Question about Poulan Pro Chain Saw 46cc 20"
46cc cranks but wont keep running if trigger is released
After cranking you must keep trigger fully engaged or saw will shut off. Has a hard time reving up to top speed at first.
    Problem Solver:
  • 5 Answers
The small ports and passages within the carburator is blocked,the carb must be disassembled and cleaned and possibly replaced ..
Posted on Nov 24, 2008
Starting a poulan 18 inch widthing chainsaw
Start by filling the fuel tank with a fresh mix of 50-1, fill the chain oil tank with non fling chain oil, sit the saw on the ground with the bar away from any obstructions, engage the chainbrake, switch the ignition on, press the fuel bulb as many times as it takes to 3/4 fill the bulb, pull the choke out, this should also engage the fast idle, crank the engine until it fires once, it will not run on choke, it is importent at this point you must push the choke back in, now crank the engine until it runs, flick the trigger to allow the saw to idle.
Sep 28, 2013 | Poulan Garden
Won't idle and when trigger is fully engaged it bogs out?
This could be several things..fuel filter in tank clogged, hole in fuel line, clogged carb., hole in carb. diaphram or leaking crank shaft seal under flywheel or chain sprocket,,,engine block acts as fuel pump..hope this helps
Jul 25, 2012 | Craftsman 38cc 16 In. Gas Chain Saw
Have new 450 and is very difficult to start. Lost or didn't get book. How do I start it and re-start it while still warm??
Start procedure is, push the primer as many times as it takes to 3/4 fill the bulb ( you cannot over prime it ) pull the blue choke lever fully out,place the saw on the ground with your right boot through the back handle, crank the engine until it fires once, do not continue to crank the engine with the choke out ( they will not run on choke, only fire ) push the choke fully home, crank the engine until it starts, blip the throttle trigger to bring the saw to idle, warm engine, pull the choke fully out and push in again without cranking engine, this will engage the part throttle, crank the engine until it starts, blip the throttle to bring the engine to idle.
May 18, 2011 | Husqvarna 450 e-series 18" Chain Saw
I have a Husky 435 model that is less than 2 years old and as cut only about a cord and a half of lumber . The saw runs fine when it is running the problem is getting it started in the first place . I...
It should start easily, start with fresh fuel/oil, pump the primer as many times as it takes to 3/4 fill the bulb, pull the choke fully out, crank the engine until it fires once, push the choke fully in and crank again until it fires up, after re fueling a warm engine, pump the primer again until it 3/4 fills the bulb,before cranking the engine pull the choke fully out and in again( this will engage the part throttle ) then crank the engine until it fires up.
May 15, 2011 | Garden
2nd use of chainsaw pp3516avx, it won't start, choke lever will not stay extended. I followed the instructions to start and nothing works
The choke system is connected to the half throttle position, if you lift the throttle trigger the choke pull will automatically return, whilst trying to start do not lift the throttle trigger, the starting procedure is, pump the primer bulb as many times as it takes to 3/4 fill the bulb, pull the choke pull fully out, this will switch the saw on and engage the half throttle, crank the engine until it fires once, do not continue to pull,it will actually not run on full choke, if you do continue to crank with the choke fully out, you will very quickly flood the engine, now push the choke fully in, now crank the engine until it fires up, lift the throttle trigger once, this will dissengage the half throttle, and it should now come down to idle.
Mar 19, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Saw floods out at initail start. Saw turns off after releasing ths gas trigger.
Are you following the correct start procedure? make sure the air filter is clean, switch the ignition on, pull out the choke fully, if fitted, engage the half throttle lock, crank engine un til it fires once, push the choke fully in, do not continue to crank the engine with the choke out after the first fire, crank the engine again until it fires up and runs, if you are following this procedure and still have problems, then the rubber tipped needle in the carb is leaking, if you have a bulb pressure tester connect it to the fuel inlet on the carb, pressure up to 2 psi, the needle should be steady and no leak, if you do not have a tester, you will have to remove the carb and replace the needle as a matter of course, let us know if you need help with this.
Feb 26, 2011 | Echo Garden
Can anyone help with fuel mix and starting instructions for McCulloch 2214av chainsaw please
Ok, always use good quaility teo stroke oil, from a manufacturer who actually produces a chainsaw, ie Husqvarna/Stihl/Jonsered etc, all of these oils should be run at 50-1, avoid oil makes you have never heard of.
Starting instructions are as follows, switch the red ignition switch too on ( up ) depress the primmer bulb as many times as it takes to 3/4 fill the bulb ( you cannot flood the engine if you over prime, it is better to over prime ) pull the blue choke fully out, crank the engine until it fires once ( it will only fire once, do not continue to crank the engine after it first fires with the choke still out ) now push the choke fully back in, crank the engine until it fires up and runs on fast idle,now blip the throttle trigger to diss engage the fast idle position, the saw should now drop down to idle.
Regards
Jan 31, 2011 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
I have difficulty starting my Gardenline 49.3cc chainsaw. Please let me know what the correct starting proceedure is.
Genral starting procedure on a chain saw is as follows, put fresh fuel into the fuel tank, top up the chain oil tank,switch the ignition on, if the saw has a half throttle position on the trigger lock this, if the saw has a primer depress this as many times as it takes to 3/4 fill the bulb, pull the choke fully out, if it has a deco valve push this in, now place the saw on the ground with the chain brake on and crank the engine ( always have the saw body between you and the cutter bar,NO left hand starting, NO drop starting ) the engine will only fire once on full choke, do not continue to crank engine after the first fire or you will flood the engine, push the choke back in, crank the engine until it fires up and runs,release the chain brake and blip the throttle to release the half throttle device.
Jan 22, 2011 | Garden
My 1750 psi campbell hausfeld pressure washer will operate at first until I release the trigger on the wand. Then it won't restart. If I wait for a while it will run again. Sounds like the pressure switch.
Common with that washer...it has a wabble pump. Release the trigger, if by pass does not engage, stalls engine. You can however keep using it, all you have to do is keep trigger pressed, and when you are cranking engine, depress trigger with the free hand. Can be repaired, but the fix probably will cost more than a new pump.
Oct 18, 2009 | Garden
Can,t hardley pull starter cord. I've removed muffler and carb. It will pull fine if the spark plug is removed (w/or with carb and or muffler . this is a poulan pro 18"
What i have to occasionally do for a chain saw after it sits all winter is to put something like WD40 in the spark plug hole and crank it over several times. What happens to me is that the piston gets gunked up from the gas that ran down into it during the winter and it won't crank over hardly at all. This is probably your problem. I have also found that if i store my saws with the tank down, the gas cant get into the carb and do this. (Although it's better to drain tank).
If this has been a running saw instead of a stored one, you probably need a rebuild kit if the piston is scored.
Apr 14, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chain Saw 46cc 20" Logo
118 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
