Question about ASUS A3Ac Notebook
Dear Sir, I have a Asus A3Ac Laptop and I have windows xp installed. My issue is the Cam is not working, even the dirver in correctly installed. when I open the cam is shows blank only. I wish you can help me solve this issue. Thanks allot for your time. Mahir Markos
Unable to instaal windows 7 on Asus A3Ac
if your computer is 5 yrs or older it might not support windows 7 also you will need a minimum of 1 GB of RAM for 32 bit or 2GB of RAM for 64 bit to install windows 7
http://windows.microsoft.com/en-AU/windows7/products/system-requirements
hope this helps
Sep 21, 2012 | ASUS Computers & Internet
Hi, after windows 7 installation,my asus k50 laptop webcam is working head down,also I can't find my webcam setting.
Dear sir/Madam...
The Laptop come with the motherboard installation disc.Use that disc to install your webcamera automatically.if that disc will not work properly then try to download the right driver for your webcamera . Keep in mind, drivers are vary by the versions of Windows(xp,Vista,7). So you search in google.
Ex: asus K50 Laptop webcam drivers
ALL THE BEST
By Ganesh A(INDIA)
Dec 04, 2010 | ASUS Computers & Internet
The SD card reader in my ASUS a3a laptop is no longer working after installing Windows 7. Any ideas?
The windows 7 need updated rivers.Download them from asus.com free!!!!!!!!!!!!
Oct 17, 2010 | ASUS A3Ac Notebook
WHAT IS THE MAXIMUM MEMORY CAPACITY THAT MY ASUS A3AC CAN HAVE? WHAT TYPE OF MEMORY WILL GO INTO THE ASUS A3AC? What maximum hard disk size can the ASUS A3Ac running Windows XP can have?
max memory is 2GB ddr2 533 also known as pc4200.
If you dont have sp1 or later, 137gb is the maximum HD your system will see. If you have service packs installed then you can have as big a HD as you want. You may need to use a disc partitioning program to get the full use out of large HD's
Sep 03, 2010 | ASUS A3Ac Notebook
Webcam failure
Double check you drivers for the webcam to see if they are still working.
Go to control panel, system, device manager (hardware for XP).
Locate your web cam, IF you see a RED X than your driver is messed up or missing.
I would try reinstalling your software for the web cam. Either via cd or go to the vendor's web site.
Sep 25, 2009 | ASUS A3Ac Notebook
Hai sir, Laptop Display Driver Probelm
be sure to get the windows vista driver for your laptop. you may have use the windows xp dirver. if not you can go to http://global.acer.com/support/download.htm
Jan 27, 2009 | Acer Aspire 5720 Notebook
ASUS A3AC HELP
Here are the audio drivers for Windows XP:
http://support.asus.com/download/download.aspx?modelname=A3Ac&SLanguage=en-us
Realize that you also need to load the Microsoft HD audio drivers as well.
Feb 26, 2008 | ASUS A3H Notebook
Audio dirver software for Compaq notebook.
Hi there ajay999
Heres the site for your audio driver(updated)
http://www.soundcard-drivers.com/drivers/137/137369.htm
It says Windows 98 but Also Quates Tested with windows xp and works like a charm have also had this software tested with your model of laptop and also works hope this helps and if u have time please rate me
thanks again
Feb 19, 2008 | HP Pavilion dv6000z Notebook
ASUS A3Ac Notebook Logo
116 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
