Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
Belkin 54 encryption
I have a belkin 54 to which my PC is attached and a laptop which gains internet access through the wireless connection. My system is not encrypted and I need to do this. Would someone be able to tell me how I can apply encryption?
Paul I have a Belkin54 installed in 04 (expires August 2038). One of two computers using the connection crashed and the Windows 98 was reinstalled in the Dell by Staples. I have Windows just fine but I cannot find the original Belkins info which I think was a disk. I have copied most of the data from the still attached computer and I have the original 13 pairs of the code that I think I used to access the Belkin's wireless. Is there a means of getting instructions, downloads, or re-installing Belkins54 access in the refurbished Dell????
  • Gateway Master
  • 4,806 Answers
Firsty you have to connect the router diectly to a pc via an ethernet cable, once you have connected the two and made sure that the router is not connected to the modem, open a web page, in the address bar at the top of the window type http://192.168.0.1 and hit enter, this should bring the router access page, password is usually "belkin" or "admin" (lower case) you can then go into the settings and set the security up you desire
belkins default user name is your isp user name in some routers!!
regards
Posted on Nov 24, 2008
    Genius:
  • 1,550 Answers
Have a look over the link below
Belkin encryption
Steps are provided there to encrypt .
    Sergeant:
    Champion:
  • 347 Answers
Open your internet browser and type: http://192.168.2.1
Then you have to search for the option to set up a password.
When it ask you if you want a WEP or WPA password you wil have to decide that.
(WEP are easy to "hack" so, i recomend you to select WPA. It will be a longer password but it will be safer)
Good luck,
Dahaka
    Sergeant:
  • 276 Answers
But do you have the software cd of the belkins with you.
How to use router without using wifi in belkin n150
This model Belkin wireless router has 4 LAN ports so you can connect a LAN cable from this wireless router to your computer.
I suggest you disable the wireless in the router so no one can access your network and Internet. If you cannot disable the wireless then you can setup WPA2 encryption to secure your wireless network or just remove the aerial off the wireless router.
Mar 05, 2013 | NetGear WGR614 54 Mbps Wireless Router -...
I have a belkin.4bda router connected to my laptop from my pc which normally works very well, however from time to time my laptop will not allow me to connect to the internet saying that my security key...
The PC connects to the Internet because it uses a network cable that is attached to the router.
The laptop connects to the router with a wireless connection, you most likely have enabled encryption on the router's wireless settings and if the laptop's wireless card has not been configured with the router's encryption settings, then it cannot connect to the router via the wireless until you enter the encryption (security) key.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jan 01, 2011 | Belkin Basic Wireless Router
My router does not show wireless signal just wired
Your computer cannot detect the Belkin if the wireless card in the computer has not been configured with the Belkin wireless settings.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your computer/laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
Dec 24, 2010 | Belkin N1 Wireless-N Wireless Router
Belkin router problems
Its not necessary to purchase a new router. Nintendo DS supports WEP encryption. You wont be able to connect if the encryption on the router is WPA. Your computer can connect on both WPA and WEP so what i suggest is for you to access the router page then check the wireless settings then change the encryption to WEP so that your Laptop and DS can connect at the same time. To access your router check the manual for the username and password
Thanks for using Fixya.
Aug 03, 2010 | Belkin (F5D5231-4) Router
Trying a add another desk top to an existing Belkin wireless G router at home. Right now there's a desk top and laptop working off this router.Try several times and still can't connect to internet.
Make sure the Belkin wireless is the only device directly connecting to your internet service provider's router/modem. Usually that port is labelled "WAN" or even "Internet". The Belkin should have extra ports/jacks for WIRED connections, right? You then connect the PC into the other remaining ports/jacks on the Belkin (if they're wired) or just use the wireless for the laptop if the laptop has wireless. After getting the wireless going, though, you should lock it down by using WPA encryption key if possible.
Feb 24, 2010 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D7050) 802.11a/g/b Wireless Adapter, home networking. I am on AOl using Thomson speedtouch, I am trying to link up 2 pc's and one laptop to access the net. Main Pc is Vista - with wireless...
try to reset the wireless router to factory default.( with out encryption). connected the Xp first. then the other two.
try to use simple encryption (8 characters).
Oct 12, 2008 | Belkin Computers & Internet
How to set up my belkin adsl modem with built in wireless router (8o2.11g/54 mbps) with my broadband connection?
There may be a set up wizard disk with the router so you can put in your broadband account details etc to get you running.
The wireless side of things will almost certainly require you to use a cable to connect you PC to the router and log in using internet explorer
Post the model number of the router so I can assist you in more detail
Jul 19, 2008 | Belkin Computers & Internet
Belkin Wireless Router
1. you need to put the software belkin installation disc into the girls laptop not just the desktop.
2. you need to plug the modem back in
3. on the back of the router press the little button NOT THE RESET BUTTON MAKE SURE IT IS THE LOCK BUTTON it will ask you for a password on the laptop
May 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
1. Log into your Wireless Router or Access Point.
Open your web browser and type in the IP address of the Wireless
Router or Access Point. (The Router’s default is 192.168.2.1, the
Access Point’s default is 192.168.2.254.) Log into your Router by
clicking on the “Login” button in the top, right-hand corner of the
screen. You will be asked to enter your password. If you never set
a password, leave the password field blank and click “Submit”.
Click the “Wireless” tab on the left of your screen. Select
the “Encryption” or “Security” tab to get to the security
settings page.
2. Select “128-bit WEP” from the drop-down menu.
3. After selecting your WEP encryption mode, you can type in
your hex WEP key manually, or you can type in a passphrase
in the “Passphrase” field and click “Generate” to create a WEP
key from the passphrase. Click “Apply Changes” to finish. You
must now set all of your clients to match these settings. A hex
(hexadecimal) key is a combination of numbers and letters from
A—F and 0—9. For 128-bit WEP, you need to enter 26 hex keys.
For example:
C3 03 0F AF 4B B2 C3 D4 4B C3 D4 E7 E4 = 128-bit key
4. Click “Apply Changes” to finish. Encryption in the Wireless
Router is now set. Each of your computers on your wireless
network will now need to be configured with the same
security settings.
May 09, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
