Question about Dryers
Dryer makes a loud nosie when running
My dryer make a noise like the brake are going out in a car what is need to make that problem stop
Have the same problem. on a DNXR473EW0WW. Probably the brake is dragging. Am convinced that the centrfiical force which releases the brake is being impeded by lint build-up or the motor has lost torque.
Posted on Dec 20, 2008
2005 ford focus zx4 ac compresser making noise when ac is turned on
Yes, it could be the ac clutch or the compressor itself.
Jul 08, 2012 | 2005 Ford Focus
My 1993 toyota tercel makes a loud knocking noise and does not go forward when I drive it. what is the problem
it would be your driveaxle on the side that makes nosie and depending on how long the knocking nosie has been knocking you might need to also do your wheel bearing also
Oct 25, 2011 | 1993 Toyota Tercel
Hi. My left rear brake is making a very loud nosie when i stop. The same noise continues once i press the gas but only for a short second.
sounds like either your caliper is sticking or your wear indicator on your brake pads is making the sound.
Jun 20, 2010 | 2004 Toyota Highlander
Making loud nosie
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Jul 09, 2010 | Crosley CDE6000 Electric Dryer
Brakes makin nosie
Sounds like a wheel hub assembly is bad without seeing it. Alot of GM vehicles have the ABS wheel speed sensors built into the hub assemblies. Should be able to narrow the noise down by driving the car slightly turn left and right noise should change from loud to soft when turning the wheel. ( if you turn left and noise gets louder hub on right front is noisey.Opposite will occur if left side is bad)
Jul 31, 2009 | 2002 Pontiac Aztek
I have a 99 jeep cherokee sport. When making a sharp turn to the left I hear a rubbing sound coming from the left front tire area. There is currently a light squealing noise when stopping. Are the two...
Probably. Check your brake rotor and caliper. The brake pads may be worn down enough to make that noise. Brake pads are around $29 bucks for a set. And rotors are about the same each at Autozone. I just did mine recently and I am VERY happy now that my 99 Jeep cherokee stops right and doesn't make the rubbing noise when cornering, and the squealing noise when stopping. There you go! Happy Motoring!
Jun 24, 2009 | Chevrolet Suburban 1500 Cars & Trucks
Bmw e46 loud vibration noise from front wheel
usually noise complaint can be pretty tricky to repair. especially if its intermittent. since you say it only when its cold my first guess would have to be a wheel bearing. some other things you can check is how the tires are wearing. when you rub your hand along the tread is it smooth or does the tread catch your hand. if your tires aren't wearing smooth noise complaints can be heard while slightly turning, braking, or even accelerating.also if its a wheel bearing you can lift the vehicle up in the rear (turn off your dsc) and run the rear tires up to speed. usually you can hear a loud wheel bearing. also you can drive the vehicle and swerve back and forth and see if the nosie changes. depending on which side of the vehicle suspension is being loaded
May 03, 2009 | BMW 3 Series Cars & Trucks
Loud nosie coming from rear left drum
sounds like it may be a wheel bearing
Apr 21, 2009 | 2005 Jeep Wrangler
Maytag performa dryer
You may have a bad motor that turns the drum. Have it checked out. Does your breaker trip when it stops running? Last I would check is the timer of the dryer.
Jan 24, 2009 | Maytag PYE2300AY Electric Dryer
Dryer makes a loud noise then stops
If it stops running when hot it may be the motor. The belt or drum rollers would not stop it from running.
Dec 23, 2007 | Maytag LSE7806A Top Load Stacked...
Dryers Logo
100 people viewed this question
Top Dryers Experts
