Question about Graco SnugRide 8646 - Fiesta
Graco Snugride canopy
I had got a new cover for both of my Graco Snugride car seats. WOW  I can changed everything but the camopy.  How do I pull the canopy apart to put a new canopy on it? Any help pleae asap, Happy Holidays
  • NatalieCoop Dec 01, 2008
    Hi! I need to take my hood off too to put my new cover. We got the hood off, but now need to pull apart the two pieces (you can't just slide the cover over the ends because they look like huge hooks...but in the middle it looksl ike you can pull apart the two pieces...we just can't get it to work!).
    Any help would be MUCH appreciated!
    Natalie
Slide the fabric all the way to one side to expose the center clasp (hook). Then using both hands grasp the clasp like you were putting you hands on handelbar (placing your thumbs under the bottom of the clasp about 1 inch apart). Then push up with your thumbs while pulling down with your fingers (which should be wraped around the outside of the clasp). You will need to push with your thumbs all the way up in order to separate the two pieces (note - it feels like you are going to break it but you wont).
Putting them back to gether is just a matter of aligning the tabs in the slots and pressing the two parts together.
Posted on Dec 20, 2008
DO GRACO SNUGRIDE INFANT CAR SEAT BASES WORK WITH A DIFFERENT MODEL?
Some do, some don't.
From Graco's web site:
What base will work with my car seat?
We have designed many of our car seats to work with more than one base, for your convenience. Please see the chart here for Classic Connect models.
The SnugRide Click Connect 30, 35, 35LX and 40 infant car seat carriers are compatible with any SnugRide Click Connect infant car seat base. Consumers should adhere to the height and weight requirements for the SnugRide Click Connect infant car seat carriers as stated in their owner's manual; however, the SnugRide Click Connect 40 infant car seat carrier is restricted to a height limit of 32 inches when used with a SnugRide Click Connect 30, 35 or 35LX base.
Jun 15, 2014 | Graco Baby Gear
The canopy on my Graco Stylus Travelsystem Stroller has an extra flap of fabric that doesn't seem to go anywhere. It hangs over the cupholders or lays over the canopy covering the window. It...
You may have the top on backwards. The flap is usually used as a sun shade, and should probably be over the open part in front of the stroller.
Nov 19, 2017 | Graco Snugride
How do i replace a graco carseat canopy?
The canopies simply pull off of the carrier. You would have to replace both the plastic and the fabric. You can order replacement sets from Graco for about fifty bucks, but that's kind of expensive. I don't think you can replace just the canopy. I'd call/email them to confirm.
May 01, 2011 | Graco SnugRide - Giselle Infant Car Seat
I can't remove the canopy on my graco snug ride car seat to wash it. I'm having trouble separating the two parts to get the material off.
The two plastic pieces clip together inside the fabric of the canopy, but if you push the fabric all the way to one side, you can expose the latch where the two pieces meet. The two pieces are identical, so you can push in on the tab on either piece to separate them. You have to push firmly, but they should separate easily.
Once you've washed the canopy, just thread one of the plastic pieces through the canopy and snap the two back together by sliding them together.
Hope that helps!
Aug 20, 2010 | Graco Snugride
Install graco snugride to a graco stroller
Fitting your Graco Snug Ride infant seat into a Graco stroller is usually easy to do -- the exact instructions just depend on which stroller you have. Typically, all you have to do is fold the stroller's canopy back, recline the seat (if it reclines), and snap the car seat in (backwards -- facing the rear of the stroller). You can hear it lock in place when it's in correctly. Your stroller's manual will have specific instructions, and if you don't have the manual you can find it online.
Which Graco stroller do you have?
Nov 24, 2009 | Graco Snugride
Dismantleing canopy
If this is for the Graco Snugride (I have the Windsor model from the Quattro Travel System), this will work:
1. Push the Graco canopy to one side, exposing the plastic support bars that hold the canopy in place.
2. The center of the support is where the canopy comes apart. Using both hands, pull the canopy support
bar apart (as if you were playing tug-of-war). It's best to grab the curved ends and pull HARD (and point it away to the side so that you don't hit your face).
3. Once the support bars are apart, remove the old Graco canopy and slip on the new/freshly washed canopy.
4. Secure the support bars by snapping them shut, and then slide the canopy into place.
Aug 26, 2008 | Graco SnugRide - Clover
Washing canopy on Graco Snugride
if the wash is hot you might melt the plastic parts
Feb 28, 2008 | Graco SnugRide 8649
The sun shade on top
1. Infant restraint comes with four identical canopy support parts. Thread one canopy support completely through one sewn tunnel.
2. Slide straight end of a second support into the straight end of the first support.
3. On models with four canopy supports, repeat steps one and two for the other canopy tunnel.
4. Attach canopy in the areas between the infant restraint and the handle base.
To remove canopy, reverse the steps.
http://www.gracobaby.com/assets/pdfs/instructions/ISPC089BA_ISPC106AA.pdf
Hope this helps!! Thanks
Nov 16, 2007 | Graco SnugRide 8646 - Fiesta
Graco SnugRide 8646 - Fiesta Logo
3,106 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dennis Crouse
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
