Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Canister will not release
Can not get the canister to release to dump trash have taken apart and cleaned and put back together now the canister will not release
  • tobyj1 Nov 29, 2008
    Great solution! Vacuum cleaner back to working great.
    Scholar:
  • 55 Answers
I've done that.
There is a stem that runs down the center of the cyclone that releases the bottom. You didn't get that stem back in place. The only thing you can do is pry it open, hope is doesn't break, and put that cyclone back together correctly.
I've never broke one, but I had to pull pretty hard. Thought I was going to.
Good Luck
Posted on Nov 26, 2008
I have a Dyson I took out the screws to clean it before I opened the canister now I can not get it together again
You're a bit unclear on what screws you took apart to 'clean it'. If you took the canister apart, then this Snapguide page
How to Clean Dyson DC07 Canister goes through taking the top section thoroughly apart, and has some notes about things needing to line back up properly, which might help in the event that you're not getting things to snap back together right. I took mine apart solo after picking it up cheap at a flea market, and also recall reassembling the top took a little patience.
Good Luck!
Oct 30, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do I empty the tank instructions do not say
Looks like you have a bagless vacuum. The other kind have a tank. The tank can usually be removed by pressing a lever or switch somewhere on the top area of the tank.
When you get the tank off, it will come apart easily. Try to remove the top of the tank. Then you can dump it out into the trash. Watch how you open and removed the tank so you can put it back together again.
Hopr this helps.
Feb 02, 2015 | Vacuums
How to empty it
1. Push down on carry handle and
pull dirt container away from unit.
2. Once it is pulled back lift it out.
3. Hold dirt container over trash can and push down on bottom
release lever to release debris.
4. Close bottom cover on the dirt
cup until it snaps shut.
While you have the dirt container out you can also clean the Lifetime HEPA filter. It is on the top of the dirt container.
1. Twist lid to the left to remove lid and filter from
container
2. Remove foam filter from dirt container and dump out
any loose dirt. Wash the foam filter.
3. Remove the HEPA filter by Twist filter handle to the left and
pull out of lid. Wash the Heap filter.
4. Once the filters are thoroughly dry (I recommend set out for 24 hours) then installer filters in lid and thread back on top of the dirt canister.
Before replacing the dirt canister you can also clean the exhaust filter install below the dirt canister on the top vacuum cleaner head.
1. Loosen the exhaust grille by pressing the locking tab, and
remove it.
2. Remove and shake out the exhaust filter and wash it.
Note: Scented filter are not washable.
3. Once the filters are thoroughly dry relace it and snap the
exhaust grill into place.
Replace the dirt container
NOTE: Dirt container will not
align on base if filter is not
aligned properly.
May 15, 2014 | VAX Appliances Vacuums
Henry hoover brush not rotating so not picking up
Check the ends of the rollers for a build up of hair/thread, etc between the bar and the ends. remove if found.
Dec 29, 2012 | Numatic Henry Bagged Canister Vacuum
I have taken henrys lid off to look at the motor now he has stopped working
It's possible when you took the lid off one of the wires has come off a switch or the field. It could also mean the motor has gone. Recommend you get it checked out.
Dec 10, 2012 | Numatic Henry Bagged Canister Vacuum
Round filter clogs often
The Flange in question is about one inch tall and and approx 4 inches circular ..... When you pull the canister (container to empty) off and empty the contents in the trash .... some of us tap it to get the excess out or off the sides ..... That Flange is the rubber piece attached to the bottom of the darker gray cylinder inside the canister you are emptying. When you tap the canister or after dumping it numerous times that flange can work itself (slide) up the darker gray cylinder ...... it needs to be slid downward and overlap the bottom when you close the canister from dumping it. You can remove the flange and see the grooves .... replace it back on with it hanging off a little to allow for overlap. That should decrease the amount of excess being trapped in the filter. Hope this helps.
Jul 10, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
667 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
