Question about Canon DC100 DVD Camcorder
Canon DC100 - Finalizing Problems
I got a Canon DC100 camera for Christmas and just finished my first DVD. I can't figure out how to finalize it so I can view the DVD on a player. I can see the Finalize option within the menu but cannot select it. I'm wondering if I did something wrong during the DVD initialization process that has goofed me up. The users manual doesn't have a troubleshooting section for this problem - only directions on how to finalize. Any thoughts or suggestions? Thanks
  • 8 more comments
  • Cindylou352 Dec 17, 2007
    I bought mine over a year ago and have taken video, but don't know how to close or finalize the DVD. I have a wedding to go to and vacation footage that I would like to show my family. HOw the hell do you finalize these DVD's?????
  • Anonymous Dec 27, 2007
    same problem....but i found out all you have to do is plug-in your camera to the wall outlet...DC adapter...
  • Anonymous Jan 05, 2008
    I have the sem problem
  • Anonymous Mar 15, 2008
    Lost Manual. Seek Replacement. Canon DC 100 DVD Camcorder
    George Savas
  • Evem May 04, 2008
    I have the same problem and have it plugged into the wall outlet. It still refuses to finalize.
  • lost tech Jun 12, 2008
    I have owned my Canon DC100 DVD Camcorder for over a year. I have yet to watch the first video. I work at the store where I purchased and no one can help me to figure out how to finalize my DVD. A customer came in today because he had the same problem. He had the newer model. I called Canon support after working with his camera for about 15 minutes. They walked him right through to finalize. I came home and tried the same things but I am having no luck. I can't find my book because I have had it everywhere in my house this past year trying to figure this out. I get to the place where it says to finalize but nothing happens. I have it plugged in. I am at my wits end.
  • Henry VII Jul 15, 2008
    http://software.canon-europe.com/files/s...
    Manual doesn't mention the need of having the unit plugged in to wall, which solved my problem after giving the disc a title as well. If last entry is a picture it might also present a trouble. Add short recording and try again. I've only tried finilizing in playback mode however. Recording mode might not work, dunno.
  • 501sttrooper Aug 13, 2008
    I have some video that I really want to get polished up and into my podcast but I can't finalize either. I have it plugged in, but the option is black instead of white and it's unselectable. wtf?
  • Anonymous Dec 31, 2008
    i did the finilizing part but when i put it in my computer it still wont work
  • Mohit Gupta Nov 27, 2012
    Yes , to finalise have to plug the camera to wall socket, probably to ensure solid power supply.
Thanks I got it plug-in the camcord to the wall outlet with DC adapter then you can start the finalizing thanks again
Posted on Sep 08, 2008
Plug it into the wall...(outlet) while you finalize it... set the camcorder down on the ground in the procces becasue if it is shaky it will mess up the video(s)
Posted on Oct 27, 2007
  • 33 Answers
I have contacted cannon about this issue, the answer is exactly what most users are saying. This is what was said to me.
Follow these steps:
- Plug the unit into the wall (Using the charging adapter)
- Go into the media browser (Pull the on/off switch to mode while in recording mode)
- Press the 'Menu' button (Chrome button located just above the LCD screen)
- Press the 'Right Arrow' on your focus control (Round button that circles around the OK button)
- Press the 'Down Arrow' on your focus control until you reach "Disc Title" and press the 'OK' button (Skip this next step if you already have named your disc)
- Using the focus control arrows and the 'OK' button, set a title for your disc. (When finished select SET and press the 'OK' button)
- Next, Using the focus control arrows, select "Disc Finalize" and press the 'OK' button.
- The DC100 will then display the time it will need to finalize the disc. If you are able to place the camera down where it will not move, press 'OK' (Dont worry it gives you a few seconds to place the camera down)
- Place the camera down on a flat surface with the LCD screen's side facing up (You don't have to close the LCD screen)
- Finished. :-)
If you are unable to finalize the disc using the following steps, then you have one of two problems.
1. You have a bad disc
2. You set the disc to 'Read Only' using a computer with a DVD writing drive.
Posted on Feb 11, 2009
Yeah, i have been having the same problem as well. One thing i found quite helpful is to to initialize the disc while the main power adapter is on.
Then when you come back to finalize it also the main power should be plugged in. I found in that case the finalization.
The finalization process is as earlier posted by Shadowmaru
Posted on Oct 23, 2009
After posting on May 4th, 2008, I did some further research on the web and realized the problem for me was a bad disk. I have since finalized many other disks.
Posted on Oct 05, 2008
You are abosultely right. must plug in. but i have to say that this makes the use of the camera retarted. i have to carry around an adapter just to finalize the disc to watch it in my dvd player. great. nice little camera ruined because i have to carry around gear.
also no mention of this obvious canon flaw in the manual. they makr good cameras but dropped the ball on the dc100.
You need to plug the camcorder in while finalizing.
Posted on Feb 13, 2007
SOURCE:
How do you finalize disc in a dc100
To finalize the disk:
Select MENU --> then select: DISC OPERATIONS then select: FINALIZE then select: YES ... to go back to MENU
During the disk finalization, a progress bar is displayed. Close the MENU only AFTER the screen display returns to the DISC OPERATIONS menu
Feb 26, 2011 | Canon DC100 DVD Camcorder
I want to transfer my DVD's taken with a DC100 Canon video camera to computer files to share on Facebook & other social networking sites. But I have no idea how to get them from DVD to computer file...
please make sure to finalize the disc before inserting it to the computer.
steps:
1.go to media browser(its the mode where you playback recorded videos)
2.press menu button
3.pres right directional button
4.press down directional button and look for the "finalize" option and press ok
note: plug the camcorder to walloutlet during the process and avoid vibrations and movements with the camcorder. it would be better if you place the camcorder on a stable surface during the process.
-wait until finalization finishes and then insert the disc to computer and then copy the videos to a folder in your computer and so that you can upload them to facebook.
Sep 11, 2010 | Canon DC100 DVD Camcorder
Can't transfer video from dc100 dvd to conventional dvd
Are you trying to transfer the video to a computer to then burn to a dvd? Make sure before you put the disc in any other device, that the disc is finalized.
Apr 21, 2010 | Canon DC100 DVD Camcorder
I just bought new discs for my Canon DC100. The
It's possible that, for some reason, the disks aren't compatible. It can almost drive you crazy trying to figure out why. To find out for sure if this is the case, try some new Panasonic discs, with the same specifications as the old ones that worked, and see if they work. If they don't work, you're probably having a dvr issue with the laser lens or related parts within the camera. There are many issues with dvrs that develop over time, requiring replacement parts and service. In those cases, it's usually better to get a replacement camcorder. The new HDD camcorders are immune from a lot of problems inherent with dvr and tape recorders.
Apr 18, 2010 | Canon DC100 DVD Camcorder
Canon dc100 will not finalize memorex disc, which says it can be used in canon
make sure the power adapter is connected, you can not finalize on battery power alone. also make sure you are in playback mode...it will say original in the top left corner..then you should be able to finalize when you go into the menu
Apr 10, 2010 | Canon DC100 DVD Camcorder
I'm trying to load a disc onto my computer but it keeps saying the disc is corrupted. How can that be?
It could be. Try intervideo.com. Thats a good DVD program. If you have an ATI video card in your computer, you might have a DVD for their player as well. Either way both programs will provide you with a DVD decoder for playback as well.
If you didn't finalize the DVD after you recorded it, that error can happen as well. It can by fixed by reinserting it back into the DVD Camcorder and finalizing it.
Jun 14, 2008 | Canon DC100 DVD Camcorder
Canon DC100 DVD
MAKE SURE ITS A DVD - R OR -RW IF CAMCORDER WILL NOT RECOGNIZE +R OR +RW IF ITS AN RW MAKE SURE YOU INITIALIZE IT
Nov 22, 2007 | Canon DC100 DVD Camcorder
Finalizing a disc (when plugged in) on a Canon DC210
I think it is a problem with the camera.
We had one, couldn't finalize, exchanged that, and still the same problem.
Canon NO help whatsoever.
Even the mini disc companies that we purchased, NO help either.
We are returning this camera and going with a hard drive.
We were able to plug the camera to a DVD recorder and copy onto a full size disc.
Oct 30, 2007 | Canon DC210 DVD Camcorder
Instruction manual
i had the same problem. you may have plugged your power supply into the a/v slot near the function button..that is what i did. there is another place near the lens to plug it in. try that and then finalize should be an option.
Aug 13, 2007 | Canon DC100 DVD Camcorder
Finalzing my disc
you can only finalize a disc in the dc100 with the power adapter on. (page 59 instruction manual)
Aug 01, 2007 | Canon DC100 DVD Camcorder
Canon DC100 DVD Camcorder Logo
4,276 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
