Tht drive used to work but now the power light coes on erratically if I wiggle the USB end of the connection cable, then goes off a few seconds later. The drive isn't recognized as connected by computer (macbook 1,1),
SOURCE: Seagate 300GB ST3300601U2-RK
usb cable provides power to your hard drive.
try to use new cable.
hopes it works.
pls. confirm
SOURCE: Power problem
I have purchaed the Seagate Free agent pro external hard drive one month before. I moved around 200 gb of my very important data to this drive. Now it is not working. Initially there was no drive shows in my laptop. Then the light is not showing in the External drive.
I called the seagate office. They are going to send the cables.
Please do not buy this ********* drive.
SOURCE: New Seagate FreeAgentPro USB eSATA 500GB power on light not glows
Thank you for your reply.
I have solved the problem with local help.
Printed installation manual of Seagate 500 GB eSATA external hard drive has not properly mentioned how to use power on/off switch once connected to mains. I could get local help, who has already used the device. On/Off switch to be pressed for few seconds after mains connected, sometimes it comes automatically once power is on and USB cable pluged to the USB port of PC if power supply is ok. There is no indicator for the power supply (before device glows) after connected to the mains. I was in confusion whether power supply is ok or not.
Finally, It was found that the problem was with mains power supply and I have changed the power socket and adapter.
SP Jena
SOURCE: seagate external hard drive problem
I have the same problem with a 500GB HD by the same maker. Fortunately mine started throwing "delayed write failed" errors regarding the MFT. I had enough time to save my data. Your event log should say something to point you in the right direction. Make sure your pc is up to date with the latest service pack too and start looking for a new External HD. Tiger Direct has great deals. I got a 1TB for about $120 Good Luck!
SOURCE: seagate free agent pro 500 gig external hard drive NOT RECOGNIZED
its possible that you can still get the data from the external drive..just separate the harddrive from the case and use another external casing to access the harddrive or just add it your desktop...hope this helps...ITTech7574
