Question about Mitsubishi CS-35505 35" TV
Changing the inputs
I am connecting multiple devices (dvd, vcr, gamecube) into my tv. I am using the s-video for the dvd, input 1 for vcr and input 2 for the gamecube. As I change the input channel to each device, my tv won't bring up the INPUT-1 channel. I can get the S-VIDEO and INPUT-2, but not INPUT-1. Is there a setting that needs to be changed? Do I need to reset the channels? thanx
  • 5 Answers
It might depend on the type of input. VCR often use A/V or component cables. if you are using AV (red, white, yellow) make sure they are plugged into the right input. if plugging in to a component (white, red, green, blue, red) make sure the yellow plug goes into the green input. If plugging in component make sure your red wires are not backwards. There should be a white and red together (these are the audio) and a green blue red together (these are video)
Posted on Sep 08, 2017
SOURCE: WD-52628 Mitsubishi - change inputs
We had the same problem. Luckily, we had a service contract, so it was serviced yesterday. The fix involved the service guy going through a "service menu" and resetting the TV that way. He was not "allowed" to tell me how I can access the service menu, however. I do plan to research this on the internet in case it happens in the future. It is basically a software/computer problem, and unplugging the TV isn't enough to clear it unless the TV is unplugged for "a long time." The technician said the length of time depends on the condition of your capacitors. Anyway, as a temporary fix, he showed me that you can go into the PIP mode. The device toggle for PIP apparently did still work with mine, so I was able to switch the device on the secondary picture and then switch it to primary, then toggle the PIP off. Good luck!
Posted on Mar 26, 2008
  • 4 Answers
SOURCE: lost remote to freeview set
replace system control and memory control.
Posted on Sep 07, 2008
SOURCE: ws-55511 component inputs will not work
you have to hook up the HDTV receiver to the INP (or what ever the initials are) input to get HD
Posted on Oct 20, 2008
SOURCE: How do I set the correct input channel for S-video from laptop
press the video/tv button on your remote control until it gets to video or input 3
Posted on Feb 18, 2009
hawk127311
  • 350 Answers
SOURCE: How do I change my remote for TV to Input Video 1?
There should be a button on your remote denoting "Input." If you connect the DVD player to the TV on "video input 1" then push the input button on the remote or TV itself until the DVD appears on your TV (which will be Video 1). Some TVs must have the component (in your case) the "DVD" player connected to the TV before the TV will recognize it. Make sure the DVD is powered up and then push the input button until the DVD player appears on the TV. Depending on your TV inputs, there may be multiple inputs like, Video, Component, DVI, or HDMI. The above are listed in the respective order of "quality." HDMI being the best. Whatever input you hook the DVD player up to on the TV will be the "input" you will look for when pressing the input button. Hope this helps.
Posted on Oct 26, 2009
How to source AV Input on remote
Search Results
    How do I change the input on my television? ' FAQ ' Cogeco ...
    https://www.cogeco.ca/.../how-do-i-change-the-input-on-my-tele...
    CogecoClick on the TV button near the top of the remote. Click on the video source button on the bottom left corner of the remote. Using the arrow keys to highlight/select the inputyou want. Some televisions may require pressing the source button multiple times to change the inputs.
    Understanding Inputs - Harmony Support - MyHarmony
    https://support.myharmony.com/.../understanding-different-input-changi...
    Televisions, AV receivers, soundbars and other home electronic devices switch ...Devices with toggle (or cycle) inputs have a single button on their remote that ... In the below example, you would press the Source button to bring up a list of ...
    Changing AV input on TV using Sky remote ' AVForums
    www.avforums.com > ... > Satellite TV, Sky TV & FreeSat
    Changing AV input on TV using Sky remote. Discussion in 'Satellite TV, Sky TV ...VSX-924 LG simplink changing AV source to TV. Posted By djrobmac In AV ...
    Selecting the DVD, VCR, Game Console, HDTV, Camera, or ...
Feb 08, 2016 | Venturer KLV39150 15" Under Cabinet LCD TV...
How to change sylvania tv to video without remote
I was able to get the Sylvania TV to accept a different input (the remote was lost) by connecting the DVD to a Sony VCR using composite RCA jacks then connecting that to the TV. You'll need two 3-jack (yellow, white, red composite) cables - cheap at any store. Here;s how:
1. Connect RCA output jacks from the DVD to the input female receptacles of the VCR (first cable).2. Connect output jacks from VCR to the female input jacks on TV (second cable). 3. Turn on all equipment (VCR, DVD, TV)4. Switch the VCR to "Line 1" (for my Sony VCR, this shows up as "L1") by pressing the TV/VCR button on the VCR remote (which I did have).
Your system should now work.
The principle is to "fool" the TV into thinking that it's primary input is through the RCA composite A/V jacks rather than the cable connection. No need to disconnect the cable at any time. Any functioning VCR should work well as long as you have the remote for that device. Remember, connect output on the DVD to the input on the VCR, then the output on the VCR to the input jacks on the back of the TV. If you have the connectors on the TV, VCR, and DVD, component cables should work as easily. Remember, output from the DVD goes to the input of the VCR. Theoutput from the VCR (for which you DO have the remote) goes to the input side of the TV.
Apr 07, 2012 | Sylvania Televison & Video
What is the audio/video input?
Hi
Audio Video input or [AV] input is meant for to connect the TV to any external device which has AV output. For example, you can connect the TV with a DVD/VCR/Blu-Ray/Amplifier etc. The audio video output of the connectig device has to connect to the audio video input of the TV with an audio video cable. This cable can be bought from most of the electronic sparepart shops. After connectin it such, you have to go to the input selection window of the TV and must select the input of the tV to Audio Video. No tuning or any other adjustment should be done then. Just play the connected device and see the its output by Tv. OK.
Jul 10, 2011 | Toshiba 37C3030D 37 in. LCD Television
Hi i want to know how to connect my gamecube to my portable dvdplayer
I'm going to assume you are trying to be able to play both gamecube and the dvd player on one tv. Not at once, but I'm guessing you think you can't hook both to the TV. If you no matter what big tv it is, you can connect it to your tv.
If your trying to connect the gamecube to the dvd player then you need to have inputs and outputs on the dvd player itself. hook the video and audio of the gamecube to the input of the dvd player and the ouput of the dvd player to the input on the tv
Aug 09, 2009 | Pyramat PM450WR for PlayStation 2,...
Cant hook dvd/vcr to my cable box the manual says I need a extern
The cable box IS an external tuner.  You should connect the video output (either S video, HDMI, or component video) of the cable box to the video input of the DVD.  Then connect the audio output of the cable box to the audio input of the DVD via stereo RCA cables.  If your tv monitor has multiple inputs (ie: video 1, 2, and 3...) connect the video and audio output of the DVD to your tv monitor using an alternate video input (if cable box goes into your tv thru video 1, connect the DVD to video 2).  If your cable box only has one output, or your tv has only one input, then just connect your cable box to the DVD as above, and connect the DVD to your tv.
Jun 21, 2009 | Philips Magnavox DVD/VCR Dual Player
What is Input Select and how do I find this on my TV?
Typically, 'Input' is an option found on your television's remote control, not on the TV.
If you have your remote, look for a button labeled 'Input' - pressing this allows you to change the input that the television is using at the current time (ie. you can have multiple devices [GameCube, a DVD player, and an XBOX (for example)] connected to your TV through the various inputs on the back (where all the cables go) and select (or jump) between the various devices. This means that you don't have to unplug and plug in each different device everytime you want to use it)
Jan 08, 2009 | Nintendo GameCube Console
Lost manual...I cannot get DVD or VCR to record
You need to decide which set of inputs or outputs you want to use. To record, and watch what you have recorded on your TV, you will need TWO sets of audio/visual patch cords. One for recording and the other for playing. Let's start with the recording. Look for the Line in or video in plugs on your DVD-VCR unit. Some recorders have separate inputs for the VCR and DVD. Others let you select with the remote. Usually Line 1 is at the back and Line 2 is on the front. Your remote will have "recording source" to let you select, or sometimes you can use the channel up and down arrows to select your input source. Your remote will also allow you to select either the DVD or VCR for recording. Connect the Yellow plug to the Video In socket, and the red and white plugs to audio in., Connect the other end of the cord to the TV or cable box. Yellow goes to Video Out, red and white go to audio out. Recording from the cable box is much easier because you wiull always have a signal going into the DVD-VCR recorder no matter what happens at the TV.  Now look for the Video out connection on the DVD-VCR recorder. Connect the Yellow plug to video out and the red and white plugs to audio out. Ignore the other connections at this point. They are for RGB component video. Your DVD -VCR should have one output for both functions. Use that one.
Now connect that cord to a Video one or Video 2 input on your TV.
Test the set-up. Play a DVD or a VHS tape and try to bring it in using the TV remote.
Then turn on a program and try to record it on  the DVD-VCR, then play it back.
This sounds very complicated, but all that's involved are two patch cords with three plugs on each end - 12 connections in all and color-coded. YELLOW is always video.
Dec 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Toshiba Model 42HM66 DLP Projection TV
I strongly doubt it's the lamp assy since you can actually see the blue screen. If the lamp failed, you would not see anything on the screen. This blue screen indicates to me that either the tuner is no longer decoding the signal, in improper input has been selected (ie: input 1 is selected while actual signal is on composite 1), or something of that nature. If you are getting audio then the input is selected properly but the video decoder has failed.
If your cable signal is going through a VCR or DVD, disconnect it from there and go directly to the TV (ie: bypass the VCR/DVD). If your picture comes back, there's some kind of problem with your VCR/DVD player.
If you have multiple inputs, try connecting an input signal to another input (ie: video 1, or aux from a dvd player) and see if you get a picture there. If you do get a picture, the whatever input you're currently using has malfunctioned.
Mar 08, 2008 | Televison & Video
Sanyo TV
If I understand your posting/description right, you have:
1, a Sanyo TV with only 1 video input;
2. you have a DVD player with only video output; and
3. you have a VCR (which I will assume to be with both video input and output).
Your query, if I may clarify, is how to hook them up so that you need not connect/disconnect any video cable when you want to switch video source from either DVD or VCR.
If that is what you want, then connect:
a. audio/video OUT of your DVD to audio/video IN of the VCR;
b. audio/video OUT of your VCR to audio/video IN of the TV.
The above described connection would allow you to:
i. watch DVD movies on your TV (your VCR must be powered ON and set to Video INput, your TV must be powered ON & set to Video INput);
ii. watch tape movies from your VCR without disconnecting/connecting cables.
Additionally, this arrangement would allow you to record DVD movies in your VCR. Further, connecting your cable/aerial to the RF INput of your VCR would allow you to do the same with a TV/Cable program.
Incidentally, if one of your units (TV, VCR, DVD) would only have a single audio input, it is still possible since some models uses the white audio RCA connector as either left or mono, the red is right. You can also use a 2 female RCA to 1 RCA male adapter as shown below to joint the red/white audio.
Hope this be of some idea/help. Pls post back how things turned out or should you require additional information.
Good luck and kind regards.
Nov 19, 2007 | Sanyo DS32224 TV
Multiple video inputs
Unfortunately, you cannot use the connectors at the same time. The S-Video connector overrides the standard video connector. This is why they share common audio left/right inputs. If you could use them separately, they would each have their own set of audio inputs. (S-Video does not carry audio signals on the cable.) I'm assuming that you are connecting your Satellite as an input to your VCR, and then your VCR to the TV via a video connection. The VCR passes the satellite signal through unless you are watching a tape, then it overrides the dish signal. You have a few choices here: 1. You can connect the coaxial (RF) output from the VCR to the TV, and watch the satellite and VCR on channel 3 (or 4). You can then connect the DVD via S-Video, and watch it on "video". This is the simplest solution, and provides the best picture quality for the DVD (with this TV), but lower quality for the dish and VCR. 2. You can connect the DVD player via RF (if it supports that), watch the DVD on channel 3, and connect the VCR via video. This will make the DVD picture quality terrible. 3. You can replace the VCR with a combo DVD/VCR unit. You can then connect the S-Video out from the combo unit to the TV. This is a more expensive solution. 4. You can replace the TV with a model that includes more inputs. This is the most expensive solution, but will allow you to watch your DVD over component cables (very high quality) and VCR and dish over S-Video. Ironically, the obvious choice, connecting the DVD as an input to the VCR (as a pass-through) simply WON'T WORK. The signal put out by the DVD player is "copy protected" (using a system called MacroVision) which the VCR will refuse to play, even as a pass-though. Best of luck with this. Given that you are trying to make this all work without replacing equipment, I recommend option #1, until you decide to break down and buy a shiny new HDTV. They are coming down in price every week, but only you can decide when the time is right.
Mar 22, 2007 | Sony KV-32S26 32" TV
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
