, in FEB of 2008 we had to repair both mounts for the drum and replace the out rubber boot due to mold issues. Now the washer will not spin, very dissatisfied with this washer, will never buy fridgidair again, shame on them, we paid $1274 for the washer/dryer pair at Lowe's, and it only lasts less than 4 years. The dryer has issues as well.
  • bwilson371 Dec 06, 2008
    My frigidaire washer GLTF2940ES runs fine untel the final 7 minits of the final spin cycle .The clothes remain wet .
    why do you say your help is free then try to charge me
  • Anonymous Dec 07, 2008
    the cycle will run for 5 minutes then reset and then shut off. water will run in and will drain when i put it on spin cycle it will turn for a minute and then shut off
I replaced the speed control module and all is fine now. The part number is 131770700 which has since been updated by 134149220.
Posted on Dec 08, 2008
I need a solution for this problem, you can help me, please
Posted on Nov 25, 2008
Solution: take off the back off the door on the back of the washer. Look underneath where the drain hose attaches to the pump. Squeze the clamp to loosen it and pull the drain hose off of the pump. Feel inside the opening of the pump side and there is a flap which is there to prevent backflow that gets stuck in the wrong position. Tear the flap off as it is what is causing the problem. Put the hose back on and enjoy your washer working again.
Posted on Dec 07, 2008
  • 1 more comment
  • robbie young Dec 07, 2008
    The flap getting stuck in the wrong position is preventing the washer from draining. When the washer will not drain, it will not spin because it is too heavy and there are sensors to the electric motor which de-activate it or put it back and forth into drain mode.
    I am not a washing machine mechanic - I just have the same problem and through trial and error figured this out.
    Tearing the flap off may void your warranty so do it at your own risk... I'd rather not have a flap than have a washer that does not work.
    Chow!
    No do not tear the flap off! That was a bad idea! I thought that was the problem. but now my washer is not working right. I have to go buy another flap......
    Sorry. I still have the same problem.
    robbie young
    OK. It looks like it is working. I have never seen it drain this good, since I have been working on it.
    Now it is going into full spin mode. This thing spins super fast. Let me check the clothes real quick. Wait! It does not work because when it is in the last spin mode it pulls the water from the discharge line back into the washer - because there is no backflow preventer - the flap.
    Conclusion: I think the flap is still the problem with the drainind in that it gets stuck in the tube in the wrong position. Only there needs to be the flap for the drain to prevent the old water from coming back in.
    Maybe a better made flap than the factory flap...
5 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: frigidaire (gallery series) err problem
ck to see that a control lock light is not illuminated, as far as fisher and paykel pressure swithc is part of motor controller under main console. removing screws behind console allows you access and from ther i would remove clear plastic tubing from right side of control and blow down the line (sometimes detergent will block other end not allowing proper readings)
Posted on Feb 24, 2008
  • 208 Answers
SOURCE: I have a code E20
bad pump
Posted on Jun 22, 2009
  • 4 Answers
SOURCE: washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Posted on Mar 20, 2010
  • 1531 Answers
SOURCE: Frigidaire Gallery Series GLTF2940 front load
check the belt make sure it is still contected.
if that is good you may have a faulty door lock
Posted on Apr 10, 2010
Washer will not spin what do i do first
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 16, 2011 | Frigidaire Gallery Series GLRT83TEK 30"...
My washer wont spin it washes but wont spin i have a Frigidaire Gallery
heatman101
Oct 26, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Water will not drain and washer will not spin
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 01, 2010 | Frigidaire Gallery Supreme Series...
Washer will spin while in rinse mode, but does not
this could be a main control board problem.how ever i would check the drain pump for any kind of foregin object that may be causing the drain but to stop functioning.last resort bad drain pump
Sep 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire Front Loader Won't Drain
if your washer is digital or with elecronic control board check the the motor control board located at the bottom difiniely you have to call a tech to confirm that. other model like wd5595 and wd 8095 has the same problem and it is the motor control unit that always fails.
Mar 21, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Dec 18, 2007 | Washing Machines
Frigidaire GLTF2940ES Front Load Washer Logo
470 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
