Question about Dryers
Condensation is forming on the walls when I use my clothes dryer
I have a wall mounted Simpson Sirocco 350 clothes dryer and when I used this for the first time a large amount of condensation formed on the walls of my laundry room. (it was a cold day and the laundry room door was closed.
I have examined the back and don't believe that it is vented which I am assuming is the problem.
1) Are there other ways to get around the need to vent my clothes dryer? as fixing this seems like a complete pain (as it is wall mounted)
2) What is the easiest way to vent the dryer? What does it entail? Where do I get the parts? For reference it is mounted to an external wall and next to a second external wall.
Many thanks to whoever responds.
    Top Expert:
  • Dryers Master
  • 45,984 Answers
Simpson may have a kit available for accomplishing this. Also, your dryer may have several optional ways of venting.
Posted on Mar 27, 2017
  • 185 Answers
SOURCE: simpson sirocco 500 runs properly but
is it a gas or electric
Posted on Apr 08, 2008
SOURCE: diagram of how to replace drive belt on simpson
Diagram of how to replace drive belt on simpson
Posted on Jul 31, 2009
SOURCE: Simpson Sirocco 350 Dryer not heating
I repaired my broken fan belt with a drop of super glue - there is virtually no load on the belt and it now works perfectly again. A 30 sec quick fix.
Posted on Sep 20, 2009
  • 17 Answers
SOURCE: My Simpson Sirocco 3500 clothes dryer emits burning smell!
1)check for something stuck between drum and dryer housing 2)check for stuck vent flapper at exhaust opening outside 3) check dryer lint screen
Posted on Nov 06, 2009
  • 70 Answers
SOURCE: Simpson sirocco clothes drier tumbles ok, but heater not working
Bad heating coils, or bad ignitor if gas.
Posted on Jun 23, 2010
Westinghouse dryer LD505E is to be mounted on a brick wall ,what size rawlplugs & screws are needed .I bought the wall bracket mounting kit
that unit does not have wall mounting information its user manual
or a wall mount bracket supplied with that dryer
its a 5KG dryer by the looks of it
thats means its load a with 5kgs of wet clothes on the floor
suggest to me its no meant to be wall mounted
http://laundry.manualsonline.com/manuals/mfg/whitewestinghouse/whitewestinghouse_dryer.html?p=7
wall mount kit might be say suit most dryers
you have to go by common sense
use bigger mountings and fixings that you think it needs
has to hold up on the wall
this much weight
the all up wet weight of clothes
the dryer dry weight empty
and steady any vibration with the rotation on full load
into wood walls depends on the thickness of wood
if into dry wall ...need to hit the wall studs centre
I would not try it
if going into brick concrete ...hammer drill in and . ranset bolts
Sep 16, 2016 | Dryers
Simpson clothes dryer sirocco 455 5kg the power shorts out when we turn it on ?
check the heating element.remove back panel to access it
May 31, 2015 | Dryers
Is it a big job to replace the heater element on the Simpson Sirocco 350 dryer?
It won't be the element unless a wire from it is grounding against the casing. You most likely have some sort of issue with the home breaker.
Mar 15, 2014 | Kenmore 500 6952 Dryer
I have a GE model # DCVH680EJOMS front end loading Dryer and it seems to take multiple cycles to get my clothes dry. I discovered that Water is collecting in the flexible exhaust tubing...not just a...
Hi and Welcome to FixYa. I am Kelly
You already have discovered the problem. Lint has built up in the vent / exhaust ducting. Most of the time the through the wall vent flapper gets lint build up on it outside the house and then as that restricts airflow you get condensation in the ducting. The condensation causes the lint to form a cake like paste inside the ducting. THOROUGHLY Clean out your vent ducting from the dryer connection all the way thru the outside wall and your dryer will be fine. If you need to replace the ducting please do so. Ducting is cheaper than the electricity you waste on clogged ducting. You proved your dryer will work correctly when you dried a load of clothes with the ducting removed.
Thanks for choosing FixYa
Kelly
Sep 27, 2010 | GE DCVH515EF Electric Dryer
Nov 05, 2009 | Dryers
I have 2 simpson sirocco 350 dryers and neither will dry clothes as soon as a bit of heat happens they turn off is there something that I did'nt take out of them when Ifirst got them? Hoping you can help....
difficult one , but drier will typically switch off if the over temp. sensor activates. Suggest you move the drier away from the wall or any area that could block air flow into the air ducts and retest. Very unlikely both would do the same thing. Common denominator is its position..
Sep 14, 2009 | Siemens Dryers
When the dryer is on high or medium heat, it trips the power breaker of the house. it does not do this on air only/no heat", which makes me think of a short in heating unit.
the dryer is run by a universal motor, and these motors (while being very robust) can draw more current if the torque put on the drive train is overloaded. try running dryer with less clothes.
May 12, 2009 | Dryers
Mar 21, 2009 | Dryers
Simpson sirocco 350 clothes drier
Yes fixed with prayers I found the restart safety switch and am now dring merrily,.Paste
Sep 05, 2008 | Dryers
Dryers Logo
115 people viewed this question
Top Dryers Experts
Marvin
Marvin
