Question about Philips DECT VOIP-321 cordless telephone
VOIP321 Engaged Tone & Dialing a number out using Skype
Why Do I get engaged tone when I dial out using Skype? And how do I dial a number that is not in the Skype contact list from the handset?
  • omaenopa Mar 20, 2009
    were can I download a manual for this phone, only got the start up instructions
  • 26 Answers
Katasen, You punch in the number and press the Skype button.
Posted on Mar 08, 2009
Caller gets engaged signal. I get no dial tone, dial number is dead / does not ring.
take the phone to a friends/neighbours and plug in to test for a dial tone
if no tone , have the phone fixed
if there is a dial tone call the service provider and ask for a repair to your line
Oct 18, 2017 | Lands Phones
Will not dial out on pulse on one line, works on second line
try changing phone to tone dialing . one phone line has been setup for Decadic dialing and the other line may be setup for tone dialing.
If tone dialing is working on one line but not the other then get phone company to change the dialing type on the phone line.
Dual tone multi frequency is the technical name for tone dialing and is more efficient than decadic dialing or pulse dialing.
Jan 23, 2016 | Lands Phones
How do I change pulse to tone dialing?
Are you sure about the phone model number?
Tone/pulse is set in the common equipment (KSU) configuration, not the individual set.
Press Feature 9*80 to see the system software version.
Jan 27, 2015 | NorStar M7324 Telephone
Phone doesnt have dialing tone, cant make a call also when we ring home its goes to engaged tone
This means that your phone line is short circuited somewhere.
The technical name for it is Partial line Lockout.
Try unplugging anything connected to the phone line, including modems, fax machines, house alarms etc (as faulty equipment can cause this), then try ringing home again. If it now rings, plug things in 1 at a time and ring each time to see what is causing it.
If it is still an engaged tone with everything unplugged, then the short circuit is on the phone line in the street and needs to be repaired by your telephone company.
Oct 11, 2014 | Lands Phones
Hello, I have a Remo-Con Tone Dialer but I cannot remember How to use it ! What is it meant for ? Kind regards.
That's not a brand I remember, but it's most likely a tone generator from the days when you still found phones with rotary (pulse) dials. Before tone dialing was the standard, if you wanted to use any kind of service (banking, alternate long-distance phone carriers, etc.) from a rotary phone, you needed a dialer to generate the tones. You held it up to the mouthpiece on the handset and pressed the numbers on the dialer keypad. Some of these dialers also allowed you to store some phone numbers so you could quickly dial them if you were using a tone dialing service. As tone dialing has almost completely replaced pulse phones, you seldom see these devices except maybe at yard sales. They have no practical use any more.
Nov 23, 2010 | Cell Phones
Swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
The phone will have a dial tone and call out but no sound on phone
Look if the VOIP321 speakers are not muted on your computer.
cheers
Mar 19, 2008 | Philips VOIP3212G/37
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Philips DECT VOIP-321 cordless telephone Logo
310 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
