Question about Yamaha RX-V870 Receiver
Yamaha receiver front channels only getting 50% output on rt side
I have a Yamaha R-V701 receiver that is not putting the same volume out of both sides changed wires and speakers and ruled them out. I think it is the output jack in the receiver, is there a way to check for sure, or to repair. the receiver was disconnected during remodeling, it got dusty around the house, I tried to keep it dust free.
thanks for any help
    Problem Solver:
  • 4 Answers
Go to your setup and check the settings in your sound setup!
Posted on Oct 01, 2009
How can I connect Senheiser wireless headphone to Yamaha RX773 without using front headphone jack as this mutes speakers, I have hearing problems, my wife doesn't, I tried both av audio outs in the back...
Your receiver has Zone-2 functionality. For Zone-2, it has both speaker (powered) output and pre-out line outputs. According to Yamaha FAQ, these pre-out outputs are independent on the main volume settings. So if your wireless headphones have their own volume settings, you can change the volume independent on speakers volume.
If you want same volume for speakers and headpohones, use the PRE-OUT FRONT outputs on the back. If you want different volumes (and listen to headphones even with speakers muted), use ZONE-2 OUT outputs on the back.
Oct 02, 2013 | Yamaha RX-V773WA RXV773 7.2-Channel A/V...
I have a AV receiver RX-V440 Yamaha and........
The title of your question reads "I have a AV receiver RX-V440 Yamaha..." yet you say you are using the manual of an RX 1020L. I will try to provide a suitable answer for both receivers.
First, a "MON" connections on an amplifier or switching unit is normally used as a line level OUTPUT from the amplifier or switch. Line level outputs are sent to RCA connectors on other TVs or amplifiers (or switches).
"MON" should not be wired directly to the OUTPUT of anything trying to "playback". It should be connected only to things that can record or allow you to see or hear what the amplifier is outputing.
Now to answer your question:
The RX-V440 is a 6.1 channel Home Theater Receiver. If you stand behind the receiver and look at the left hand side, you will see 12 RCA connectors (2 L/R by 6 high). The top 2 connectors are labeled "CD". The next set of 2 connectors are labeled "IN/(PLAY)". The third set down from the top are labeled "OUT/(REC)".
You can connect the reel-to-reel output to either CD or IN. If the reel-to-reel has a selector switch, set it to "Output" and not "Monitor". If the reel-to-reel has volume controls, set them such that music causes can be heard when you select CD or IN on the RX-V440.
The RX 1020L is also a multi-channel receiver. If you stand behind the receiver and look at the left hand side near the center (top to bottom) of the receiver, you will see RCA connectors labeled "AUDIO 1" through "AUDIO 4".
You can connect the reel-to-reel output to either of these. The primary purpose for "AUDIO 3" and "AUDIO 4" is to allow you to hear component video input AV1 and AV2. If the reel-to-reel has a selector switch, set it to "Output" and not "Monitor". If the reel-to-reel has volume controls, set them such that music causes can be heard when you select one of the "AUDIO 1", "AUDIO 2" or whatever on the RX 1020L receiver.
Nov 21, 2017 | Audio Players & Recorders
YAMAHA RXV350 RIGHT CHANNEL NOT WORKING
Adding on again: I have interchanged speakers, if i connect any speaker on the right front channel it will not work. When I do a automated speaker test only right front channel does work.
Jan 26, 2012 | Yamaha RXV-350 Receiver
Yamaha v-r701 reciever It has sound but it is very faint. You have to turn the volume way up for it to play at a wisper.
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead
Mar 27, 2011 | Yamaha R-V701 Receiver
I have a yamaha r-v701 the main 120 volt fuse was blown when replaced it keeps blowing what would be causing the short
If you are blowing the mains fuse, you likely have an issue in the power supply. This can be a bad rectifier or filter capacitor; or, less likely, some other component. The fact that you're asking the question suggests you should not try to fix this yourself.
Dec 08, 2010 | Yamaha R-V701 Receiver
I'm using an old Yamaha stereo receiver off my Panasonic Plasma to run a pair of E660's, can I just use the Speaker ''B'' on the receiver to run the center channel? (E660CEN)
I do not believe that you can. If you use the "b" channel for the center channel, the "a" channel will not process the left and right channels simultaneously. It is either or, not both at the same time. It may be possible to run your E660's directly off the TV output adjusting the volume from the TV, while running the center channel through the Yamaha receiver and adjusting the volume for the center channel from the receiver.I hope this helps.
Oct 26, 2009 | Audio Players & Recorders
Fuse blows as soon as you turn it on. I disconnected all speakers and equipment and still have the same problem.
The power suply most likely has a problem. If it was the outputs, the unit would not come out of protect mode. Check the rectifier diodes for a short.
Dan
Aug 19, 2009 | Yamaha R-V701 Receiver
Yamaha rx-v661 unsolved speaker wiring error
1. Try running the auto setup without the sub. ( is it a powered sub {the sub has its own amp on the back} or is a NON powered sub that is driven off the speaker jacks of the Yamaha receiver. )
If the sub is powered, and connected to the Amp via the RCA cable from the " sub out " jack, chances are you either have a defective sub or a gound loop.
Good luck...Rob
Dec 03, 2007 | Yamaha R-V701 Receiver
93 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
