Question about Microsoft Windows XP Professional
My operating system not uninstalled
Sir, i have upgraded XP-service pack II by using a self cabinet extractor of service pack 3. now i want to change my operating system but it was not happening. could you please help me to uninstall service pack 3 from my system.
iam waiting for your reply sir.
    Scholar:
  • 162 Answers
Method 1: Use the "Add or Remove Programs" item in Control Panel loadTOCNode(2, 'moreinformation');
  1. Click Start, and then click Run.
  2. Copy and then paste the following command in the Open box, and then press ENTER: appwiz.cpl
  3. Click to select the Show Updates check box.
  4. Click Windows XP Service Pack 3, and then click Remove.
  5. Click Finish to restart the computer after the removal process is complete.
Method 2: Use the hidden $NtServicePackUninstall$ folder loadTOCNode(2, 'moreinformation');
  1. Click Start, click Run, type c:\windows\$NtServicePackUninstall$\spuninst\spuninst.exe in the Open box, and then click OK.
  2. When the Windows XP Service Pack 3 Removal Wizard starts, click Next.
  3. Follow the instructions on the screen to remove Windows XP SP3.
Method 3: Use the System Restore process loadTOCNode(2, 'moreinformation'); Note Before you use System Restore, make sure that you have restarted the computer at least one time after you installed Windows XP SP3. By restarting the computer, you allow for any remaining servicing processes to finish.
  2. Copy and then paste the following command in the Open box, and then press ENTER: %systemroot%\System32\restore\rstrui.exe
  3. Click Restore my computer to an earlier time, and then click Next.
  4. Click the date on which you installed Windows XP SP3, and then click Installed Window XP Service Pack 3 in the Restore Point box.
  5. Click Next, and then follow the instructions on the screen to remove Windows XP SP3.
Method 4: Use Recovery Console loadTOCNode(2, 'moreinformation'); Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base: (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
If you cannot remove Windows XP SP3 by using one of the previous methods, follow these steps:
  1. Insert the Windows XP CD in the CD drive or in the DVD drive, and then restart your computer. When you receive the following message, press a key to start your computer from the Windows XP CD: Press any key to boot from CDNote The computer must be configured to start from the CD drive or from the DVD drive. For more information about how to configure your computer to start from the CD drive or from the DVD drive, see the documentation that was included with your computer, or contact the computer manufacturer. You can also use a bootable floppy disk to start Windows XP. For more information, see the following Microsoft Knowledge Base article: (http://support.microsoft.com/kb/305595/ ) How to create a bootable floppy disk for an NTFS or FAT partition in Windows XP
  2. When you receive the Welcome to Setup message, press R to start the Recovery Console.
    Note Multiple options will appear on the screen.
  3. Select the correct Windows XP installation.
    Note You must select a number before you press ENTER, or the computer will restart. Typically, only the 1: C:\Windows selection is available.
  4. If you are prompted to type an administrator password, do so. If you do not know the administrator password, press ENTER. (Typically, the password is blank.)
    Note You cannot continue if you do not have the administrator password.
  5. At the command prompt, type cd $ntservicepackuninstall$\spuninst, and then press ENTER.
  6. At the command prompt, type batch spuninst.txt, and then press ENTER.
    Note The Spuninstal.txt file appears. As the file scrolls down, you will see errors and the files that are being copied. This is typical behavior.
  7. After Windows XP SP3 is removed, type exit, and then press ENTER.
  8. Restart the computer in safe mode. To do this, press F8 when the computer restarts.
    Note After you restart the computer, the computer may stop responding, and you may see a black screen. The mouse will work. In this case, restart the computer again by turning the computer off and then back on. The second restart will let you log on.
  9. When the computer restarts, Windows Explorer (Explorer.exe) does not run, and the Windows icons and the Start button are unavailable. To resolve this problem, follow these steps:
    1. Press CTRL+ALT+DEL, and then click Task Manager in the Windows Security screen.
    2. Click File, and then click New Task (Run).
    3. In the Open box, type regedit, and then click OK.
    4. Locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\RpcSs
    5. In the details pane, right-click ObjectName, click Modify, type LocalSystem in the Value data box, and then click OK.
    6. Restart the computer
  10. Use one of the previous methods to remove Windows XP SP3 from your computer.
Posted on Nov 25, 2008
  • 62 Answers
What is the system doing when you try to change the operating system?
You should be able to uninstall the SP in ADD/REMOVE Programs.
Posted on Nov 24, 2008
What is service 3?
if your question refers to service pack 3 it is that lastest upgrades to the original operating system
for example win xp came out as win xp
later on in it's life a service pack 1 then 2 and finally a service pack 3 was issued where by all the updates were in a pack so that if you had win xp disc and installed it , then you could install service pack 3 and the operating system was up to date
xp is now no longer supported by microsoft and is rapidly falling out of service
win 7 is now up to service pack 1 ( last time I looked ) but with the large amounts of installing up dates , it may be around pack 2
.with the release of win 10 , win 7 will be no longer supported after a period of time
Mar 05, 2016 | Computers & Internet
Tip
Upgrading Windows XP
Most users of Windows XP are using Windows XP service pack 2.
You can upgrade Windows XP service pack 2 by installing plain service pack 3.
This will upgrade and improve functionality to your current installation to Windows XP.
There are alot of versions of Windows XP Service pack 3 but i recommend downloading an official version from Microsoft's downloads center through the link below.
To after download is complete, install the file. Installation takes about 10 to 30 minutes depending on your system specifications.
If your current installation of Windows XP has too many errors, installation of service pack 3 may not be successful.
The solution to this is to reinstall your Operating System (OS) using your OS installation CD, then install Service pack 3.
How ever, OS re installation will erase all your data in your system partition so back up all your data.
To download an official copy of Windows XP service pack 3, follow this link:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en
on Jan 07, 2010 | Computers & Internet
Mishraji your the besttttttttttttttttttttttttttttttt
Service Pack 2 (SP2) appeared on 2004-08-06. It is an important upgrade and should be installed on all Windows XP computers. The same is true for Service Pack 3 (SP3), which appeared on 2008-05-06.
However, due to the general tightening of security, there is the potential that some security measures interfere with special functions you had been using on your computer, and you may have to loosen some security settings accordingly. Given the complexity of some Windows XP installations, there is also always some potential for some other defect to show up.
List of fixes included in Windows XP Service Pack 2
http://support.microsoft.com/kb/811113/
Available disk space is used as follows (LIS = Local Install Source, the install files remain on disk; CAB = files of type .cab, cabinet).
Free disk space Features 600 MB Minimum for safe installation
(and safe operation of Windows XP) < 1.5 GB No LIS 1.5 .. 2 GB LIS and used CABs > 2 GB LIS and all CABs A general advice, particularly after changing hardware, is to power everything down, including any routers, cable modems, switches, hubs, and the like, wait 10 seconds, then power them up again. Rebooting without powering down is not enough in some cases.
Your problem may not be related to Service Pack 2 at all. If you have the firewall set up properly, but still have network problems, continue with the Windows Network Problem Solver page.
Microsoft offers free technical telephone support for Service Pack 2. In the US call (800) 936-5700 and press 0 to get to an operator. Ask for technical support on SP2.
This article does not generally cover installations running a third party software firewall. If you want to rely on the information given here, you have to completely uninstall any third party firewall software first.
Feb 14, 2011 | Microsoft Windows XP Professional With...
I have two problems with my HP compaq 6830s running VIsta business SP2 1) My inbuilt web cam stopped to work, and i have tried to uninstall and reinstall drivers with no luck. 2)The wireless card,...
If you upgrade your operating system like from windows xp to windows vista, you need to install new hardware driver for your computer like for LAN, webcam, WAN and others because the old driver is only compatible with the old operating system and not with VISTA operating system. Solution would are, download webcam and WAN driver for Windows Vista and install it into your computer. Don't just upgrade your computer because the configuration is not the same with the old operating system. If problem still exist, just upgrade the service pack from 2 to 3. There is available install for upgrading the service pack of each operating system. and surely all your hardwares will function.
Dec 29, 2010 | HP Compaq 6830s Laptop
Keep getting stack overload. line 0
Your browser is corrupted, reinstall it.
Jul 11, 2010 | Dell Inspiron 1720 PC Notebook
About service pack 3
Open this link and download the XPS file to upgrade to Service pack 3
http://www.microsoft.com/downloads/details.aspx?FamilyId=68C48DAD-BC34-40BE-8D85-6BB4F56F5110&displaylang=en#filelist
Jun 30, 2010 | Microsoft Windows XP Professional
Product key for xp sp 3
You dont need a product key for Service Pack 3 to upgrade from service pack 2.
You can simply download an official copy of Service Pack 3 for Windows XP from Microsoft's downloads center.
Follow the download link to download Service Pack 3, then install it.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Thank you for using Fixya,
Kenneth.
Jan 18, 2010 | Microsoft Windows XP Professional With...
Removal of incomplete, unwanted os setup
Hey sorry about your pc sir..
OK first let me explain to you the problem you are having and the various ways we can solve it ..
ok the reason some of the files were removed is cause they were infected..
The cd you have is windows Xp, but during windows updates you updated with service pack 2, so obiously the system will ask for windpws xp cd with service pack 2,, (MICROSOFT BUGS :( )
now you have a mbr with 2 operating systems. cause the main mbr is non functionaly a secondary oe was created leaving your current file system intact, but with the bad effects of having 2 operating systems on the same partation.. hence slow sloppy behaviour..
we can remove boot sector and rewrite mbr to remove the bad operating system but that would not help the speed..
Here is what i believe is your best solution and the one i recommend..
1.) BURN all your important data to a dvd or cd so you wont loose it
2.) Boot off the the windows xp cd.
3.) delete the entire partation and format the drive(full format)
4.) reinstall windows and drivers and software..
NB.. when windows ask if you want to repair select no and install a fres copy,, when it ask if you want to leve the file system intact say no, delete the partation, and it will say unpartationed space, hit enter there and select full format..
Jan 14, 2008 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional Logo
148 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
