Question about Philips 20PT6441 20" TV
Re:philips greetings: i was repairing a philips tv and i removed a bad electrolytic capacitor,while i was away my friend plugged the tv on and a resistor was burned,the question is can i still test that color coded coded resitor,will it still give the right resistance?i hope you can give me the right answer.thank you redd
  • 24 Answers
Hi, not advise to on the set, will put load on other parts component faulty. Check surrounding and ensure all components is all mounted before on the set.
rdgs
alan
Posted on Feb 24, 2008
  • 38 Answers
You need to secure a schematic diagram for this matter. schematic diagram can be obtain and can be bought at electronic stores....gud luck!
Posted on Mar 24, 2007
FIRSTLY REPLACE FAULTY CAP .SWITCH SET ON AND THE SET CHECK THE SYMTOM IF ANY CHECK THE COLOR CODE ON RES
Posted on Mar 20, 2007
    President:
  • 1,284 Answers
It might test ok resistance wise but might break down under the load of the television in operation. Then again it depends on how badly it was burned.
Posted on Mar 19, 2007
Repair Sony nsx-40gt1 tv, no picture, 2 red blinking lights where normally green. Is the power supply board bad, t-con bad or main board bad. Who sells repair manual?
Hello Eric,
shopjimmy has the circuit boards and gives live support..
Check out the URL below.
Also consider getting an anti-static wrist band... so you don't destroy good semi-conductors with tiny static sparks.
Further information on that is under "ESD"
(Electro-static Discharge)
TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 14, 2016 | Sony NSX40GT1 40 Inch Internet TV powered...
Power board for 37pf5521d
hello!
You don't need to replace power supply in most cases. If you can to the board itself, it buried deep under metal shield, up side down, remove it from the set by unscrewing 6 machine screws, unplugging few plastic connectors. Be careful, connectors are fragile, gently move those in every direction, while pulling out male part of connectors. You will find at least 1 "bloated" electrolytic capacitor, remove and replace those. It's good have "in circuit" capacitor checker to determine quality of "hot side" of power supply capacitors. If you won't find and replace those, small: 1mf 10mf or 22mf, your set will start up, might even work fine for a while, then will quit for good! I've seen that happen! If you don't have capacitor gizmo, then replace all small electrolytic capacitors on "hot" side of power supply. "hot" is that side, what connects to main power in plug area, contents one large capacitor, I.C. chip diver, power mosfet, etc. worst case scenario: if you can't replace those parts yourself, remove the board and take to local TV repair shop. It won't cost you that much to do so, compare to complete TV repair.
Good luck,
Alex.
Feb 19, 2012 | Philips 37PF5521D 37 in. HD-Ready LCD...
Tv wont turn on. there is a ticking sound coming from the back. whats the problem?
bad power supply...try to check for any bulgy capacitors mostly electrolytic type...also check the transistors for switching...if needed repair I recommend to bring it to a service center...nice day..
Feb 12, 2011 | Philips 42PFL5332D 42 in. LCD Television
Tv will not turn on straight away can take up 30 minutes with on button clicking on/off while waiting for the tv to come on
Depending on the model number of this tv, you may find an electrolytic capacitor on the power supply panel,  2200Uf @ 10volts, usually blue in color, if the top has popped up it's bad.  You need soldering skills and a new capacitor to repair.  Be careful of +/- polarity or the new part will pop again.
Nov 29, 2010 | Samsung Televison & Video
There is a red blinking light on the bottom right side of the set and the TV will not power on.
You have a blown power supply, most likely caused by defective electrolytic capacitors that if are electronically handy can be replaced for a few dollars.
Here is a link to some one who experienced what you are going through and how he got his repaired for less than $30.
http://recycledpapyr.us/2009/03/26/blown-power-supply-on-philips-plasma/
Defective electrolytic capacitors from China are a rampant problem. Cheap Dell, computers fail all the time because of this problem. I repaired my Commercial grade $2500 Samsung 42inch LCD monitor for the very same reason. I was able to open up the case fairly easily and remove the board, replace the defective capacitors with much better grade caps and be on my way, has worked great ever since.
Oct 01, 2009 | Philips 42PF9631D 42 in. Plasma Television
My 50 inch philips plasma tv has a bad smell coming from it. what is it and what can i do
The sypical source of a bad smell is electrolytic capacitors that are failing. Please UNPLUG this unit and have it repaired. There is a slight but definite chance of fire. This is not a major repair effort at this time, but a delay will significantly increase the repair cost. Please have this serviced ASAP.
Thanks,
Dan
Jul 18, 2009 | LG 50PX5D 50 in. Plasma HDTV
Tv will not turn on
Greetings!
Depending on the model number, there are a number of things that could be wrong. Even within a given model number there are a number of possibilities. I have seen everything from rectifiers to horizontal outputs to bad electrolytic capacitors to bad solder connections kill these things. If you are skilled and experienced these are a few things to check. If you do not have repair experience then please stop, put the back on it and get it to a repair facility. I rarely have estimates declined on these because you can not replace it for less than most repairs will cost.
Rob
Jan 14, 2009 | Sanyo DS25390 TV
Bad picturre on toshiba tv
Good Day, pieps57;
Corrective Action: Remove the MVUP13 Hyper Module from the TV chassis, remove the top shield and replace the 10uf, 16v capacitors using Part Number 24619040. It’s recommended that all of the capacitors identified be replaced (Note: These capacitors are low impedance surface mounted aluminum electrolytic capacitors. Care should be taken to avoid damaging the PCB while replacing these capacitors.) CAPS: cx178, cx221, cx230, cx241, cx250, cx261, cx270, cx541, cx670 & c514, c5030.
Good Luck, Big Irish.
Jul 07, 2008 | Toshiba 42H81 42" Rear Projection...
Horiz. lines across top of screen.
I agree with solution #2
I recently had my phillips 27" model 27PT6341/07 repaired after warranty expired due to white lines appearing at the top of the screen. The shop advised that it was a capacitor giving me the problem. So, after getting it back, I examined the repair job and the shop had replaced a capacitor at the back of the main board, next to the rear rca inputs. It is labeled 10uf 100v. I was told that it would fail again soon because it is a manufactures defect. For me it is at location 2465. Here are a couple of photos of the part.
http://farm4.static.flickr.com/3215/2337629026_eaa30cfa18.jpg?v=0
http://farm3.static.flickr.com/2411/2337627420_b45bbf1a74.jpg?v=0
Good luck,
Ed
Nov 13, 2007 | Philips 27PT6441 27" TV
Replacing Circuit Board Capacitor
820pf / 2KV capacitor Philips # 483512257004 Andrews
Or # 13-821U HB Electronics .......T.
Nov 08, 2007 | Philips Smart 25TS54C 25" TV
Philips 20PT6441 20" TV Logo
94 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
