Question about Onkyo TX-SR606 Receiver
Reciever turns off
Just purchased the Onkyo TX-SR606. The whole unit turns off when the volume exceeds 39. Ive set the volume limit to 79 in the speaker settings.
  • 2 more comments
  • robjohnpaul Dec 05, 2008
    volume level over 40, unit cuts out.
  • MadDog1980 Dec 12, 2008
    I just bought this reciever and have experienced the same issue. It shuts off if the volume is pushed passed 40.
  • blueirisedit Dec 26, 2008
    New unit shuts off if volume set at 30 or above and sound on DVD spikes. Sounds like this is something of a universal issue.
  • Anonymous Dec 29, 2008
    same issue very irritating
North American models are all set to 6 ohms. You can't switch the setting.
Try reconnecting the speaker wire into the back of the unit. This worked for me.
Posted on Dec 27, 2008
Powering off usually points to issues with speaker setup. You should read pages 42 and 96 of the 606 manual.
Page 42 covers impedence settings. Check your impedence settings for your speakers. The 606 handles speakers from 4 to 16 ohms. There are two impedence settings on the 606 - 4 ohms and 6 ohms. Set to 4 ohms if your speakers are 4 ohms or more but less than 6 ohms. Set to 6 ohms if your speakers sit between 6 and 16 ohms. Incorrect settings can result in the 606 going into power protection after prolonged use or at higher volume.
Page 96 covers testing for unexpected power protection. You should switch off your AV at source and leave for an hour. Disconnect all cables to speakers and other peripherals (TV, DVD et al). After an hour turn on AV and turn volume to MAX, If the AV remains on, turn down volume to min, switch off AV and reconnect all devices. Make sure the speaker cables are properly connected and that no bare wiring is exposed.
Once you have done this switch on the AV and turn to volume to MAX. If the AV stays on then problem solved. If the AV switches off then you should contact your supplier.
Posted on Dec 26, 2008
My Onkyo TX-SR606 won't turn on
The reference to Zone 2 means that your Onkyo receiver is set to be remotely controlled from another location. Normally, this arrangement would be initiated at the time of set up but could be done later. You may have to repeat the initial set up routine to get things back to normal
Feb 22, 2013 | Onkyo TX-SR605 Receiver
Has trouble getting input signal
This unit has a defective hdmi board,this is a common problem with this model. The unit is to be taken to a onkyo service center for exchange of the hdmi board under warrenty, if out of warrentyit will cost you several hundards of dollars.
Apr 19, 2010 | Onkyo TX-SR606 Receiver
No audio from pc connected using hdmi
Are you not getting audio to the television speakers and the onkyo reciever speakers when connected HDMI thru the reciever or just the television. If it is just thru the television then it is because the reciever is grabbing the HDMI audio signal and converting it so it does not reach the TV. If it is both then try changing the HDMI signal output from PCM to DOLBY DIGITAL on the computer. Your reciever may not be able to process the PCM signal of the computer. Does the reciever show a PCM or DOBLY DIGITAL display when HDMI is hooked up to it?
Oct 03, 2009 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 power on default input setting and hissing sound
I had the same problem for more than a year but just lived with it. The solution is to reset the receiver to factory defaults. Page 96 of the owners manual, "turn the unit on and while holding down the VCR/DVR button, press the ON/STANDBY button. CLEAT will appear on the display and the unit will turn off". Problem solved!
Sep 21, 2009 | Onkyo TX-SR606 Receiver
My Onkyo TX-SR606 will not turn off, will not adjust volume, will not change modes, will not do anything but stay "stuck" on cable/satellite at volume 33. It will not reset. I unplugged it, waited, and...
contact onkyo and ask for a disc that you use threw the cd player via a toslink . The disc will upgrade your avr ,thus overwriting any problems you had. My tx-sr705 had an issue with popping during blu ray playback while the dts-master audio was being used. I got a disc that upgraded the chip that utilizes the codec's.
Aug 14, 2009 | Onkyo TX-SR606 Receiver
Onkyo tx-sr606 turns off during loud dvd sounds.
It sounds like you have a defective unit. I would contact the manufacturer and ask to RMA it.
Aug 08, 2009 | Onkyo TX-SR606 Receiver
Remote code for sony playstation 3
you cannot control a ps3 with that remote because the playstation 3 only works with bluetooth. I'm sorry to have to tell you. you can purchase a remote that works with your system at any that sells your system.
hope this helped
please rate well.
Mar 06, 2009 | Onkyo TX-SR606 Receiver
Maximum Volume is set at 79 yet will max out at 60-65 depending on source, TV, Audio or DVD is anything wrong?
have you done the audessey setup or even changed the level calibration on your receiver? if so this would reduce the actual max volume on the receiver.
Feb 27, 2009 | Onkyo TX-SR606 Receiver
ONKYO TX-SR606 Single output to TV
Hi there. for your receiver, the only time it can upconvert is when you go out as HDMI. In your current hookup (component out to tv) the signal from your cable (using a composite) will not be able to pass through the component cable. This means you either have to hook up your cable box using a component cable as well or add a composite cable (yellow) from monitor out of the receiver to the tv. Page 22 of the manual will show a diagram of the video signal flow. hope this helps.. ^_^
Dec 02, 2008 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 Receiver Logo
335 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
