Question about Palm Tungsten E Handheld
Tungsten E My device wont turn on. After inserting a tip of a paperclip into the reset hole it lights up for about 3 seconds and then it shuts down . This is happening again and again. Any solution?
I have a tungsten e2 and it automatically turns itself on with out any buttons what so ever so the battery wont stay charged long enough for me to do any thing illput it up and come back an hour later to find the batter is already dead ill charge it unplug it and bring it to work with me to only find that when i get to work its on and the battery is draining what do i do
Posted on Feb 08, 2007
Cant enter setup mode or use Bluetooth anymore
Look for small button or hole underneath or near power supply should be marked reset...insert paperclip or reset pin tool press lightly and hold for 15 seconds power light should blink turn device off gen back on . That should reset fully
Jan 13, 2016 | Miscellaneous
My tablet says to enter decrypted password but i never set one up
PLEASE NOTE THIS INSTRUCTINS IS FOR FACTORY RESET
BY DOING THIS ALL DATA WILL BE DELETED
The paperclip is used to activate the reset button in this small hole; You will hear and feel a click of the inside button, in less than 15mm of insertion. Do not force unduly!
1. Insert paperclip, until you hear the click of the button. Keep paperclip inserted, and press and hold the black power button.
2. In about 10 seconds the blue PROSCAN screen will appear. Continue to keep black power button held, and release paperclip.
3. A few seconds later you will see an Android 'guy' lying on his back with belly open, and a red triangle (with !) symbol hovering above his belly. Release power button. This means we are on the verge of being able to break things. Note that after a minute or so, if no further action is taken, the tablet will shut down, and then be restarted normally.
4. Press and hold power button. Insert and remove paperclip. You will see a screen titled Android system recovery. (Note that repeated insertion of the paper clip will alternate the display of the Recovery menu). Release power button.
5. Use paperclip to scroll down the list of options. To reset the tablet, selectwipe data/factory reset. Press power button to make the selection. (If you go past the desired option, keep on clicking, as the selection will scroll back to the top once at the bottom).
6. Once reset has been selected, you are now at the final chance to back out or commit. All the menu items, except for one are labeled No. To commit to the reset, select Yes - delete all user data and then press power button.......FOUND ON ZOLYGON.COM
Mar 09, 2015 | Proscan 8" Tablet with 4GB Memory
How do i do a hard reset on a magellen maestro 4040?
  • 1 Slide the Magellan GPS unit's powericon1.png switch to the off position, if your GPS has a two-way slide-style switch. Hold the switch in the off position for 8 seconds or more to reset the device.
  • 2 Slide the switch to the reset position if your GPS has a three-way switch. These switches feature "Reset," "Off" and "On" labels. Hold the switch on the reset position for 10 seconds to initiate a reset.
  • 3 Inspect your GPS for a reset pin hole if the unit has a push-down power button rather than a switch -- check the bottom and sides of the device for a pin-sized hole. Insert a pin or a straightened paperclip into the hole, pushing until you feel a slight pop. Hold the pin or clip down for 10 seconds and the GPS will reset.
  • Read more: http://www.ehow.com/how_5635240_reset-magellan-gps.html#ixzz33LpAdUJE
    Jun 01, 2014 | GPS
    It wont stay on
    Is it turning off with charger connected or without charger?
    If it is turning off while charging also, Try doing a soft reset.
    1. Insert a small pin or unfolded paperclip into the reset hole located at the back of the player.
    2. Hold until the player shuts down.
    3. Power on the player again by using the Power on/off key.
    If this doesn't help, try repair it using Philips device manager program which came with the CD or downloadable from Philips web.
    Apr 19, 2014 | Philips GOGEAR SA6045 MP3 Player
    Reset button is broken and need to reset adapter
    When you look the reset button, does it have a color?
    When you try to press it using a paperclip, does it click or did it just came through?
    Right way to reset devices:
    1. Use the tip of a paper clip.
    2. Press and hold the reset button for 30 seconds.
    3. Lights on the device will flicker.
    4. When the time is up, turn off device, wait for 10 seconds and turn it back on.
    Oct 03, 2013 | Computers & Internet
    Can i reset my tomtom one v3 to original factory settings
    yes you can rest your tom tom. If you don't know how to do the reset, follow the steps below:
    1. Remove the TomTom GO from its cradle.
    2. Turn the unit upside down.
    3. Look for a small hole in the bottom of the unit. It will be located just behind the release button. The reset button is recessed inside this hole.
    4. Straighten out one end of the paperclip.
    5. Press the recessed button by inserting the straightened end of the paperclip into the reset hole.
    6. Hold the button down for ten seconds, then pull the paperclip out of the hole. Your Tom Tom GO should now be reset back to the original factory settings.
    Take care.
    May 28, 2010 | Tomtom ONE 3rd Edition GPS
    Lost password for router and can't accsess wi-fi on my ipod touch
    do a hard reset - press the little button inside the device, while unplugged and disconnected. hold with a paperclip for at least 30 seconds.
    This will reestablish factory default settings
    Dec 26, 2009 | Computers & Internet
    I lost all the passwords want to reset the system to reconfigure it
    Turn your router upside down or look on the rear for a small pinhole. It should be labeled "RESET." With the router turned on, unbend a paperclip and insert it into the hole. You will feel a small button inside, which you'll want to press with the tip of the clip. Hold the button down for 10 seconds, or until the lights on the front of the router stop blinking. The router will reboot within about a minute and be ready for configuring from its virgin state.
    Remember..default username is admin, default password is admin and default IP address is 192.168.1.1
    Nov 19, 2009 | Airnet AWR014G8 Wireless Router
    Palm won't shut off but displays the Palm shield with the note "powered by" or it displays a message that says it it trying to connect to tyhe desktop. I have pressed the reset button and it will shut off...
    HI,
    Here is a link to Palm support. It sounds like you need to do a hard reset. Try that by depressing the reset button on the back of your unit. You will need to use something pointed like a paperclip and insert that into the hole and hold in in while you hold down the power button. When you see the Palm powered logo let go of the power button and follow the onscreen directions.
    Here is the link for Palm support in case you have any other issues.
    http://kb.palm.com/wps/portal/kb/na/tungsten/e/unlocked/home/page_en.html
    Oct 26, 2009 | Palm Tungsten E Handheld
    Palm Tungsten E Handheld Logo
    96 people viewed this question
    Top Palm Computers & Internet Experts
    Michael Vincent Cruz
    Don Eagan
     steve
    steve
    Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
