Question about Fine Digital FineDrive 400 GPS Receiver
Never been able to get satellite signal
I never could get a satellite signal so I took it to a installer and he couldn't get a signal either. He tried for 20 minutes and nothing happened. A map appears on the screen but it's not my area and it says it's searching...... I called the toll free number listed in the instruction book and it was disconnected. I've wrote an e-mail to the address given in the book and it's never been answered.
  • Lisathayer Nov 25, 2008
    no signal always searching for signal
  • ehiggin Dec 14, 2008
    the solution worked, thanks so much. I finally got a connection and so far has worked great.
    Scholar:
  • 107 Answers
If you exit navigation and go to the main manu, you can go into setup and do a GPS reset, if this does not get it going then your GPS receiver or antenna has failed...
Posted on Dec 02, 2008
How can I get my Toshiba Sd H400 to find satellite signal?
You have to use some of the special connections on the back to connect the Satellite box. It will not work with those you are trying. See the manual below:
Toshiba SD H400 TU Installation Manual Using Your Sd h400 With Cable Or...
Oct 05, 2017 | Toshiba Sd-h400 Combination...
Had a lightning issue the other night and now my Vizio tv will is not able to find satellite signal. Netflix works and can pick up Wi-Fi signal .....there is a good picture but it says searching for...
If it says "searching for satellite" the problem is in your satellite receiver, not the TV. The TV is working. Its showing you the signal coming from the sat box. The sat box is the tuner and is responsible for the sat signal. The "searching for satellite" is a common problem after lightening issues. If you have multiple sat boxes, then swap this one with another that you know works. If this is your only box, call your provider as it means the dish LNB or the sat box was damaged by the lightening. Also have the wiring checked for bad grounds due to an improper install.
Dec 21, 2017 | Vizio VO420E 42 in. LCD TV
Hi,what cable do I need to link a Toshiba Satellite U330-14B to a tv please?
I couldn't find any record of that model of a Toshiba. It looks like you might be talking about a Lenovo IdeaPad U330. Assuming that's correct, that laptop has a an HDMI out.
If your TV has an HDMI input on it, then all you need is an HDMI cable.
If your TV is older and does not have an HDMI input, you would need a converter box that converts the digital signal to an analog one. Search the internet for "HDMI to Composite converter". There's plenty of choices out there that can do this task.
Sep 17, 2012 | Toshiba Satellite U300-14B WXGA 13.3" LCD...
No input 2 signal
The connections bad.... try rewiring the one for signal 2 or if its making a good connection... look for a weak spot in wire... that helped me when i couldn't figure out wiring
Aug 28, 2012 | Cars & Trucks
Left rear turn signal and brake light not working. fuse is good, bulb is good. back-up lights work.
I have a 2007 Chevy Express with the same problem. Just happened. Brake and turn signal not working on left side. Fuses good, bulbs good (dual element lamp, turn signal and break are same element) running lights work (other element) Relay blinks fast and not getting voltage at light for blinker or brake. Is there something else in the circuit I need to check. Took it to an ASE mechanic and he couldn't or didn't want to fix it. THANKS Let you know if I fix it tomorrow.
Jul 31, 2011 | 2007 Chevrolet Express Passenger
I have Dish 322 receiver. Everything was fine; a week or so ago satellite 119 reception was spotty, now we can't get 119 at all. We get 110 but only about 34%. Sometimes the receiver will power itself off...
hartpark
It looks like you have lost the signal for the 119 satellite from your dish. Are you getting an error message, either 002 or 015, saying the satellite signal has been lost or acquiring satellite signal? First, check the cables on the back of the receiver to make sure they are secure. You can also run a check switch test to see if there is a problem between your dish and receiver.
Press the Menu button on your remote. This will bring up the Main Menu on your TV screen. Input the numbers: 6 (System Setup), 1 (Installation), and 1 (Point Dish). On the right side of the Point Dish screen are 3 buttons. Select the Check Switch button. Within the 2 large boxes are satellite numbers and green or red boxes. Make a note of the satellite numbers (should be 119, 110), the trans, the device, and switch. Super dish and alternate should not be checked. Select the Test button on the bottom of the screen. If a box pops up with a warning about TV 2, select Yes. It will now run the check switch test. Let it complete the test. After completion, the screen will automatically go back to the Installation Summary screen. You may get a message stating that the Check Switch test has found fewer satellites than previously detected. If you get this message cancel out of each screen (do not save the results) till you are back to the TV screen and it is acquiring Satellite signal.
If you don't get that error message, see if the information on the Installation Summary has changed. Then select Done on the next 2 screens and cancel out of the others till you get the message, Acquiring Satellite Signal. After it finishes acquiring satellite signal and downloads the program guide, see if you are getting a picture - try different channels. If you still have problems, please email me at, ray.calo@dishnetwork.com. If you are still experiencing problems, we will need to send a technician to fix the problem.
Ray Calo
DISH Network
Apr 23, 2011 | DISH Network 322 DTV Receiver
Lost maps in garmin nuvi 200
Form Message You need to have Garmin Tech support send you this attachment; "gmapprom.unl" Then follow the instructions below.
1.) Save the attachment from our message to the desktop
2.) Right-click the file gmapprom.unl, and click copy
3.) Click on My computer
4.) Click on the Garmin Nuvi drive
5.) Click on the Garmin Folder
6.) Rightclick a blank white space in this Garmin folder
7.) Click Paste, and note gmapprom.unl file is listed, please also delete gmapsupp.img if present
8.) Unplug the device, and allow to start up
Nov 04, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin Forerunner 305 cannot locate satellites
Hey, I install Garmin GPS Chipset Type G and now it seems work well.
Mar 01, 2008 | Garmin Forerunner 305 GPS Receiver
36" RCA TV Wont power up
IP030 Regulator part number 263567/ Regulator overheating
Nov 29, 2007 | Televison & Video
In search of Toshiba Display and audio Driver
I couldn?t find a Satellite Pro A 100 series but I did find drivers for the Satellite A100 series. At any rate click on the link, supply the appropriate information and if there are vista drivers for your laptop they?ll be here. Good luck. http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modSel.jsp
Jul 14, 2007 | Toshiba Satellite R10-S802TD Tablet PC
Open Questions:
Fine Digital FineDrive 400 GPS Receiver Logo
88 people viewed this question
Top Fine Digital GPS Experts
ChuckyMo
Iqbal Husain
Iqbal Husain
k24674
Are you a Fine Digital GPS Expert? Answer questions, earn points and help others
