Question about Canon Office Equipment & Supplies
Scanning 35mm slides and saving to computer - Canon Office Equipment & Supplies
    President:
  • Canon Master
  • 1,314 Answers
In order to scan 35mm slides to your computer, you need a scanner that has the capability of doing this. These scanners will either come with a 35mm adapter that will allow you to scan the slides, or there are scanners that will scan only 35mm slides. A good recommendation is either this or this.
Thanks and please take a moment to rate as fixya.
Posted on Nov 24, 2008
Scanning 110 Instamatic slides on Epson Perfection V700 photo scanner
Hi Stanley - does this youtube video help? http://www.youtube.com/watch?v=EcALdbbCnSk
If not, let me know and we can investigate further.
Regards,
Justin.
Jan 17, 2014 | Epson Perfection V700 PHOTO Flatbed...
How to scan negatives?
You will need to check your Canon software that came with your Pixma MX310. I have a stand alone Canon Canoscan 8800F scanner that have the capability to scan 35mm film strip and 35mm mounted slide, the software included the feature for it.
Nov 07, 2013 | Canon PIXMA MX310 All-In-One Printer
Scanning 35mm Slides - getting a pink hue when loaded into Picasa
The whitest white there is is the reflective white on the underside of a scanner tray. Get 2-4 pages of regular office paper and put them between your slides and the scanner lid. That should at least be better. If still not acceptable, try a flat (as in matte, not two-dimensional), white piece of thin cardboard instead of the paper.
Try it and you'll see where I'm going. Does your printer/scanner come with any photo adjustment features in its software?
Jul 14, 2013 | Canon CanoScan 8800F
Photoshop not accepting scans from power slide 5000
Firstly remove your scanner what you have now. Then restart your computer. Now install your scanner driver and also restart your computer. Now try it. I hope it will be fine now.
Nov 04, 2012 | Pacific Bearing Pacific image image box...
Does the HP photosmart 2710 scan negative ansd 35mm slides?
This multi function printer/scanner cannot scan 35mm slides and negatives.
Some flat bed scanners with a lighr scource that shines through 35 mm slides and negatives can scan them.
You will be better off getting a dedicated 35 mm slide/negative scanner.
Check out this WEB site foe slide scanners.
http://www.google.com.au/#q=35mm+slide+scanner&hl=en&prmd=imvns&source=univ&tbm=shop&tbo=u&sa=X&ei=dYFIUPKBKMSyiQedl4G4DQ&ved=0CEkQrQQ&bav=on.2,or.r_gc.r_pw.r_qf.&fp=4469b7ccc4340a33&biw=1016&bih=535
Sep 05, 2012 | Epson Office Equipment & Supplies
How to scan slides with Visioneer 9520 USB Scanner - it scans who
I have successfully used my Visioneer 9520 to scan 35mm slides, and they came out perfect. To do this, in my image editing software, I select File/Import/Acquire/Visioneer ScanManger Pro. This opens the VIsioneer scan manager window, where I select "Scan 35mm using:" and then I choose the desired scanning configuration, e.g., "35mm Better, 35mm Best, Custom" etc. See image below.
BTW: After several moves, I have lost my 35mm scanning template. Do you know where I can get another one, or do you know someone who could actually scan theirs and email the image to me? I could then create a duplicate from heavy black construction paper or card stock.
Jul 26, 2009 | Visioneer OneTouch 9520 Flatbed Scanner
Cant scan 4cm x 4xm slides
The mounted slide scanning option is set for scanning 35mm mounted slides (24mm x 36mm). As far as I know there is no way to change this setting. You may want to try using the film scan option, do a preview scan, and then crop each individual slide for the final scan.
Oct 16, 2008 | Canon MP970 Photo All-In-One InkJet...
No option to scan Film Negatives
In order to see these options, you must have the Film Adapter Unit (FAU) attached to the scanner. The FAU is designed to scan in 35mm film, either positive or negative. The scanner has no options to scan in mounted 35mm slides.
Does the scanner work for scanning at all? If not, you may have a communication problem between the computer and the scanner, i.e., the computer doesn't know how the scanner is configured so it doesn't show the options. If it's a communication problem, check for any other USB devices that might interfere with communication. Especially, some printers seem to take over communications. Try disconnecting all other USB devices (except keyboard, mouse, etc.), reboot, and see if the situation corrects itself.
Also, try the online troubleshooting database for this model at this link.
Sep 30, 2008 | Canon CanoScan LiDE 600F Flatbed Scanner
Scanned 35mm slide comes out as rectangle with dark edges
I've not ever seen "square" 35mm slides. By definition they are a rectangular positive film in an outer square "mount".
If you have a truly square piece of film then it is not a 35mm slide. You may have to use settings other than those for a 35mm film but these would be I don't know.
When were they taken (approximately)? What brand of film? Are they in a cardboard "mount?
Aug 01, 2008 | Epson Perfection 4490 Office Flatbed...
HOW TO GET FROM 35mm COPYING TO REGULAR COPYING
Configure your scan buttons in the bottom right corner of your screen (when you click on the scan icon in taskbar). This will help you to go back where you want to be. You may find it easier to use XP's inbuilt scanning facility instead or scan via Photoshop.
Sep 17, 2007 | Visioneer OneTouch 8920 Flatbed Scanner
1,351 people viewed this question
old marine
old marine
