Question about Teac AG-V1050 Receiver
Magnavox Console Stereo turntable does not turn at correct speed
I have a vintage Magnavox Console stereo (Model 1ST660S) and the turntable does not turn a the proper speed. The speed control doesn't seem to do anything. It turns but at a very slow speed.
    New Friend:
If it has 78 speed try it for a few minutes and see if what happens
Posted on Jul 31, 2013
I'm in Nashville, where can I have my 70"s Magnavox stereo console serviced to get bugs out of it as well as get new cartridges?
Posted on Aug 05, 2011
Can you replace the turntable in a vintage Zenith Console sterio with a newer turntable?
Generally speaking all you need to do is find the left and right channels leads from the old deck to the amp, cut them off or if thy plug in somewhere unplug them, then you can connected the playback leads of the new deck to the amp and it will then play back.
Jun 22, 2014 | Audio Players & Recorders
Sansui stereo remote
the above mentioned make and model # unit is a tuner, not a reciever, as a tuner, it's only function is to recieve radio signals, there is no internal amp, no selector switch for other components.
Apr 27, 2013 | Sansui Vintage Am/fm Stereo Tuner Tu-217...
I have a vintage magnavx console stereo and the turntable speed is off....how can I fix this?
Depends on the drive method of the old turntable. Sometimes grease/dirt can build up. If it's an idler drive then the rubber wheel that rubs on the rim of the turntable can become worn.
Aug 28, 2011 | Audio Players & Recorders
I have a Vintage 1965 Magnavox Console Stereo. It is in excellent condition, (everything works on it). No dings and even still has a new needle, all original paperwork with it. I would think there must be...
Hi mesha
To answer your question;
Of course the value is in the eye of the beholder but i`d say go to Ebay and search for your model number or look into vintage stereo systems for something that would be equivalent.
It should give you a pretty good idea of it`s estimated value.
Hope this help Good luck
Mar 15, 2010 | Audio Players & Recorders
Vintage turntable turns slow for few minutes then speeds up,,,why
The tubes are only in the audio amp portion of the stereo, and have nothing to do with the motor that turns the turntable.
Most likely it's that the grease on the motor is old and gummy, but becomes less viscous when it warms up.
Jan 24, 2010 | Numark TTX Turntable
I just inherited an old Zenith console turntable and stereo combined. Stereo sounds wonderful, but when I play records, the sound isn't loud. Is this a problem with the needle or what? When I touch the...
Hiya, check and be sure the turntable is plugged into correct inputs, "phono"
If thats OK, then probably is the stylus but could also be the cartridge itself. Check the wires on the back of cartridge make sure they are fixed properly. If all Ok, then start with a new stylus first.
Hope it helps
Jul 25, 2009 | Audio Players & Recorders
Magnavox Model 2P3602 - Turntable will not turn
This is a DIRECT DRIVE turntable (no belts) you are going to have to replace the drive motor (if you can find one!)
Please rate response!
thank you!
Jan 26, 2009 | Teac AG-V1050 Receiver
Turntable failure
The drive wheel has probably dried up and is just slipping. Also, any grease that was in there has probably turned more to glue. This unit will need some TLC and some time to get all of the old grease out. A re-lube as well as a new wheel (if still available) and you will be good to go!
Dan
Mar 26, 2008 | Audio Players & Recorders
1,944 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
