Question about HP Computers & Internet
Cd is stuck in cd rom drive, how do I get it out?
    Sergeant:
  • 207 Answers
If all you need is to get the CD out. You can unfold a paperclip and push it through a pinhole on the front of you CD rom drive. Depending on manufacturer and model it should be on the right or left side under the tray. There is a mechanism in there that you push against and it will physically push the tray out.
If you need anything further please feel free to comment back here and we'll be happy to help.
Dave
Posted on Nov 24, 2008
Drawer will not pop out to insert cd
HI
It is possible that a CD may have become stuck within the CD-ROM drive. If the CD-ROM drive has a small hole (that is not the head phone jack), using a paper clip, place the paper clip within the hole and attempt to manually eject the CD-ROM tray.
May 16, 2010 | E-Machines emachines (emachinees) CD-ROM...
Tip
Cdrom drive can not eject / Cdrom is stuck
How To Eject CD from CD-ROM drive if it is Stuck :
If you have a CD into CD-ROM drive and it is stuck and you are trying to eject tray of CDROM by pressing the eject button or windows eject command but CD won't eject as there is no command to eject a stuck compact disc from the CDROM drive then this article is for you.
Step 1: Switch off the computer.
5573fa0.jpgStep 2. On the front of the CD-ROM drive you may find a small hole called Emergency Eject hole below the tray of CD-ROM drive . Take a long pin around 3 inch, (also known as CD ejector) it must be hard enough, insert this pin inside the hole and push a little. The CD tray will slightly move to out.
Step 3: Now you may manually pull the tray and you are done. You have successfully ejected the stucked CD.
Step 4: Switch on the computer and you may work as usual.
Thanks
Proton
on May 12, 2010 | Computers & Internet
On my HP pavilion mx 75 my hp cd--writer will not open any easy fiX?
Hello
Well, if there is a cd stuck in the device, you might fix this problem by force ejecting the cd/DVD.
Here is how we do this:
Take a small pin, push it into the small hole near the eject button on the CD/DVD rom. While doinf this, gently pull out the trey.
If this was a stuck cd, just take it out, if there was no dc/dvd in the rom, it might be a faulty eject button. Test this by going to My Computer, right click on the CD/DVD rom andd choose to eject.
If this does not work, i would suggest thatyou buy a new drive, because it is often much cheaper than to repair.
Let me know if this work.
Kind regards
Andrea
Feb 17, 2010 | HP (176135-630) (176135630) Internal 48x...
It is stuck. I have tried putting a straightened paper clip. does not work. no light, no response. stuck, stuck, stuck
Shutdown the PC and try to insert straithtened paper clip in the small hole provided in front of the CD/DVD ROM drive.
Dec 04, 2009 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
The CD ROM Drive is not ejecting properly
hi,
Locking device / software installed
First, verify no locking software is being loaded, which would allow the CD-ROM tray not to open. If you are unable to determine this, reboot the computer and as it is booting up, attempt to eject the tray. No power to computer or CD-ROM drive
If you have recently installed a new CD-ROM drive or you have moved the computer, it is possible that the power to the CD-ROM may have become loose or disconnected. Check the cable connections. Bad eject button
If you are running Microsoft Windows 95, Windows 98, Windows NT 4.0, Windows 2000, Windows ME, or Windows XP, open My computer, right-click on the CD-ROM drive and choose the option to eject. If this ejects your CD-ROM drive tray, it is likely that the button on the CD-ROM drive has become defective and it is recommended that the drive be replaced. CD stuck within drive
It is possible that a CD may have become stuck within the CD-ROM drive. If the CD-ROM drive has a small hole (that is not the head phone jack), using a paper clip, place the paper clip within the hole and attempt to manually eject the CD-ROM tray. If the CD-ROM drive is only partially able to be opened, attempt to pull the tray gently to see if it can be manually ejected. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become bad, dislodged, or that a CD is positioned in the drive, which does not allow it to open. Incompatibility with IDE / ATAPI interface
If you have an IBM compatible computer and recently installed the CD-ROM drive and are unable to open the drive, attempt to temporarily disconnect the IDE cable to verify that you not experiencing an issue with an incompatibility between the CD-ROM and motherboard. Once the IDE cable has been disconnected, power on the computer and see if the CD-ROM drive tray is now able to be opened. If the drive is able to be opened with the IDE / ATAPI cable disconnected, it is recommended you use the interface card supplied with the CD-ROM drive or the ATAPI interface on the sound card / motherboard. Bad drive
Unfortunately, if after following the above recommendations you are still unable to properly open the CD-ROM drive using the button on the front of the CD-ROM drive, it is likely defective and should be replaced. Caution: If you are able to open the CD-ROM drive using a paper clip. We do not recommend that you continue using the CD-ROM drive by manually ejecting the CD-ROM using a paper clip. The drive should be replaced and this is not meant to be used as a temporary solution. Additional information and tips for buying a new CD-ROM drive can be found on our CD-ROM buying tips section.
Jul 02, 2009 | Computers & Internet
CD Rom tray stuck
does the case a a faceplate infront of the cd rom drive(i.e. if there is a door that flops down when it opens)? if so you probably need to take off the computers faceplate and then you can get to the little hole.
Jun 14, 2009 | Zenith Data Systems Zenith (OP-260-74501)...
New (to me) blueberry cd stuck in drive
If this is a slot loading machine there may be a little hole next to the CD-Rom drive. Slide a paper clip into the hole and the CD should pop right out. If this is not a slot loading machine then it will be the same procedure only the hole for the CD-Rom will be on the CD-Rom tray itself
Aug 07, 2008 | Apple iMac Blueberry Mac Desktop
CD driver stuck
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Dec 06, 2007 | Dell INSPIRON 6000 CENTRINO...
Cd rom drive keeps opening and closing
Try cleaning it out with air from a can, possible something stuck in it. Also might want to try uninstall and reinstall device. This could also cause problem as well
May 29, 2007 | HP (D4384-63002) (d438463002) Internal 32x...
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
