Question about Frigidaire FRS26R4A Side by Side Refrigerator
Refrigerator and freezer not cooling. We checked out the door, and that seems to be fine. There is some ice build up on the bottom of freezer and on back panel. Model # is FRS26ZSH Thanks.
  • nasrgallery Nov 30, 2008
    my freezer is not cooling and change the number from 6 to -15.
    thanks
  • Anonymous Dec 02, 2008
    I HAVE THE SAME PROBLEM. MODEL FRS26SH. THE REFRIGERATOR AND FREEZER WILL NOT COOL. HOWEVER IT SOUNDS LIKE THE MOTOR AND FANS ARE RUNNING. THIS IS THE SECOND TIME THIS HAS HAPPENED. THE REFRIGERATOR AND FREEZE WILL STOP WORKING FOR THREE DAYS THEN IT WILL START WORKING AGAIN. IT HAPPEN A COUPLE OF MONTHS AGO.
    President:
  • Frigidaire Master
  • 2,651 Answers
Sonds like a either a defrost issue,( not self defrosting), or your evaporator fan motor is not turning,can you here hte fan turning inside the freezer compartment???
Posted on Nov 25, 2008
The bottom of my Panasonic frig freezer NR-B29SG2 keeps forming ice making it difficult to open the bottom drawer
Confirm that the seal around the door is tight.
Confirm that the door is fully closed with no obstructions and the door alignment is correct.
Confirm no ice between door and seal.
Using a strip of paper test the tension between the door and seal around the door.
Check the freezer temperature.
It is possible that the defrost cycle has stopped operating. Usually the self defrost will prohibit proper cooling as the ice builds up on the cooling coils. Look for ice build up on the cooling coils/vent openings.
Check the freezer and refrigerator temperatures.
Hope this has helped?
Nov 07, 2016 | Panasonic Refrigerators
Not cooling, bottom of freezer has a vent that has ice build-up
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice keeps building up in freezer. Then the refrigerator stops cooling. You can get the ice off the vents in bottom back of freezer and it will start cooling again but only last a couple days before it...
Your freezer coil needs a good defrost. You are getting only a little bit of the ice off. It stops cooling because the ice acts like a insulator over the coil so it is unable to cool. Was to get this done is to empty it out and shut if off and leave the door open or maybe a hair dryer or even so warm water.
I hope this helps.
Apr 20, 2010 | Frigidaire FRT17G4B Top Freezer...
We have Maytag 25 cubic feet stainless steel double door fridge with pull our freezer on the bottom. The fridge as stop being cooled but the freezer works fine?
There is a defrost problem. Ice builds up between the ref and frz sections and wont allow coolo air through. You can also check to see if the damper is stuck closed
Jun 13, 2009 | Maytag MFD2560HES Bottom Freezer French...
Ice build up in bottom of refridgerator, loud fan noise
check gaskets for air leaks or blocked drain in freezer section
Jun 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer is building up frost and refrigerator is not cold enoough
Almost certainly, you have a leak within the freezer compartment.
The cooling system will use a divertor valve to concentrate coolant to the fridge or freezer compartment - whichever is necessary to maintain selected temperatures.
If a seal within either compartment is compromised and leaks then the coolant will be excessively diverted to that area in an attempt to lower it's temperature - the other section will suffer since more coolant is diverted to the weaker area; the weaker area that is being excessively cooled will also have more moist air circulating, hence moisture will contribute to a build up of ice - exacerbating the problem.
Ensure that both fridge and freezer doors are closing properly, if they appear to be secure then also check that the seals are airtight - there should be no ice accumulating around them.
You might need to re-align the doors, or less likely, replace the door seals.
Please reply if you require further clarification or help.
May 31, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Refrigerator not cool
Hi, if the freezer has ice on the bottom, you nees to clear the drain hole.
Remove the rear panel and remove all the ice. After the ice is out of the drain hole, try and flush it real god (baisting seringe works great) with hot water. If I can assist you further, please let me know.
Thanks
Vic
May 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
275 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
