Question about Weather King 12AJA4801AH Air Conditioner
Heat Pump Stops Working only in the Early Morning
I have a weather king A/C heat pump. I purchased the unit (regrettably) and had it installed about a year ago. I've had the compressor replaced once after about six months. Unit worked fairly well after replacing the compressor. The supplier gave me a Copeland scroll-type comp which is has good reputation. Everything seemed to work fine afterward until this winter. Unit will run well during the day while the ambient temp is 50-65 degrees. However during the night when the temp drops to 20's and 30's the heat pump is louder than normal, but seems to be heating well. At around 5 - 6 a.m. (when it seems to be the coldest outside) the unit will stop blowing warm air and begin blowing cool air( not cold, just cool). The suction line at the air handler is cool (not cold) to the touch, but the compressor is still running. I will cut the unit off for about an hour and the heat pump begins working again until the next morning. I was thinking that it probably is a reversing valve or a RV coil problem. Not real sure though. I would certainly appreciate any input you might could provide.
  • neil03 Dec 02, 2008
    thanks, idaho HVAC, for your suggestion. I already have emergency heat strips. I think I have solved the problem. The unit was a little over charged. That seemed to help with the outside unit being a little loud when it was really cold outside. When its colder, the unit has more liquid refrigerant to move, so it tends to be louder, especially if its over charged. It makes the compressor work harder( so I'm told). That also seemed to help with the cycles being too long. I havent checked yet, but someone said that with that unit there is a timer that will override the heat pump during a defrost mode if it doesnt cut off after defrosted. They suggested making sure the timer is at 60 min.anyway thank you very much for your help.
  • 85 Answers
I recommend getting electric back up heat to fix your problem. Like the other gentleman said, defrost is having to kick on too much. It's doing the best it can givin the conditions outside. If you don't have enough power supply for electric back up heat, then a gas furnace or propane furnace will work also, depending on your needs. Heat Pumps are a like a full time fan, they are designed to heat your home at a steady rate unlike forced gas units that turn on extremely high temps and then shut off... Ensure your charge is correct, givin your tempatures the unit sounds to be working correctly, however a second opinion is always a good piece of mind before you spend money on emergency heat.. Hope that helps..
Posted on Dec 02, 2008
  • Armando Bernal Dec 02, 2008
    Pull off door and look for the timer pin, you should have three or four different options... Glad your problems solved.
  • 96 Answers
When the unit does what you say does the fan motor outside stop also , if it does that means it is in defrost mode and should kick back over to normal after the system heats up the coil enough
Posted on Nov 25, 2008
Where is the condenser at on weather king heat pump & what does it look like
Dear Sir:
Please go to the next web page:
www.fitness.manualsonline. com give you model and download for free, in that way you will ubicate the condenser unit , that you are asking.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Apr 04, 2012 | Heating & Cooling
Heat pump stops working in cold weather
Sounds like there is a problem with your unit. The cooling tower doesn't have anything to do with the compressor other that the delivery of water to your heat pump. The compressor is probably shutting off on a low pressure because the water is cooler than in summer. I think the heat pump you have is low on charge or has a defunct TXV.
Jan 11, 2010 | Weather King 12AJA4801AH Air Conditioner
Weather King 10PJB18A01 heat pump. Compressor is working, however reversing valve is stuck in cooling mode. Need HEAT! Can this be fixed without replacing entire compressor?
yes it can be fixed with a reversing valve replacement or you can check if the solnoid on the reversing valve when in heat mode is energized if not then replace
Jan 06, 2010 | Weather King 10PJA4301AH Air Conditioner
Can I install emergency heat strips by myself? Our heat pump does not have them, so it's 56 degrees in my house right now. Help!
Sounds like your heat pump may be undersized or is not defrosting frequently enough. But in answer to your question, they are not that difficult but if it was installed without strips, your power supply may not be enough. You will also have trouble purchasing them unless you can buy from a HVAC supplier. I would look into the heat pump function and the power supply. You may need to make some modifications before adding strips.
Jan 02, 2010 | Weather King 10AJA2501AH Air Conditioner
Weather King 13AJA36A01 AC freezing up at night
check the inside coil is dirtyor may be low on freon
May 14, 2009 | Weather King 12AJA4801AH Air Conditioner
Heating
your condensing unit shoould run when the heat is on. Noe what is the temperature of the discharge air at the grilles. If it's really cole then the reversing valve may not be working correctly and you may be ablre to go to emergency heat only until you get a technician out to see why.
Dec 22, 2008 | Weather King 12AJA6001AH Air Conditioner
Weather King kicking on an off
An easy way to tell is look at your t-stat if it has emer heat, heat , cool and off on it it is a heat pump system and if you only have heat ,cool and off on the switch it is electric heat
Dec 03, 2008 | Weather King Heating & Cooling
I'm trying to figure out if our Weather King system has a heat pump... how do I tell?
Your indoor furnace is weather king? If you have a a/c unit outside, it could be a heat pump, but you have to provide the model number on it.. If you do have a unit outside, when you call for heat does the outdoor unit kick on?
Dec 03, 2008 | Heating & Cooling
Electric heat strip installation and wiring
Need to make sure your wire size to the inside unit is large enough to handle the amperage, that you have a two stage heat thermostat.
Jan 02, 2008 | Weather King 10AJA2501AH Air Conditioner
Weather King 12AJA4801AH Air Conditioner Logo
715 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
