Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Bissell Pump Weak?
Seems like you're the expert here on these, so I figured I'd ask directly. I went to use my Bissell today and the flow indicator wasn't working, so I immediately figured "heater" (as I've had to clean it up before). Well I took the heater completely apart and cleaned up the insides, but it still didn't solve the issue. Obviously the belt is good, and as best as I can tell, the water and shampoo tanks are fine, with all rubber gaskets where they should be. All the lines are clean and routed properly, and I can even get the unit to **** water out of a glass from the water tank hose, but as soon as I put the cover back on (I've done this 20 times today) and drop the tanks in, I get nothing. As such, the ONLY two things I can even think of at this point is the shampoo selector piston is causing issues (even though it seems to be installed properly) or the pump is working but weak, and when vacuum is placed on the tank itself there's just not enough vacuum from the pump to still pull water. It will spray for a moment or two if I shut the unit off and allow the pump to prime (although there are obvious air bubbles in the line), and will even **** water poured into the water tank adapter fitting... but nothing from either of the tanks themselves. Bad pump?
  • Bissell Master
  • 1,545 Answers
Often times I see the pumps clogged with soap when acting like you described. This can cause a pump to be weak. Pressure builds up whe you stop squirting water but tapers off quickly. A few times I've been able to get water flowing good but most times have to replace the pump.
Posted on Mar 15, 2017
reddevil6
  • 1673 Answers
SOURCE: bissell shampoo
I am assuming this had a flat and a cogged belt, if not then provide the model number.
First take off the cover on the left side oif the top cover, then turn it over, remove the screw holding the red lock and pull the cap and brush roll out, remove the cap, remove the cogged belt, then you can put the new pump belt thru that slot, put over the pulley on the pump and then stretch it to go over the motor shaft. Then put back together.
Posted on Feb 13, 2008
reddevil6
  • 1673 Answers
SOURCE: Bissell 1698 Powersteamer no spray
A simple thing to check is make sure the round seal is on the bottom of the tank, it needs to be on the tank not sitting loose in then hole that the tank valve goes into. Could be a problem with the flow indictor cap leaking air. Is the top and the base tight together in the back, sometimes the plastic breaks loose and the top will rise enough that it raises the tank so water won't flow. Your pump may be bad.
Posted on Mar 30, 2008
  • 29 Answers
SOURCE: Bissell steam cleaner will not spray shampoo
My Bissell stops releasing shampoo when the handle is lacked upright, when there is no water in the tank (the most common cause of this issue), or when water is not flowing through the machine because the sprayers are clogged.
Make sure the shampoo container grommet is releasing properly when you press the trigger. To check this, remove the shampoo tank from the Bissell, stand over a sink, and use a finger to push up inside the grommet on the shampoo container, the part of it that mates with the rest of the Bissell. Shampoo should dribble out when you do this. If it won't, the grommet may be clogged.
Posted on May 29, 2009
  • 17 Answers
SOURCE: Nothing spraying out of bissell powersteamer
Here is how to fix it
Posted on Feb 08, 2010
heatman101
  • 43501 Answers
SOURCE: Bissell proheat 1698 reassembly, smart mix piston, new pump?
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
erqtr
Posted on Sep 30, 2010
Is there a filter to bissell pro heat pet ? PUMP
Check your User's Guide on page 13 for Maintenance and Care. There is a flow filter located under the flow indicator that should be cleaned after each use. To get to it you turn the Flow indicator cap counter-clock wise, lift the rotor out and the then the filter. Ensure you replace the filter with the stem in the up position. Reassemble in reverse.
Nov 21, 2015 | Bissell Vacuums
Water will not dispense
I'd clean the small filters. One under the Flow Indicator: Unscrew the Flow Indicator cap to remove it. Lift out the rotor and the filter is directly under it. Lift the filter out and clean. Replace in the reverse order. If that didn't work then call Consumer Care 1-800-237-7691. Hope that Helped.
Sep 26, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
After replacing pump water comes out in short squirts. It seems to come out of pump in steady stream but short squirts at nozzles including hand held.
Check your filters. Flow Indicator Filter: Turn Flow Indicator Cap counter-clockwise to remove, lift rotor and filter out. Clean filter and replace in reverse order.
Sep 03, 2015 | Bissell 8920 ProHeat 2XTM Upright Vacuum
My bissell proheat 2x carpet shampooer will not put out any water
Have you cleaned the filters? Check your User's Guide for directions. One is located under the Water Tank Cap (small screen) the other is under the Flow Indicator. Bissell Consumer Care 1-800-237-7691 Hope that helps.
Jun 23, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
How to clain filter on bissell 1697
The clear cap on the flow indicator unscrews and the spinner and filter can be removed to clean.
Jul 11, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell Proheat 1699-5 won't spray, belt ok
Hi There,
It sounds like to me that this may be your pump. The newer ProHeat 2X models actually have a Silinoid problem right now which is more common then the pump going bad, but if you have the original ProHeat series, then it sounds lik you have a bad pump.
Here's a link to a very, very helpful repair guide directly from Bissell that will explain to you step by step how to trouble shoot, and replace the pump if needed. I would be lost on the ProHeat series without this handy repair guide.
I'm pretty knowledgable now on these machines, if you need some help or some clarification on how to repair this, please feel free to reply to this repair by using the Clarification request form. If you found this helpful, please be so kind and rate my repair, and give feedback.
Here's the link:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/bissell-proheat-repair-guide.pdf
Thanks again,
Chris Jones
GoVacuum.com
Apr 19, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Water is not dispensing to clean carpet. Water
the problem is the heater is cloged you can drill it out to clean it
Dec 10, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell Power Steamer Pro
The belt has broken and needs replaced. bissell uses a belt driven pump. ther ar two belts, one for the brush, and one for the pump. all can be replaced through the belt access on the left hand side of the machine.
Nov 05, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bex Bissell Pro Heat 7920-E
Remove the cap for the flow indicator, then there 6 screws to remove to take off the top, before removing the top, turn the smart mix valve to about the half way point so the piston won't fall off. When you are ready to re-install the top cover, just before pushing it all of the way down, turn the smart mix valve to the water only setting, then push it into place, re-install the screws and the flow indicator parts.
May 27, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
336 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
