Question about Refrigerators
Water dispenser will not turn off
I have a GE refridgerator, model number GSS25TGPAWW. The water dispenser will not turn off. The switch that operates the water has part number V5K032EB3C. I cannot find this part number as a replacement.
dididsaythat
  • 291 Answers
SOURCE: GE SIDE X SIDE Dispenser problem
Sound like maybe a dispenser board short... you could try taking of the top hidge cap on the freezer side unplug the power to the board there for 30 minustes or so plug back in and see if it can reset to default and try that before u have to change board
Posted on Aug 21, 2007
applianceboy
  • 77 Answers
SOURCE: Water dripping on GE Fridge model TFX24ZR
check your water filter. water preasure is important in the operation of the water valves. if the filter is ok replace the valve. water filter should be changed at least once every year.
Posted on Sep 26, 2007
SOURCE: ge refridgerator model gsl25jfpe bs
I have a gsl25jfpe bs ge regrigerator and the baffle motor that controls air flow from the freezer to the refrigerator is out. This had been causing everthing in the fridge to freeze and cause the water to stop working due to water freezing in the storage tank. The baffle is in the back top of the fridge covered with a plastic cover. Remove plastic cover to check baffle function.
Posted on Nov 08, 2008
  • 115 Answers
SOURCE: Replace GE ice dispenser damper door on GE model PSI23sgna
take both hands and place on the front bottom edge of control panel pull up and out it is hard and you think you are going to break something but you are not when you get the control panel off there will be 4 screws at each corner undo them and slide that piece off then you can see your door
Posted on Dec 30, 2008
SOURCE: Slow water flow from GE Fridge water dispenser
slow water from my ge refrig side by side. less than a momth old
Posted on Jul 22, 2009
Everything normal on my GE Profile Model PFSF6PKWBBB French door bottom freezer refridgerator except the water dispenser just quit dispensing water. Is it frozen? How do I fix it?
The paddle that you push the glass against to dispense water activates a microswitch. Sometimes this switch can break off it's mount and drop away from it's intended position. The microswitch operates a solenoid valve near where the water line enters the back of the fridge. Then there's the wiring in between them. The water line doesn't go through the freezer. It runs through the refrigerator in a coil of tubing then into the door of the dispenser. Check the paddle switch, the water solenoid and the wiring and you'll find the reason it doesn't work
Mar 05, 2016 | GE Refrigerators
I have a GE side by side Model #GSH25KGPA refridgerator with a water & ice dispenser. I cannot get the ice to dispense. Water works fine. I removed the ice storage drawer and top shelf and note that...
If you can not turn the U shaped drive by hand, you most likely have a frozen auger drive motor. Just thawing it out will not cure the problem, as moisture will re-freeze it again. You will need to replace the motor, part number WR60X10258 for your model.
Dec 11, 2009 | Dishwashers
Model#a4425gd2aww;water dispenser stays on witout pushing cradle even when ice selection is on. This is an americana refridgerator made by GE.
Disconnect the wires on the water valve.(or unplug the frig) If the water stops the dispenser control is defective. If the water continues the valve is stuck and needs replacing.
Eric
Oct 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refridgerator Not Dispensing Water
The waterline inside the door is frozen . Best way to thaw is .....1. open the door and tape the light switch down to keep the light off and the fan working . 2. tape plastic (trash bag , drycleaning bag..etc) over the entire freezer opening so the food will not thaw and the fridge will continue to work as designed . If possible 3. disconnect the water coupling behind the kickplate so air can enter , helping the door defrost cycle , or , leave the coupling connected and ocasionally walk by and press the water dispensor to see if thawed . 4. turn your freezer setting to a lower temperature ! to keep this from happening again .
Jul 10, 2009 | GE GSS25SGPSS Side by Side Refrigerator
Ge refridgerator model gsl25jfpe bs
Jul 19, 2008 | Refrigerators
GE Arctica Refridgerator, PSS26MSRB SS, water leaking from tray, and other questions
ok first the water dispenser i would take out the drip tray and run a thin bead of black silicone to seal it there as to the turbo light getting brighter its because when you switch on turbo its running more power through the switch to the fan now to the fan early model fans were noisy i think ge redid them and if you contact ge you can get one of the newer fans hope this helps by the way loved the pics and mpeg that helps
Jan 25, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser not working
I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Mar 10, 2007 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
