Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
2005 harley fatboy electrical prob
Installed new battery and regulator and still no charge. checked stator electrical outputs and within paramiters but still no go.
  • 25 Answers
Check stator leads to ground in ohms [OFL]
Posted on Nov 26, 2008
2004 Victory Vegas error code P0562
Hi, Art before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
1. Battery Test:
The battery needs to be a fully charged and load tested to ensure proper readings, connections need to be clean and tight. If you are not working with a fully charged and functional battery, all other voltage tests will be incorrect. Standing battery Voltage should be 12.5-13.2 DCV.
2. Charging System Voltage Test:
Start motorcycle, measure DC volts across the battery terminals you should have a reading of approximately 13.2-15 DC Volts.
3. Connections and wires:
Inspect the regulator stator plug, and check the battery terminals for connection corrosion. If everything seems to be in order, move on to number 4 below to determine if there's a failed component.
4. Stator Checks/Rotor Check: Each of the following tests isolates the Stator & Rotor. If AC output and resistance test fail and stator test passes then the rotor is at fault (Pull Primary covers and inspect rotor for damage).
5. AC Output Check:
Unplug the regulator plug from the stator start motorcycle and change Voltmeter to AC volts. Probe both stator wires with your meter lead. The motorcycle should be putting out approximately 18-20 ACV per 1,000 rpm. Reading will vary depending on system, check service manual specification
Generic Specs:
22 amp system produces about 19-26 VAC per 1,000 rpm
32 amp system produces about 16-20 VAC per 1,000 rpm
45 amp system produces about 19-26 VAC per 1,000 rpm
Stator Resistance Check:
Switch your multimeter to Ohm x 1 scale. Probe each stator wires with meter leads and check resistance on the meter.
Resistance should be in the range of 0.1-0.5 Ohms. Reading will vary depending on the system, check the service manual for specifications.
Generic Specs:
22 amp system produces about 0.2 to 0.4 ohms
32 amp system produces about 0.1 to 0.2 ohms
45 amp system produces about 0.1 to 0.2 ohms
5. Stator Ground Check:
Probe each stator wire with your positive lead on the multimeter and the negative to ground.
There should be no continuity to ground on either wire.
If there is continuity your stator is shorted to ground and must be replaced.
6. Regulator Test:
Each of the following tests isolates the regulator only, so if any of these tests fail, the regulator is at fault.
Identifying Wires:
Battery Charge Lead- Wire going from the regulator to battery positive.
AC output leads- Wires coming from the Stator to the regulator.
Ground- Wire from Regulator to ground or regulator may be grounded via the physical bolting to chassis.
Regulator Ground Test: Ensure the regulator body is grounded or grounding wire is fastened tightly to a good ground (you should verify this by checking continuity from the regulator body to chassis ground).
Fwd/Reverse Bias Test/Diode Test:
This check is testing the Diode function to ensure it is regulating the AC current for the stator into DC Current.
Switch multimeter to Diode Scale.
Place your Multimeter positive lead on each AC output wire.
Place your multimeter negative lead on the battery Charge wire.
The meter should read voltage typically around .5 volts.
Next, switch your multimeter leads putting the negative lead on the AC output wires and the Positive lead on the Battery Charge Wire. The reading should be Infinite. With your meter on the same setting, place your multimeter positive lead on the regulator ground wire or to the regulator directly, and then place your meter negative lead on the AC output leads.
Next, switch your multimeter leads putting the negative lead on the regulator ground and the Positive lead on the AC output wires. The reading should be Infinite.
Note: Below is a table to show the readings:
Positive Lead Negative Lead Reading
AC output 1 Battery charge lead Voltage
AC output 2 Battery Charge Lead Voltage
Battery charge lead AC output 1 ?
Battery charge lead AC output 2 ?
Ground AC output 1 Voltage
Ground AC output 2 Voltage
AC output 1 Ground ?
AC output 2 Ground ?
For more information about your issue and valuable "FREE" downloads for viewing or printing that you will need please click on the blue links below. Good luck and have a wonderful day.
system voltage low p0562
Harley Diagnostic Codes 04 Present DG Custom Cycle
02 04 VICTORY Service Manual 02 04 pdf
Motorcycle Service Parts Part Finder Victory Motorcycles Store Victory Motorcycles 2005 Vegas Owner Manual
Mar 18, 2015 | 2004 Victory Vegas Base
2001 Ultra Classic Battery went bad had to jump it quit charging. have a new battery now only shows 10-12 volts on the meter tried a different regulator with same results. tried to check stater with...
usually it is either the regulator or stator that dies
firstly check stator...(alternator)...set multi mtr at 500ac volts
connect probes (red/blk) to both wires from stator..output voltage should read between 100 acv mid revs to 150 acv mid revs
output to battery should be 13.5v -14.75v dc...if not then regulator is RS ...I used to fit Honda regulators 30amp type with 2 red and 2 green wires ..because it is a 3 phase regulator just disconnect one yellow wire
harley regulators are of poor quality...they have no on off switch like the japanese ones ..in other words when you turn off your ignition the harley regulator is still on
hope this helps
MCS
Mar 08, 2015 | 2001 Harley Davidson FLHTCUI Electra Glide...
Looking for help charging system not charging battery on 1999 Harley Davidson fatboy
Check regulator ground by using an ohmmeter with one lead on a known good ground, such as the battery ground cable, and the other on the regulator base.
The connection where the alternator stator wires plug into the regulator could be corroded/dirty and need to be cleaned and sprayed with electrical contact cleaner and protected with dielectric grease because corroded wires going to the battery or alternator from the stator or the regulator will affect the ability of the charging system to properly charge a battery.
Motorcycle voltage regulator connections must be clean and tight for proper operation so it must be verified that both the AC (stator) connections and the DC (battery supply side) connectors are clean, fully inserted and locked in place with the regulator latches (they should also be coated with dielectric grease to keep them clean and corrosion free).
The motorcycle voltage regulator is a series regulator that is also a rectifier that changes stator supplied alternating current (AC) to direct current (DC) which the battery system requires. If the charging system does not keep the battery properly charged both with regards to Voltage (between 13 VDC minimum and 15.5 VDC maximum) and the current supply at a high enough amperage to meet the system lighting, ignition, TSM/TSSM, security and accessory requirements plus a minimum of 3.5 more amps (3.5 amps more than the foregoing system requirements) there are a number of tests that can be done to ascertain why.
As the voltage regulator must have a good, clean, tight (and otherwise secure) ground connection for proper operation a Voltage Regulator Ground Circuit Test can be accomplished by connecting an ohmmeter to a known good ground (like the battery negative post) and the case of the regulator. If there is continuity with little resistance the ground is GOOD and nothing more needs to be done BUT if there is NO continuity or there is more than minimal resistance the ground will need to be fixed so there is a low resistance continuity by either locating and fixing the poor ground or adding a new grounding wire from the regulator case to a know good ground.
A Voltage Regulator Power Circuit Test can be accomplished by turning OFF the Ignition, disconnecting the voltage regulator and with an ohmmeter set to the Rx1 setting, testing for continuity between the voltage regulator wire harness supply terminal and the main fuse terminal (with the fuse removed) and if there is continuity present then the wiring circuit here is GOOD but if there is NO continuity then you will need to either find the open and repair it or replace the whole wire running from the voltage regulator to the main fuse.
As there should be no short circuit in the power supply from the regulator to battery (main fuse) wiring OR in the regulator internal circuitry continuity from these both need to be checked again with an ohmmeter set to the Rx1 setting. If the regulator to main fuse wiring connector is not disconnected from the regulator you can connect an ohmmeter with one lead on the regulator supply wire terminal end at the main fuse (with the main fuse removed) and the other lead to a known good ground. If there is NO continuity then you know that both the supply wire and the regulator are okay (as there is no short to ground). BUT if there is continuity then either the regulator or wiring or both is/are shorted to ground. To determine where there is a short circuit (i.e. either the wiring or the regulator internal circuitry) you must disconnect the DC side of the wiring harness (the connector at the DC side of the regulator) from the regulator and test between either or both ends of the wire i.e. from the regulator wire harness.
AC Output Check
Disconnect the voltage regulator connector from the alternator stator wiring and then connect an AC voltmeter across both stator sockets of a two wire stator, or if a three wire stator across two of the three for example 1 & 3 and then later you will repeat the test between 2 & 3 and later between 1 & 2. THEN run the engine at as close as possible in the circumstances to 2000 RPM. The AC output should be approximately 32-40 VAC, approximately 16-20VAC per 1000 RPM. If you have done a stator static test and the stator has proven to be in good mechanical condition and the AC output is below specifications, the charging problem is going to be a faulty rotor. If you have not done a static stator check yet and the AC output is less than as set out above it may be that the stator is defective and the static stator check will need to be done. While the regulator has nothing whatsoever to do with the alternator output, if the alternator output is good the regulator might be defective in either rectification or in limiting the output to the battery to under 15 VDC. If AC output is low and the stator has passed the static stator check then it is likely that the permanent magnets in the alternator rotor are weak. A permanent magnet can lose its magnetic strength if it is dropped or shocked such as letting it snap into place when being installed or possibly by use of an impact wrench to remove the compensator fastener etc.
May 27, 2014 | Harley Davidson FLSTF - FLSTFI Fat Boy...
Why battery not charging, test bat its good
Could be a bad regulator or alternator.
Current and Voltage Output Test
This test requires a load tester. As it appears that many shops/techs do not understand electricity and as they are relatively expensive testers many shops do not even have one. If you have one connect the negative and positive leads to the battery terminals, place the load tester induction pickup over the positive regulator cable and run the engine at 3000 RPM, increasing the load until a constant voltage reading of 13.0 VDC is obtained. At this point the current output should be 26 to 32 AMPS. Make a note of this reading as it will be used if a TOTAL CURRENT DRAW TEST will also be done. (A rider's riding habits, i.e. rpm of the engine while usual riding is being done could be significantly lower than 3000 RPM which would mean that less than the above optimal voltages would be produced so a rider in too high a gear for a given speed might have too low an operating RPM and thereby produce less current than is required to meet the bike's electrical load demands.)
CAUTION
Do not under any circumstances leave any load switch turned on for more than 20 seconds or overheating and tester damage are quite likely to occur.
Voltage Output Test
After removing the load, read the load tester voltage meter AND if voltage to the battery is not more than 15 VDC then voltage output is within specifications but if the voltage is higher then the regulator is not functioning properly or there are lose or dirty connections present.
AC Output Check
Rotor Inspection
Inspect the rotor for physical signs of damage. THEN remove center bolt and inspect for signs of the center hole having become oval and ensure that the stator bolts have not come loose and come into contact with the rotor.
May 08, 2014 | 2000 Harley Davidson FLSTC Heritage...
2001 Honda VT 1100 C2 Shadow Sabre not charging
Hi, Anonymous before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amperage and must be replaced AGM types more so than lead acid batteries.
1. Battery Test:
5. AC Output Check:
Generic Specs:
Generic Specs:
Stator ground Check:
5. Regulator Test:
Identifying Wires:
Battery Charge Lead- Wire going from regulator to battery positive.
Regulator Ground Test: Ensure the regulator body is grounded or grounding wire is fastened tightly to a good ground (you should verify this by checking continuity from regulator body to chassis ground).
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
VT1100 Charging Problem
http://racetechelectric.com/files/pdf/rte_troubleshooting_flow_chart.pdf
Honda shadow vt1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual Page 3
Apr 11, 2014 | 2001 Honda VT 1100 C2 Shadow Sabre
How do you know if a reg/rec has gone
Hi, Derek before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amperage and must be replaced AGM types more so than lead acid batteries.
1. Battery Test:
5. AC Output Check:
Generic Specs:
Generic Specs:
5. Regulator Test:
Identifying Wires:
Regulator Rectifier Motorbike testing blown or not mp4
Triumph Daytona 600 Regulator Rectifier upgrade
Triumph 2003 Daytona 600 Service Manual
http://www.bikebandit.com/oem-parts/2005-triumph-daytona-600-650-sump/o/m17663sch569813
Triumph DAYTONA 650 Manual
May 01, 2017 | 2005 Triumph Daytona 650
2005 Suzuki Boulevard C90T not charging
Hi, Ytruelove before testing any electrical component in the Charging System Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
1. Battery Test: The battery needs to be a fully charged and load tested to ensure proper readings, connections need to be clean and tight. If you are not working with a fully charged and functional battery, all other voltage tests will be incorrect. Standing battery Voltage should be 12.5-13.2 DCV.
2. Charging System Voltage Test: Start motorcycle, measure DC volts across the battery terminals you should have a reading of approximately 13.2-15 DC Volts.
3. Check Connections/Wires: Inspect the regulator/stator plug, and check the battery terminals for connection/corrosion. If everything seems to be in order, move on to number 4 below to determine if there's a failed component.
4. Stator Checks/Rotor Check: Each of the following tests isolates the Stator & Rotor. If AC Output test Fails and Resistance Check, and Stator IB Test Pass then Rotor is at fault (Pull Primary covers and inspect rotor for damage).
5. AC Output Check:
Start motorcycle and change Voltmeter to AC volts.
Generic Specs:
Resistance should be in the range of 0.1-0.5 Ohms. Reading will vary depending on system, check service manual for specification
Generic Specs:
Stator IB test or Ground Check:
If there is continuity to ground your stator is shorted to ground.
5. Regulator Test: Each of the following tests isolates the regulator only, so if any of these tests fail, the regulator is at fault.
Identifying Wires:
Fwd/Reverse Bias Test/Diode Test: This check is testing the Diode function to ensure it is regulating the AC current for the stator into DC Current.
Suzuki C90t Stator Problem
http://www.jetav8r.com/Vision/Stator/fault_finding_by_www.electrosport.com.pdf
Suzuki VL1500 Service Manual
OEM parts for Suzuki
Suzuki Intruder VL1500B Owner Manual
Mar 31, 2017 | 2005 Suzuki Boulevard C90
I have replaced the battery and it will not hold a charge.the motor sounds like it is not firing right and when it idles the led mileage indicator flashes on and off. after I let it run for a period of...
Three things. The battery, voltage regulator and stator/rotor are all dependent on one another. If the battery is bad it can pull the voltage regulator and stator both down trying to keep it charged. So you need a known good battery to start, then check the output of the regulator with a voltmeter, if that is good, then it will keep the battery charged. If not good check stator output. Somewhere therein lies the problem, as they say.
The engine will misfire and run erratic because it is not getting enough electrical power to run the electronics that control it.
Bottom line, it sounds like the voltage regulator or stator is the problem, which are both easy to check.
May 19, 2010 | 2003 Harley Davidson FXDL Dyna Low Rider
2005 Hartford HD-125S electrics not working
Hi, Ratbag1488 before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amperage and must be replaced AGM types more so than lead acid batteries.
1. Battery Test:
5. AC Output Check:
Generic Specs:
Generic Specs:
5. Regulator Test:
Identifying Wires:
Hartford HD 125S
Reading Hartford Hd 125 Super 2009 Manuals
CHINESE SC HARTFORD HD 125 LEGION 2005 2009 Spares Parts Accessories
Hartford HD 125S 2007
Jul 11, 2017 | 2005 Hartford HD-125S
Overcharging on a 93 fatboy
The only defect a stator would have is it's either delivering no or low voltage output. By design, it will always put out higher voltage than required. It is the job then of the regulator to control how much is pushed to the battery. If the battery is overcharging, then the regulator would be at fault.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 11, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Lands Phones Logo
205 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
