Question about Sony Bravia KDL-40S4100 40 in. LCD TV
Comcast cable remote work on sony tv
I was needing to get the code for the sony tv so that i only have to use the comcast cable remote for power, volume and such?
  • Anonymous Jan 31, 2009
    I need the code for the Sony Bravia KDL-40S4100 that works with the comcast on demand remote
    Problem Solver:
  • 7 Answers
0000 I have same tv...
Posted on Jul 14, 2009
How to get my Sony HT-CT60 Sound Bar Home Theater programmed to my GCI Cable remote?
This worked for me, but I have a Comcast Motorola DVD-R:
These are the codes for your SONY SA-CT60 Audio Device. Follow the instructions below to program your remote.
silver_with_red_ok_button-lg.gif Most likely code: 30158
Others to try: 31758, 31759
To program your Comcast remote:
  1. Turn on the TV or other device that you would like to program.
  2. Press the TV button on your remote control.
    NOTE: If you would like to program your remote control to work with a DVD Player, VCR or Audio device press the AUX button.
  3. Press and hold Setup until the red light blinks twice, then release Setup.
  4. Enter the first code for your device listed above. If you perform this procedure correctly, the red light will blink twice.
    NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 4 with a valid code.
  5. Aim the remote control at your device and press Power once (press the Play key for devices that don't have a POWER button). If the TV turns off, make sure that the VOL+/- and Mute buttons also work. If so, you're all set!
  6. If not, repeat these steps using the next manufacturer's code (you may need to try several codes to find the one that works).
Nov 24, 2012 | Sony Audio Players & Recorders
What are the remote codes for Sony RM-EZ4 / Haier TV, Comcast Xfinity cable box?
Follow these steps to program the remote control.
  1. Turn on the component to be programmed.
  2. Press the SET button.
  3. On the remote control, press the appropriate component button.
  4. Using the number pad, enter the component's manufacturer code.
  5. NOTE: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
  6. Press the ENT button.
  7. Point the remote control at the component.
  8. Press the POWER button to verify operation.
Comcast offers several remote controls. The type of remote you get depends on the device you're using. Some Comcast remote controls are multi-device or universal remotes, while others only control the set top box and TV.
May 06, 2012 | Sony RM-EZ4 Universal Remote Control
I need to program my cable box
The real problem with the Comcast remote is that there is no other brand, it's not like a Sony remote that's relabeled or anything. Fortunately, Google helps again, and it turns out Comcast has a page online about programming the Comcast remote control.
comcast_remote.jpgComcast 3-in-1 remote control To program the remote to work with your Sony TV, you need to take the following steps:
  1. Find the code or codes for your TV from Comcast's list [PDF]
  2. Turn your TV on
  3. On the remote, press and release the TV key on the very top of the remote.
  4. Press and hold the Setup key, until the "TV" key flashes twice, then release the "Setup" key.
  5. Using the number pad, enter in the first 4-digit code found next to your television brand on the chart. If you do this correctly the "TV" key will flash twice. Now it's programmed!
  6. Now point the remote at your TV and press the Power key. If the TV turns off, you're golden. If not, try again with the next code on the list.
Jun 01, 2010 | Symphonic SC3919 Combo
Need remote codes for emerson lc320em9 so can program cable remot
If you only wish to power the TV off/on with the remote, there is an alternative. Plug the TV into the outlet on the back of the Comcast box. In the Setup Menu for the Comcast box there is an option to make the outlet switched or unswitched. Select SWITCHED then the TV will turn on/off with the Comcast box. The
LC320em9 will maintain the previously selected input.
Jan 16, 2009 | Televison & Video
Remote Codes for new Sony Bravia
0000 worked for my XBR4 using the remote called: Comcast Custom DVR 3 Device found here:http://www.comcast.com/corporate/customers/customer_support/remotes.html
Nov 17, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Code for Comcast remote for Sony DAVHDX275
It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helps you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.
What you need to do is steal some codes from a like product and then hardcode in the changes you need to the comcast remote. Set your AUX to 21232 (a sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Power = 32719
Good luck. Let me know if it works.
Sep 27, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
I need device codes for sony DAV HD279w home theater/dvd player controlled by comcast digital cable remote control (none of the codes work in the manual and I tried searching for code and still no luck)...
2. Type 994
4. Type 32975
Vol+ = 32975
Vol- = 31951
Power = 32719
Jul 27, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
I plugged this code in and it worked:
10000
Good Luck
May 12, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
DTV remote code
KZXten,
Don't know if this will help but I have Comcast as my cable TV provider and am using a Motorola DCT-6200 STB and the remote Comcast provides with the STB. To get my Panasonic TV/VCR combo (PVQ-2510A) to work with the Comcast remote I had to do the following:
1) Do the remote code search in AUX mode (or VCR or DVD mode if your remote has that button instead) using the instructions for searching ing remote codes. I had to toggle back and forth between AUX and POWER on the remote until the TV turned off. I saved that code on the remote, but it only controlled the power on the TV, not the volume control.
2) Next I did the remote code search using the TV button on the remote and toggled between the TV button and the volume control until the volume +/- bar appeared on the screen. I saved that code too.
I use the AUX button to turn the TV on and off. Once the TV is on the volume control on the remote operates the TV volume normally. I still need to toggle between CABLE and AUX depending on which device I'm controlling, the cable Set Top Box (STB) or the TV. You may have to experiment some to get it to work correctly.
Here's a link to the remotes Comcast is providing in my area.
Dec 23, 2007 | Panasonic PVQ-2510 25 in. Combo
Sony Bravia KDL-40S4100 40 in. LCD TV Logo
288 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
