Computer freezes, unable to move mouse. - Computers & Internet
  • 1 more comment
  • beaven Nov 25, 2008
    computer is usually very slow to get onto internet, we may have to try several times because the mouse does not respond and it stops whilst trying to do this. The mouse does not move at all. This also happens when we are in other programs as well, for example wordpad. To turn computer off and try again, we try the ctrl alt delete buttons and this usually wont work, so we just turn the computer of using the on/of button. It is very frustrating.
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    need more info please
  • 4,806 Answers
This sounds like a faulty mouse, to test this plug another mouse into the pc and see if you get the same results
regards
Posted on Nov 25, 2008
  • 94 Answers
Unplug your computer and switch it again and press F8 continuoslly and the safe mode will pop-up and select last known good configeration and press enter.computer freezes, unable to move - e9cb516.gif
Posted on Nov 24, 2008
  • Joel Cruz
    Joel Cruz Nov 25, 2008
    it is time to reformat your computer to install fresh copy of windows
Nextech mouse through usb continues to install successfully, then freezes while trying to move about my laptop! No, it is not that the Lptp is working in the background, leaving the mouse to freeze th
Step 1:
For a standard trackball mouse, unplug the mouse, turn it over and then twist the retaining ring counter-clockwise to remove it. Remove the trackball inside the mouse. Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in rubbing alcohol. Replace the trackball, then secure it with the retaining ring. Clean the outside of the mouse with rubbing alcohol and a cotton ball. For an optical or wireless mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth. Solve Hardware Problems Make sure the mouse is connected properly. The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction. Check for any bent or broken pins or damage, then carefully plug it in, making sure the connection is secure. Reboot the computer. Connect the mouse to another computer, then reboot the PC. If the mouse works after testing it on another computer, the problem is most likely with your PC or operating system. Also, try a different mouse on your computer. If there is no PC freeze, your mouse is probably malfunctioning. Switch to a different USB port. Sometimes mouse freeze will occur if the mouse is connected to a USB hub. Connect the mouse directly to one of the USB ports on your PC. Try different ports until you find one that works. Replace the batteries. If you have a wireless mouse, replace the batteries with fresh ones. Also, try using a different kind of mouse pad. Sometimes surface imperfections can interfere with the operation of a wireless or optical mouse. Install more RAM or memory. If your PC doesn't have enough memory, PC mouse freeze may occur when you are running resource intensive programs. Installing more RAM will help your PC run more efficiently. Solve Software Problems Check for device conflicts. When you install another device on your computer, it can sometimes conflict with a PC mouse. Remove any new hardware and drivers you may have installed, then reboot the computer. Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System." Select the "Device Manager" tab, then scroll to and select your mouse. Uninstall any drivers that are listed. Unplug the mouse and reboot the PC. Plug the mouse back in, reboot the system, then allow Windows to reinstall the drivers if prompted. Remove viruses. PC mouse freeze and other serious problems can be caused by viruses lurking on your system.Set the program to run a complete scan every 24 hours. Also make sure the virus definitions are updated regularly. Turn off video acceleration. Sometimes video acceleration can cause PC mouse freeze. Go to "Control Panel," then click "Display," and then "Change Display Settings." Click the "Advanced Settings" button, then the "performance" tab. Set the acceleration slider to "None," then reboot. Repeat the process moving the slider up one notch until you have the maximum amount of acceleration with no mouse freeze
Feb 18, 2013 | Computers & Internet
Cursor freezes when usb ports are in use
usb or ps2 mouse ?
make sure the mouse lead is securely seated
make sure the batteries are inserted correctly and have charge if applicable
make sure the usb device is properly inserted
clean dust from motherboard
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps
Jun 20, 2012 | Computers & Internet
Intel pentium 4 computer ' smetimes when I move mouse page moves
well pentium 4 is one of the best processor and as you say that it is of ten years old it seems it had worked for more than what it was expected of so there no loss if you go to buy a new PC.
good luck.
Jan 05, 2010 | Intel inside Pentium 4 P4 System Case...
Mouse Is Recongnized but wont Move
On the bottom of the mouse is a little tiny button that say: connect or reconnect. Place the mouse close to the transmitter dongle (the do hicky comes out of a USB) and look for that button on the transmitter and the mouse to reconnect the signal.
(batteries are good ?)
May 14, 2009 | Logitech 9313960403 Mouse
Cursor freezes up at sign on screen
have you tried using a new mouse if your still having the issue there is only to other reasons this issue is happening either the your ps2 ports are going bad on *********** board and its ready to go or your operating system has been corrupted and you need a fresh installation
Mar 13, 2009 | Gateway Computers & Internet
Mouse freezes when i move it on desktop or a window.
hi, ok go into control panel,printers and other hardware-mouse -slow the pointer speed a notch at a time. this should help. good luck,glen
Jan 04, 2009 | Microsoft Wireless Optical Mouse
Computer recieved the blue screen of death but before....
turn it on with a/c and remove battery if it starts normal then the problem is from battery (TRY IT I HAD THE SAME PROBLEM)
REPLY THANKS
Jul 17, 2008 | Sony VAIO PCG-K35 Notebook
PM2F 100005615 Mouse
When you start up, have to mouse on the one that freezes and then switch off that one. (turn on the one that freezes first and have the mouse set it. then once it is on boot the other one and then switch mouse.
Nov 26, 2007 | Computers & Internet
Mouse freezes
I had the same problem. The following solution from 3M support fixed it. We Normally see this problem on laptop computers running Windows XP. There is a power management setting in the Device Manager, which controls the USB Root Hub. Often this setting is selected to "allow the computer to turn off this device to save power". When control of the mouse is needed again, the computer is unable to turn the device back on. To remove this power management feature follow the instructions below. 1. Right click on the "My Computer" Icon on your Windows Desktop 2. Select "Properties" from the Menu 3. Click on the "Hardware" tab in the system properties window 4. Click on the "Device Manager" button 5. Click on the (+) plus sign next to "Universal Serial Bus Controller" in the Device Manager 6. Locate the "USB Root Hub" (Note: there may be more than one, and you will need to change all of them), double-click on the "USB Root Hub" to access the properties windows for that device. 7. Click on the "Power Management" tab 8. Remove the checkmark from the box containing the following option "Allow the computer to turn off this device to save power" 9. Click "ok" 10. Close the Device Manager and all other open Windows Test the Mouse to be sure that the new settings are working. You should now be able to leave the mouse unused without it being turned off by the operation system.
Aug 08, 2006 | 3M LX400 Mouse
Computers & Internet Logo
42 people viewed this question
Alun Cox
David Payne
David Payne
