Question about Microsoft Xbox 360 Console
When a game in placed in the console I get an ''open tray'' message
It says "open tray" on games but will play DVD's. It would read maybe 1 or 2 games out of 10 but now it will not read any.
  • ksp1051 Nov 24, 2008
    does it have to be halo 3? and how exactly do u reboot it? does it matter if its the arcade model 360?
    Thanks, I really appreciate the info.
  • 47 Answers
Just put Halo 3 in the drive, set the 360 to automatically play games on Boot-Up, and reboot it.
Tell me if that works.
Posted on Nov 24, 2008
  • Gaurav Gandhi
    Gaurav Gandhi Nov 24, 2008
    The open tray issue is normally linked to the laser itself. You do NOT have to replace the entire drive, as doing so may cause you further problems.
    If your 360 is under warranty, send it in to be replaced.
    If not, then there are things to try!
    Open the console (using the various online tutorials) and remove the DVD-ROM drive. Open the drive and you'll have access to the laser. Get a Q-tip (cotton bud) and moisten one end with some boiled water. Rub gently over the lens of the laser, then use the other end to dry. Try the game again.
    If the above doesn't work, purchase another drive assembly, matching what you already have. You could just buy the laser, but there's no point if it's something other than the laser (and you get one with a new drive). If you have a Hitachi drive, make sure you buy a Hitachi. The same with a Toshiba-Samsung. Keep the same drive type. New drives can be purchased from Ebay. For Toshiba Samsung's, either the MS25 or MS28 will be fine as the insides are exact. Hitachi's are likewise: any version will do.
    Here's the good part: you don't need to mess with the firmware on your drive, since the problem is mechanical. Carefully remove the DVD logic board from your faulty drive (the circuit board inside the DVD-ROM itself) and get a Sharpie/Marker and tick it/sign it/etc. Something which you can distinguish one from the other. The boards will look the same and you don't want to mix them up!.
    Set your board to one side and get your replacement drive. Open it up too and remove the board in the same way. Now put your board in this new drive, carefully replacing the cables (there are guides online for this too). Close the drive and try it.
    Because you're keeping the PCB from your drive, your DVD key will match still and you won't have any configuration problems!
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
Open/Close tray message
This means that you need your DVD drive replaced. If you are under your 1 year warranty from MS go to www.xbox.com/support and fill out a repair request. If you are out of warranty make sure that you only let an experienced professional perform this repair. If you do the repair on your own, or have someone that doesn't know what they are doing do it then it's very likely your Xbox will never play games again. There is vital information on the old DVD drive that must be extracted and put into the replacement in order for your 360 to allow it to play games. I can do this repair for you if you'd like. Email me at Jordan@jordanselectronics.com for more info.
Dec 28, 2009 | Microsoft Xbox 360 Console
The Xbox will not read/start a game... I place the game on the tray... close the tray.. makes a scratchy noise.. it's says Reading... it's says open tray
This maybe the game disk slipping inside the
drive due to a lose clamping of the disk between the
hub and the spindle motor . try a dvd if it plays
then you more than likely have a weak laser .
this is the cause of read errors 90% of the time.
Laser are cheap 20.00 30.00 and not hard to install
yourself if you want to save some money / time.
or you can have a shop swap it out for you
for about 70.00-80.00
if you have any questions or concerns feel free to ask me.
Rob
Nov 19, 2009 | Microsoft Xbox 360 Console
Open tray error
1. Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser. The laser is the part that actually reads the disc. The reality is... with all the hours and hours of gameplay, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
3. Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything, including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock. The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
Nov 11, 2009 | Microsoft Xbox 360 Console
Ps2 wont play DVDs
Your PS2 laser is wearing out. When the laser starts to go, first games will skip... then eventually the PS2 will stop reading DVDs altogether. If you keep using it to read CDs, it will eventually stop reading those too and the laser will die altogether. Here's a website that will help you identify your PS2 model, show you how to replace the laser, and they sell parts and do repairs too
http://store.richspsxparts.com/slps2direerl.html
Oct 05, 2009 | Sony PlayStation 2 (PS2) Console
Xbox 360 open tray message; not reading discs
If it won't play any games it might be the laser that reads the disk. I would suggest getting it checked out somewhere.
Oct 02, 2009 | Microsoft Xbox 360 Console
My xbox 360 doesn't play my games
it could be that u got **** like food in your x box360 open it up and clean it out put it back to gether and try it if this dose not work tell me at alexswierenga@yahoo.com ty
May 29, 2009 | Microsoft Xbox 360 Console
the lens of the disc drive needs a check up...
Its definately an internal problem, just have the people at microsoft repair your console.
Will not play any disc
try to clean the lens in ur x box by buying a can dust remover or you could buy a dvd eye cleaner the wierd sound in just ur x box stalling on the game cause it cant read it
Mar 23, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
77 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
