Question about ASUS P5V800-MX Motherboard
Cpu fan error
Always reset the time everytime perform the shut down
  • Anonymous Jan 13, 2009
    i am using core 2 dau cpu on this board
  • ASUS Master
  • 4,806 Answers
Posted on Nov 24, 2008
MY computer shuts itself off and then restarts, about once a day
You will need to check your event log in order to pin point where it is shutting down, thus solving the problem as it could be any number of things.
Dec 31, 2013 | Compaq Computers & Internet
Fan dose not slow down
It seems that your system is overheating so follow these instructions first
- Make sure your Heat Sink is placed properly above the processor
- Clean the Processor fan, Heat Sink and other peripherals
- Use High Speed fans
- Use CPU Heat Sink Paste in the processor
- Make sure your dint restrict the speed of CPU fan
- Shut down your computer atleast two hour a day
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of overheating
Aug 27, 2013 | HP TouchSmart Computers & Internet
Every time there is a problem of overheating error and my system shuts down .when i restart my computer cpu produce beeps . motherboard is of Intel 915 series is used.......
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is the problemis not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Sep 09, 2011 | Intel D915GLVG Motherboard
Is my cmo s battery goin bad?because every time i start my computer the time is always reset, and also detect error cpu fan.
Yes. If the time is off, the CR2032 battery is probably bad. The battery is located near the PCI port. CPU fan error, is a different issue though. The fan may need replacement. Verify the fan is running and not full of dirt.
Aug 04, 2011 | ASUS P5PE-VM Motherboard
Compaq Presario S5300NX (DM174A#ABA) PC Desktop: Compaq Presario Dekstop: CPU Fan error on bootup. ...
The fan has a third wire, that is used to tell the uProcessor that it is spinning and in some cases how fast.
Replace the fan and that should fix it. Spares form many suppliers on ebay
May 18, 2010 | HP Compaq Presario S5300NX (DM174A#ABA) PC...
Computer keeps shutting down.
Do the fan's spin when you power the PC on? All of the fans should spin up for at least a second upon initial boot. The CPU fan and video fan (if you have an external card) will spin the entire time the PC is on and vary in speed depending on temperature.
Try booting the PC with the side of the case off and note and fans that aren't spinning. The temperature to shut off the CPU is really high. If the temperature is getting hot enough to do this, you should notice a failure in a fan right away.
Mar 09, 2009 | Computers & Internet
Fan error
You mite not want to reset this. This could be telling you that your fan is faulty/Dieing. If so then if it doesn't turn off your comp, your CPU will fry from the heat. Try replaceing your CPU fan within your computer. "Cool Master" is a good brand. you can find them at any Fry's Electronics Store.
Oct 05, 2008 | Averatec Sotec 3200 Series Fan with...
OVERCLOCKING FAIL/CPU FAN ERROR
First approach shold be the CMOS utility, check in FAILSAFE DEFAULTS that the error settings for shutdown are either null for overclocking or disabled if you don't have the failsafe defaults on your CMOS utility then set your settings to best performance (should be found on the main page of the CMOS utility). If you are unsure of touching the CMOs then you could try to remove the CMOS battery (small 3 volt battery about the size of a 20 cent coin) located on the motherboard this should reset the CMOS and fix the problem. hope i could help,thanks:)
Aug 11, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Hardware monitor found an error
Diagnosis: Lack of P.S.U. fan speed report indicates P.S.U. fan sensor damaged by overheating. This was caused by cooling fin blockage since the Sony design on this model cools the C.P.U. THROUGH the P.S.U.
Expert level fix: Remove P.S.U. Remove C.P.U. fan and vacuum. Remove C.P.U. cooling fins from C.P.U. and cooling fan mounts from fin box, vacuum. Reassemble C.P.U cooling system. Replace P.S.U. with O.E.M. part only since in this case it is proprietary to the unit.
Jul 31, 2008 | Computers & Internet
Unwanted Shut-off
First Charge up you battery while the computer is off. Once fully charged unplug the adapter and play the game...see if it shuts down. If not replace that ac adapter. If it still shuts down... Your unit is overheating most likely. When you play high tech games which cause the processor and fans to run harder once it gets to hot. And most times you can hear the fan running loud on your laptop. 1. check the system requirements on the game 2. Are you overclocking your processor, check your bios 3. Lower the graphics settings and features in your game.. see if it shuts down 3.Or while you are running the game do the follow hit ctrl, alt, del buttons at the same time. A task manager box will pop up. Click on the tab Performance.....what is your cpu usage? 100% if so it's running the proccessor hard. Now in the same box click on Processes, then user name, you will then see all processes that are running at that time. If you want to play the game off line...only!!! you can stop some processes from running. On the bottom right hand corner of your screen by the clock you will see icons that load up at startup. Right click the ones not in use, like virus scan, firewall, other background applications that are running by right clicking over the icon and exiting or closing the application. Now keep in mind before you go back on line you should restart your computer so your security software will reload. Other reasons would be internal cleaning, fan, heatsink replacements and so forth. Which may need to be performed by a professional repair shop. Now they do have a laptop colling pad which have worked for some people. Also these laptops can overheat quickly, do not sit them on beds, and your lap when using ventilation is important. And also you might still want to have that ac adapter checked out. If all else fail... restart you computer in safe mode...try running the game..see if it shuts down. Good luck with your games
Sep 15, 2007 | Acer Aspire 5002WLMi Notebook
ASUS P5V800-MX Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
