Question about Pool & Spa
I have a Pentair MiniMax NT 250,000 btu pool heater that fails to
I have a Pentair MiniMax NT 250,000 btu pool heater that failsto ignite burners. the ignition element heats up and glows. the deviceattempts to light the burners three (3) times and then displays anerror...error code 04. the PLC on the inside had a red indicator lightthat blinks three(3) time which according to the key on the PLCindicates a fuel valve lock out. i have reset the heater by switchingit off and also by unplugging the unite for 10 minutes and no luck. anythoughts or suggestions?? please advise. thanks. rsm
  • chris0581 Mar 03, 2009
    my minimax would not start.  i had power but the blower never kicked on.  i realized the thermistor wire was broken so i repaired it.  now the blower kicks on but no hot exhaust and the red service light is now on.
  • 22 Answers
Two reasons.
1. There is air in the gas line. Power down the heater and allow it to try igniting until lockout. If it locks out, repeat the process. Most lines will clear within 4-5 attempts to ignite.
2. A plugged burner orifice. Run a small pipe cleaner in the brass fittings on the burner tray. They may have small webs in them restricting gas flow.
If the unit is a Standard (STD on the plate inside) it has a flame sensor that may also be bad. That sensor is on the end of the single wire that is cloase to the ignitor wire near the burners. Also check for a losse ground wire on the heater.
Posted on Dec 21, 2008
Could be inducer fan motor. On acall for heat inducer fan motor start the ignites the burner. The unit has to realize air flow. If inducer fan motor ok, check pilot assembly valve there is and adjustment screw on the valve body
Posted on Feb 06, 2009
I have a pentair minimax 400dv ,my heater burner comes on for a minute and then,the burner cuts off. The fan keeps running, the burner will ignite again. This will do this several times. Eventually the...
Cleaning the Thermal couple can work at times, however most times you will need to replace it. You may also be having an issue with the ignition control. You are in pretty deep now and it would seem like you are determined to save this heater, I would change them both.
http://www.parts4heating.com/Pool-Heaters-Pentair-MiniMax-NT-400-s/696.htm
Jun 30, 2017 | Pentair Minimax Ch 400,000 Btu Propane...
Pentair MiniMax NT pool heater not working
check breaker maybe popped check ignitor
Sep 29, 2017 | Pentair Minimax NT Heater
The pilot come on but not the burners
is t gas valve on is t tem on high ? 24 v at t brown wire at t gas valve replace gas valve if not replace ignitor
Jul 03, 2009 | Pentair Minimax Ch 250,000 Btu Natural Gas...
New ignitor..still won't light
Clean out the pilot assemby or replace it. It is probably blocked by rust and/or spiders and is not letting enough gas (if any) through.
Jun 18, 2009 | Pentair Minimax Ch 250,000 Btu Natural Gas...
BiAnnual maint of Pentair Minimax NT Low NOx Series Pool Heater
if unit is sooting check gas supply and pressure unit is overheating and ruining its self
Sep 26, 2017 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Pool & Spa Logo
1,230 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
