Question about Teac GF-350 CD Shelf System
Turntable spinning too fast
Any help or suggestions would be appreaciated!
The turntable is spinning too fast and it is noticeable.
  • diabur2 Nov 29, 2008
    Thank you so much for your help! We are going to put try putting a new belt in the unit!!
    Sergeant:
  • 250 Answers
The turntable speed is controlled by a belt, which is virtually a big rubber band. If it spinning too fast , then this means the belt is too tight. The only way this can happen is for the unit to be fitted with an incorrect size belt. You didn't say if you have a new unit, or a second-hand one, or if it has recently had the belt replaced. If it is a new unit and still under warranty, take it back to the retailer and ask them to fix it for you. Again, if you have recently had the belt replaced, take it back and ask them to do the job again, and this time to please use the correct belt. Be polite but firm....If you are a handyman, the job is not too hard to do yourself, and if you need any extra help, just ask, johnatwagga@yahoo.com. To buy the correct belt, you will need the name, model number, and preferably, the serial number. All of these can be found on the back of the unit. Good luck, and I hope this helps.
Posted on Nov 25, 2008
  • jbdurham Feb 11, 2011
    This answer can't be right...This is a direct-drive turntable, and its speed is controlled by geometry of turntable and drive shaft and drive shaft speed, not belt tightness. A belt that's too tight doesn't change the geometry or increase the shaft speed.
Turntable spinning to fast
Clearly an electrical fault. Could be something to do with the power supply or the speed control circuit, or even the motor itself.
For the manual visit the Gemini website.
Apr 21, 2013 | Gemini PT-1000 II Turntable
Direct drive spinning to fast
Sounds like a speed sensor in the motor has opened up. You need a repair shop my friend.
Spins too fast
Check that the belt [under turntable] is`nt twisted or the 33/45 speed button is`nt sticking on 45rpm
Feb 26, 2010 | ION Audio iTTUSB Turntable
My platter spins fast out of control
At a guess from the minimal informaton given, i would say the drive motor has gone. I would suggest taking it to your nearest dealer or service center for a full overhaul, appart from that, visit e-bay.
Oct 24, 2009 | Technics SL-1200MK2 Turntable
Turntable spins too fast at both speeds
this is belt driven turntable....have you tried adjusting it via the pitch control or even getting another belt for that turntable....
Apr 12, 2009 | Audio Technica AT-LP2D Turntable
Ion turntable speed problems
Turn the tturntable over, there is a speed control pot on the bottom
Nov 07, 2008 | ION Audio iTTUSB Turntable
Stanton ST150 turntable won't spin
Hello DeKay,
I just had a spindle lock issue this past Sunday at my gig. I had the turntables out in my car and brought them in. I let then warm up for 2hrs before plugging them in.
Everything was good. Then mid set my right side turntable started spinning really fast and then DEAD STOP.
I was pushing the platter and it really hard to turn. I took off the platter and tried to turn it with my hand. It was dead locked, WTF?!!
So I limped through with one turntables since I use Traktor Scratch Pro and made it through the whole night successfully.
I searched the net and it was suggested to lubricate the 1200 spindle with 15W40 motor oil. Since the motor design is indentical, I picked up some 10W40 motor oil since I couldn't find 15W40.
I oiled both turntables to be on the safe since. I tapped the spindle on the locked turntable to help loosen it.
I drove back home which is pretty much an hour drive and let the tables sit for another 2 hrs.
I decided to grab a thick towel and vice grips to work on the locked spindle.
Clamping down on the towel with the vice grips on the brass fitting for the platter I was able to free the spindle quite easily.
I was then able to turn it by hands so I did in both forward and reverse directions to work the oil down into the spindle bearings.
I put the platter back on and spun it manually to check for resistance, it was spinning nicely!
Plugged in the turntable, set the pitch at 0 and watched the stobe dots. There was no waver in the strobe dots. YAAAAAAAY!
My turntable is back to new and since I only use them on the road they stay stored most of the time.
So I would suggest just oiling the spindles every so often to keep them tip top.
Hope this helps you!
Peace,
DJ Quartz
Nov 06, 2008 | Stanton ST-150 Turntable
Turntable Spinning too fast
ya buy new belt loose or is this direct drive
Oct 09, 2008 | Teac GF-350 CD Shelf System
My tunrtable spins backwards :S
these motors are quite cheap. You can open it up yourself and see if any resistors are burned up. If not, contact numark parts dept and order new motor. quite easy to install.
Dec 06, 2007 | Numark BATTLE PAK v.4 Turntable
Teac GF-350 CD Shelf System Logo
956 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
