Question about Sony VAIO VGN-N250N/B Notebook
Can't find documents and settings folder in program data
I'm trying to install a piece of software and have been having issues. looked up trouble shooting on the manufacturer website and found it's a common problem with vaios with vista. so i'm trying to follow the instructions to fix it and there is no documents and settings folder in my prog data folder! i can't seem to find it anywhere on my computer and am wondering where it went or if it ever existed.
software: nova development - label maker deluxe 3.0
error 1320 the specified path is too long.
http://kb.novadevelopment.com/al/12/1/article.aspx?aid=3765&tab=browse&bt=4&r=0.718855
  • andrea h Nov 24, 2008
    did a little more research... there is no documents and settings folder in vista.. it's split between the users folder and prog data folder apparently... which still isn't helping me. any ideas??
  • Sony Master
  • 32,281 Answers
If you click on My Computer, then the Local Disk (C), then you will see the Documents and Settings folder among some other folders.
Posted on Nov 24, 2008
  • Chris Hingee
    Chris Hingee Nov 24, 2008
    The C:\Documents and Settings folder is in the C:\Users and C:\ProgramData. Vista uses symbolic links pointing to these new folders for compatibility reasons. However, many guides still refer to the old folder structure. There is a simple trick for using the old folder name in Windows Explorer, though. This way you can find configuration files easier.
    If you want to see the symbolic links, you have to enable first “Show hidden files and folders” in Folder Options. To access the Folder Options you must press “ALT” in Windows Explorer to make the menu visible. You’ll find them under tools.
    Now, you should be able to see Documents and Settings. But if you double click on it, you’ll get an error messages. Even administrators don’t have enough NTFS rights to navigate to this folder. It is not even possible if you change the rights by taking the ownership.
    You can, however, navigate to subfolders of Document and Settings by entering the corresponding folder name in the address bar of Windows Explorer. For example, just type C:\Documents and Settings\%username%\ and you will see all of the user profiles’ subfolders, you know from Windows XP.
I deleted my Microsoft Office Activation Wizard
try this :
1. Quit all running programs.
2. Download and install the Windows Installer Cleanup Utility.
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
3. After you have installed the Windows Installer CleanUp Utility, click
Start>All Programs>Windows Install Clean Up.
4. Highlight Microsoft Office 2007 entry in the list and then click
Remove. Click OK and wait for the process to end. If any other stand alone
Office applications (such as Visio and Project) appear on the list, please
also remove them. Then, click Exit to close the Windows Installer Cleanup
utility.
5. Click Start>Run, type "regedit" (without the quotation marks) in the
Open box and press Enter.
6. Locate the registry keys below and click Delete from the Edit menu.
Click OK on the following warning dialog box.
Note: Please go to File>Export and backup all the registry first.
HKEY_CURRENT_USER\Software\Microsoft\Office
HKEY_LOCAL_MACHINE\Software\Microsoft\Office
Quit Registry Editor.
7. Delete or rename the following folders or files if they exist:
C:\Program Files\Microsoft Office
C:\Program Files\Common Files\Microsoft Shared\OFFICE12
C:\Documents and Settings\<UserName>\Application Data\Microsoft\Excel
Data\Microsoft\Office
Data\Microsoft\Outlook
Data\Microsoft\Publisher
Data\Microsoft\Templates\Normal.dot
C:\Documents and Settings\<UserName>\Application Data\Microsoft\Word
C:\Documents and Settings\All Users\Application Data\Microsoft\Office
C:\Program Files\OfficeUpdate12
8. Click Start>Run, type "%Temp%" (without the quotation marks) in the
Open box and press Enter. Delete all the files and folders within it. If
there are some files which cannot be deleted, just leave them alone and
this will not affect the result.
9. Empty the Recycle Bin.
10. To remove Mapi, search for and rename the following folders/files if
they exist:
C:\Windows\system32\mapi32.dll
C:\Windows\system32\mapisvc.inf
C:\Program Files\Common Files\System\Msmapi
C:\Program Files\Common Files\System\Mapi
11. Restart your computer and install Office 2007 again.
May 12, 2011 | Computers & Internet
I am trying to instal quickbooks pro 2008 but error 1603
Error 1603 is related to insufficient rights to install QB. Please follow these steps to resolve this issue. Assuming you have Win XP. 32 Bit OS.
1. Remove QB from Start>control panel>Add/remove programs. {IF YOU FIND ANY QB INSTALLED].
2. Rename all intuit folders to Intuit-old. You wil find these folders here:
  • C:\Program Files\Intuit
  • C:\Program Files\Common Files\Intuit
  • C:\Documents and Settings\All Users\Application Data\Intuit
  • C:\Documents and Settings\All Users\Application Data\Common Files\Intuit
3. Then install QB using QuickBooks.msi . You will find it inside QBooks folder in your QB disc. Right click on the DVD / CD drive and click Open/Explore. Then go to Qbooks folder, find Quickbooks.msi and then run it. Follow the wizard and then install it.
IF STILL ISSUE IS UNRESOLVED, THEN REMOVE AND INSTALL MICROSOFT .NET FRAMEWORK 2.0 SP2. To do it, please follow.
1. Download and install .NET removal tool from:
http://public.blu.livefilestore.com/y1pM-hUF1x_Oqpme4sYbkLY1eFfh7z7FTyANwGAK1PQgJMwhILtFzMj7WXQJtjfH39GalpsBeQRzeQHXRlbO9w1gA/dotnetfx_cleanup_tool.zip?download&psid=1
then save it and unzip it . Then run it. Select Allversions in the box where it will ask to remove .net framework from the computer.
2. Download .NET framework 2.0 SP1 and then install it . you can download it from:
http://www.microsoft.com/downloads/en/details.aspx?familyid=5b2c0358-915b-4eb5-9b1d-10e506da9d0f&displaylang=en
click on DOWNLOAD next to NetFx20SP2_x86.exe. download it and install it.
3. Restart your computer and then again install QB.
IF STILL YOU GET ANY ISSUE, REPLY WITH FOLL :
1. WINDOWS VERSION.
2. are you installing QB using a disc or downloading from the Internet?
3. Any Antivirus on the computer?
Oct 30, 2010 | Intuit QuickBooks Pro 2008: Windows
How to remove a program,that is not on the "ADD & REMOVE" list
Try running the program first and seeing if there is any option to remove it that way. If there is not, then you will have to delete all the program data manually.
Enter the C:// drive and look for a file called Program Files. Look for the folder with the name of the program or the program's publisher. If you find the program's, delete the folder and if your find the publisher, enter that folder and delete the program's folder. Some newer systems have Program Files (x86) or (x64), so check there too.
Also, turn on viewing of hidden files. Depending on your operating system, there are multiple ways to do this, google "Viewing hidden files in (insert operating system)". After these are revealed, go back to the C:// drive and enter Documents and Settings, followed by your username. A folder should now be seen which is a lighter color and looks different from others name Application Data. Enter this hidden file and delete the Program folder or enter publisher then delete the program folder.
I hope this helps and apologize if it does not,
-Robert
Jul 15, 2010 | Computers & Internet
Quickbooks 2008 will not load, it says that it is installing and then goes to error 1325
Assuming you have Win XP, please follow these steps:
1. Remove QB from Control Panel>Add/remove programs.
2. First rename all folders of Intuit. rename Intuit to Intuit-old from the following locations.
3. Then disable your Antivirus / Online Security.
4. Then install quickbooks using quickbooks.msi . You will find quickbooks.msi in the foll location:
>right click on ur QB disc and click open/explore.
>Double click on QBooks folder and run quickbooks.msi and follow the wizard.
If you still get any more issues, please reply with following:
1. Which windows version you are using ?
2. Are you installing QB for the 1st time on this computer?
3. Did you install any other software rrecently ?
P.S : this issue may also be because of Microsoft .NET framework on your computer. PLease help me with your reply to help you.
Feb 19, 2009 | Intuit QuickBooks Pro 2008: Windows
Relocate the Documents and Settings Folder to a New Partition
greetings.
The default installation procedure works best. In my experience at internet cafe, my documents, desktop and program files are set up in the "other" drives. Drive c is freeze(deepfreeze) with this config, we could at least have piece of mind.
Jan 29, 2009 | Computers & Internet
Can't get picture to scan
try doing this procedure to fix the issue.....
To perform a clean installation of the KODAK AiO Home Center software, follow the instructions below:
1. Disconnect all USB devices from the computer, including the Kodak EasyShare all-in-one printer.
2. Uninstall the KODAK All-in-One Printer Software:
    a. In the Control Panel, select Add or Remove Programs (WINDOWS XP Operating Systems) or Program and Features (WINDOWS VISTA Operating Systems).
    b. Select one of the following software programs from the list of currently installed programs, depending on which one appears in your list:
      • Kodak EasyShare software
      • KODAK All-in-One Printer Software
      • Kodak EasyShare 5000 series all-in-one software
    c. Click Change or Remove (WINDOWS XP OS) or Uninstall (WINDOWS VISTA OS).
    d. When the Install Wizard appears, click Next.
    e. Depending on the issue(s) you are experiencing, do the following:
      • If you are experiencing errors with KODAK EASYSHARE Software, such as a tri-code, in addition to errors with KODAK All-in-One Printer Home Center Software, select Remove, click Next, and follow the on-screen instructions for removing the software.
      • If you are not experiencing errors with KODAK EASYSHARE Software, select Modify to uninstall only KODAK All-in-One Printer Home Center Software, then click Next.
    f. In the Custom Setup window, select Remove from the drop-down menu for the Kodak All-in-One Printer, and click Next.
    g. In the Ready to remove the program window, click Next.
    h. In the Uninstall Complete window, click Continue.
    i. Restart the computer.
IMPORTANT:
    • If you selected Modify and only uninstalled the KODAK All-in-One Printer Software and did not uninstall the KODAK EASYSHARE Software, continue to Step 4.
    • If you selected Remove and uninstalled both the KODAK All-in-One Printer Software and KODAK EASYSHARE Software, continue with Step 3.
3. Run the Clear Utility to delete any previously installed KODAK All-in-One Printer Software components:
    1. Got to www.kodak.com/go/clear to download the Clear Utility for KODAK EASYSHARE Software.
    2. Select your operating system from the drop-down list and click the Download button to save the file to your desktop.
      Note: If the status indicator on the Clear Utility stops, check the taskbar on your computer for an active security program. If a security program appears in the taskbar, it may be prohibiting the Clear Utility from running. You must allow the Clear Utility to run on your computer before you can continue.
4. Delete the files and folders that can interfere with the installation.
    For WINDOWS XP OS, delete:
      • Printer folder in C:\Program Files\Kodak
      • Both the Eastman Kodak Company and KDS_Kodak folders in C:\Documents and Settings\All Users\Application Data
      • Kodak 5000 Series AiO folder in C:\Documents and Settings\All Users\Application Data\Kodak
      • Printer folder in C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup
    For WINDOWS VISTA OS, delete:
      • Eastman Kodak Company folder in C:\ProgramData
      • Eastman Kodak Company folder(s) in C:\Users\your name\AppData\Local
5. Run Disk Cleanup:
    1. Open My Computer.
    2. Right-click Local Disk (C:) and select Properties.
    3. Click the Disk Cleanup button.
    4. When the Disk Cleanup for (C:) window appears, select the Temporary Internet Files, Recycle Bin, and Temporary Files check boxes.
    5. Click OK , then click Yes to delete all files and begin the Disk Cleanup.
    6. When the Disk Cleanup is finished, click OK in the Local Disk (C:) Properties window.
6. Shut down all background applications.
    1. Select Start > Run.
    2. Type msconfig in the Open field, and click OK.
    3. Select the Startup tab.
      IMPORTANT: If not all the applications in the Startup Items list are selected, write down which applications are selected so you know which ones to turn on again later.
    4. Click Disable All , then click OK .
    5. When prompted, restart the computer.
7. After the computer restarts, install the latest version of the KODAK All-in-One Printer Software as a free download from the Kodak Web site at www.kodak.com/go/downloads.
    • If the customer has the latest version of the KODAK All-in-One Printer Software on CD, install the software from the CD.
8. Before restarting the computer again, turn on the background applications.
    2. Type msconfig in the Open field and click OK.
    4. Under Startup Items:
      - If only some items were originally selected, select the check box in front of the items that you noted in Step 5-c.
      - If all background items were originally selected, click Enable All, and click OK.
9. Restart the computer.
Nov 09, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Problem with the drive
Hi pravin,
One must pay close attention to the display screen when performing a new instillation of windows. Windows will show you the drive partitions. In your case windows will show there are two partitions. One C:\ & a second partition F:\. Perform a 3rd installation of windows. When you get to the screen where you can see both partitions (C: & F:) have windows delete the F: partition. Than have windows format the C: partition. Once C: has been formatted have windows install its self onto C:\
Install your driver software for your board. Than update windows through windows update service.
If you wish to back up your personal data to a CD/DVD writer, suggest you do this before formatting the system. Suggested folders to back-up.
C:\Documents and Settings\ User name\Application Data\Microsoft\Address Book
C:\Documents and Settings\ User name\Desktop
C:\Documents and Settings\ User name\Favorites
C:\Documents and Settings\ User name\Local Settings\Identities
C:\Documents and Settings\ User name\My Documents
Data from any program you may have installed.
Once windows has been updated & you install anti-virus software you can copy & past each folder over the new folder in windows.
How to install windows XP. http://support.microsoft.com/kb/316941
Good luck pravin!
Mike
Sep 23, 2008 | Microsoft Windows Xp Home Edition Sp2...
Certificate File is missing in roxio
The following steps will completely remove any Roxio and Sonic software from your computer.
  1. Disable your startup applications using MSCONFIG. This will disable any unnecessary background or system tray applications from loading.
    • Go to Start -
Jun 25, 2008 | Roxio Easy Media Creator 7
Program!!
Here is a procedure (pasted below) which a Beta tester of CounterSpy developed having to remove and re-install various versions and running into the same problem you described. I would suggest reading through the discussion thread (CLICK HERE) before proceeding.
Hope this will FixYa!!!
____________________
Manual Uninstallation of CounterSpy 2.x
1.Open Task Manager and be sure none of these three are listed
a) SBCSSvc.exe (CP service)
b) SBCSTray.exe (tray icon)
CounterSpy.exe (CS main app)
If any are listed click "End Process"
2. Be sure the CS directory is gone. The standard location is C:\Program Files\Sunbelt Software\CounterSpy
3. Remove additional folders that may be located at these three places:
a) C:\Documents and Settings\All Users\Application\Data\Sunbelt Software
b) C:\Documents and Settings\user\Local Settings\Application Data\Sunbelt Software
c) C:\Documents and Settings\user\Application Data\Sunbelt Software
4. Run the Windows Installer Cleanup Utility. If anything is listed for Sunbelt CounterSpy, select and hit "remove".
5. Look in C:\Windows\Downloaded Installations and
C:\Program Files\Downloaded Installations
you should see one or more sub-folders with names like
{XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX} where the X's are random numbers. In each sub-folder will be an .msi file. Right click the .msi file and select properties. Look in the summary tab for indications that the .msi is an installer for Sunbelt CounterSpy. Delete the sub-folder, the one with all the numbers (do not delete the \Download directory folder)
6. Look in C:\Windows\Installer directory where you will find .msi files. Again, right-click each .msi and select properties. If any .msi files are Sunbelt CounterSpy, delete only those .msi files.
7. Look in C:\
if you have any {XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX} delete those folders.
8. Open Computer Management console utility (Control Panel-->Admin. Tools-->Computer Management) and select the Device Manager then click on View and select "Show hidden devices" . Expand the Non Plug and Play Drivers tree and scroll down until you find the SBHR device driver. Right-click on it and select uninstall.
The console will prompt you to reboot. Do so. If you don't find any SBHR device driver, there is no need to reboot.
9. You need to download a zip file at the bottom of my post. Follow the directions to be sure it is clean before you use it.
10. Check C:\Windows\System32 for the following 6 files and remove any if they are present:
a) SBAPIFS.sys
b) SBBD.exe
c) SBProt.sys
d) SBRC.dat
e) SBFC.dat
f) eSellerateEngine.dll
I also had a file SBProt.bak and asked if it was safe to remove; it was.
11. Check C:\Windows\System32\Drivers for the following three files and remove if any are present:
a) SBTEDrv.sys
b) SBHR.sys
c) SBAPIFS.sys
12. Last, if you have any Sunbelt CounterSpy desktop, tray or start menu icons remove them and reboot.
Jan 05, 2008 | Computers & Internet
Printer
A support tech at Canon suggested I try this.
find the file ImageCache.ic - I found it in application data folder in My Documents, delete it.
Uninstall CD Label Print, search for any other "CD Label Print" files or folders and delete them too.
Re-boot and re-install CD Label Print.
This worked for me. Hope it works for you too.
Cheers
OM
Dec 30, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Sony VAIO VGN-N250N/B Notebook Logo
126 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
