Question about Sony PlayStation 2 Slimline Console
No color for ps2
Hooked up to sanyo lcd, get sound and audio but no color is there a solution. tried older tv and we still get color
  • summertimegi Feb 02, 2009
    I have a Sanyo 50" and cannot get the colour to work for the PS2.
    Problem Solver:
  • 12 Answers
Check the AV wires. I've pulled a mistake before where I plugged the Video wire into one port (say AV2) and the audio into (say AV3). Drove myself nuts trying to figure out what was happening (video but no audio on AV2, and audio but no video on AV3). Eventually I fixed it and it worked.
Make sure the wires are in the right AV ports. If that's not the problem, then it's probably an issue with the TV. If that's the case, hook up a GameCube or a similar console (provided you have one) in the same ports as the PS2. If it does the same thing as the PS2, then it's probably the TV's fault. If it works fine it's most likely the PS2's fault.
Posted on Feb 18, 2009
How do i hook up the ps2 to my tv
you can connect your PS2 on tv by using video RCA... connect the fort on at the back of you ps2 and connect the three rca to your tv yellow colored for video, white and red for your audio... tnx
Mar 23, 2012 | Video Game Consoles & Games
Connecting to a video game console
Hooking your PS2 Up To your Stereo
Just got a PS2 and trying to hook it up to your TV, stereo or both? Here are instructions to help you get everything working smoothly.
First, some basic cable definitions. These are pretty much standard for ANY system or stereo you ever get, so it's good to learn them.
RED CABLE - right channel for stereo sound (get it - Red Right?)
WHITE CABLE - left channel for stereo sound
YELLOW CABLE - video signal
Your PS2 plays games and plays DVDs. So it is generating signals that go OUT of that box. You want those signals to go IN to your TV. The most simple way to do this is to simply plug them into your TV, if you have no stereo system hooked up and nothing else attached to your TV. Most TVs have stereo left in, stereo right in, and video in. Most in fact have them all color coded with the above colors. So all you do is plug the cables in and turn the TV on. Some TVs have to be set to channel 2 or 3 to know to take the signal in from the Video In line, but your manual would tell you if that was the case. Here is a diagram of the straight connection.
I would really recommend hooking a stereo system into your TV, though. The PS2 has INCREDIBLY stereo sound and you really miss out on a lot if you just have the sound coming out of your TV speakers!! Especially if you play DVDs through your PS2, you want that sound coming out of the stereo system. So in this case you would send the video to your TV, so your TV can show the picture. You then send your audio (sound) to the stereo, so it can play the sound. Most stereo systems have multiple input spots so you can plug in your CD player, your tape player, your record player, etc. So just choose an input spot that isn't taken yet. Here's an image of that connection -
So let's say you don't have a tape player and therefore plug the red cable into "Tape Input R" and plug the white cable into "Tape Input L". To make the sound play, you would now press the "Tape" selection button on your stereo so it played the music coming through the tape channel. Since that's where your PS2 is plugged in, that is the sound that will come out of your speakers.
Jan 29, 2008 | TruTech PVS31170S1W 17 in. LCD Television
Cable has pic and sound dvd ps2 only has sound no pic. says no signal
try hooking a rca yellow video cord to the adjacent plugs 1 from player to tv video in right next to ps2 input. ps2 is for audio only.
Nov 07, 2009 | Samsung LN46A650 46 in. LCD HDTV
I'm trying to hook my PS2 up to my Digital Lifestyle tv. When I hook up the PS2, I can get a black and white image, but I can't get sound or color...
You may be connecting your PS2 with a different cable connection than you used previously.  If this is the case, reconnect the PS2 to the last television that it worked on and change the video connection settings to what your next television is using.  Then power the PS2 down and move it to the next television.  The picture should be fine now.
Jun 06, 2009 | Digital Lifestyle FA1B32Z 32 in. LCD...
Sony T240HD monitor TV
make sure that the plug on ps2 is connected and check the settings on tv and the settings on ps2 browser are correct if possible check ps2 on another tv to be sure of it's settings if the ps2 works the check channel setting on tv make sure it's not in pal setting it should be ntsc and also check the antenna setting make sure it might be set to cable and also check cables of any sharp kinks your problem is with the yellow cable red and white is the sound
Dec 01, 2008 | Samsung T240HD 24 in. LCD TV
No AUX button on TV and lost orignal remote
Try hooking up PS2 as instructed and turn on. Then check all channels to find which one is receiving the signal. I had to do the same thing with an older RCA.
Apr 28, 2008 | Sony PlayStation 2 Slimline Console
PS2 hook-up
I would suggest to feed video from another source such as DVD or VCR to the same input, if the video is visible from other sources on your TV; that means the video cable from your PS2 is defective. If you did not see any video from the DVD or VCR nor the PS2, it means that there maybe a loose connection inside the TV on the video input.
Hope this helps.
Jan 03, 2008 | Sanyo DS31590 31" TV
Ps2 hookup to lcd tv
If your sanyo has a video input (yellow) available, and audio inputs available (white and red) then you just need to connect them. Then you need to select the proper input on the TV set. These may be on the back, side, or front of the TV.
Good Luck, and let me know how it worked out!
Jan 01, 2008 | Sony PlayStation 2 Slimline Console
Hooking up PS2 to Component hookups on 37" LG LCD
make sure the input is turned on in the menu. Sometimes they get locked out.
Dec 30, 2007 | LG 37LP1D 37 in. LCD Television
How to get colors on tv
sound but no picture
Dec 11, 2007 | Koss KS3102 System
Sony PlayStation 2 Slimline Console Logo
315 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
