Question about AudioSource Amp Two 2-Channel Amplifier
? connecting AudioSouce amp two to my receiver
How do I connect them so I get cd, radio to the amp. From what on the receiver to where on the AS amp two?
If you're using the receiver as a preamp, you'll need a low level output on the receiver which tracks with the volume control on the receiver. Some receivers have "preamp out" jacks which are tracked with the volume control on your receiver. This is what you're supposed to use. However, if you don't have this feature, you can use the headphone jack on your receiver. This is what I do with my amp and it works great!
Posted on Sep 24, 2009
What does "amp error" mean?
If your sub is connected to a separate amplifier, the internal amplifiers of the receiver would be at fault.
Aug 06, 2016 | Pioneer DEH150MP CD/MP3 Car Stereo Radio...
Cd player dosen't play with amp
hmmm...what cd player are you using?..
May 03, 2008 | Kenwood KDC-MP828 CD Player
Radio is turned on but no sound, mute is off
The radio has an amplifier? and you are sure there are speakers connected?
Jul 09, 2014 | Alpine CDA-7894 CD Player
No sound from the cd and extended media but have sound from radio
If you have an amplifier connected to the radio, make sure the amp remote wire is connected to the blue/white wire and not the blue wire of the radio. The blue wire is for power antenna and is energized only when tuner is playing, not when cd or ext media is played, and therefore will shut your amp off when playing those sources.
Jan 05, 2014 | Kenwood KDC-MP628 CD Player
My cd player will not work in 2005 my chrysler 300 the radio works but the cd player wont work whats wrong
Your chrysler 300 has a factory amplifier built in to the system. Seems you have connected the radios antenna turn on wire (usually solid blue) to the factory amp turn on wire. You must disconect the radios antenna turn on wire and connect the blue wire with a white stripe to the factory amp turn on wire. The problem with the blue antenna turn on wire is that when you are switching from radio to cd the unit is shutting off power on that wire(because it thinks its trying to lower a power antenna) Once the correct blue/white wire is connected the factory amp will stay on wether its am/fm or cd. Hope this helped
Jun 10, 2009 | Car Audio & Video
My cd changer, radio and amp are inter connected.the owners manuel say that if all are not hooked up system will not work. i install an after market radio but cant get the factory amp to come on
Hello moemoneymood,
Since you did not specify the make and model of your aftermarket radio, I cannot pinpoint specific connection problems. Most aftermarket receivers have a "remote turn-on" lead, probably blue, but sometimes blue/white, usually terminated with a spade lug. In addition to power and ground, the amp requires this lead to be connected in order to properly operate.
Start by checking the wiring from the old receiver wiring harness and see which wires and what colors went to the stock amp. Then connect the corresponding wires from your new receiver to the amp. Some OEM receiver/amp systems had power and ground taken from the same harness, so you may need to run those separately.
Apr 11, 2009 | Car Audio & Video
Amp connection
The only amp wires that connect to the Head Unit are:
Amplifier remote turn on wire to Blue/white at radio
and RCA audio cords to SUB or REAR output RCA jacks.
Aug 04, 2008 | Pioneer 50W x 4 MOSFET Apple iPod...
Radio sound but NO cd or ipod sound
Radio is screwed.
But try these these steps:
Clean the eye of the head for reading CD. Must open up the radio.
IPod: check for good connections from Ipod to PCB.
Feb 23, 2008 | Alpine CDA-9856 CD Player
Amp turns off when switch from radio to cd function
That because you connected the wrong remote wire to the amps.The BLUE (only) wire is for the pwr anntena, that is the one is connected to your amps right now.
You just need to switch the blue wires,you have to connet the blue w/white strip to the amps.
Dec 06, 2007 | Alpine CDM-7854
Sony cdx mp70
It may be that the remote lead on the amp has been connected to the auto antenna lead on the radio instead of the amp remote lead and because the auto antenna goes down when the cd is inserted it is turning off you amplifier, check the connections behind the radio or if there is a light on the amp check if the light goes out when you insert a cd
Oct 05, 2007 | Sony CDX-MP70 CD Player
AudioSource Amp Two 2-Channel Amplifier Logo
122 people viewed this question
Top AudioSource Audio Players & Recorders Experts
Josh Whitehead
Josh Whitehead
 Grubhead
Grubhead
alberto55
Level 1 Expert
Are you an AudioSource Audio Player and Recorder Expert? Answer questions, earn points and help others
