Question about Thermador SC272T Electric Double Oven
Dimming temperature and clock light on display window
The light on the display window indicating temperature has become steadily dimmer and is now almost unreadable. Clock lights are also dimming. The oven reaches the desired temperatures, so the thermastat and oven function are OK. We have recently been baking bread at temps of about 550 degrees. Could high heat have affected the lights? Oven instructions do not address replacement of bulbs on the display window.
  • 1 more comment
  • drharding Nov 19, 2007
    I have the same problem twice now. I called Thermador directly and they were not very helpful. This is only 3 yrs. old and we had it fixed 6 months ago and now again. I NEVER cook either so it is a defective light somehow...HELP---I can barely see what temp. I am cooking at or the time....
  • gre3 Sep 01, 2008
    I have had the same problem, dim display and temperature. The display has been replaced three times or about every 8 months since the first time. Thermador paid the three times but it is out again and they are not going to warranty it this time even though the last one was put in only 7 months ago. I cannot believe a company like thermador cannot fix this problem. Guess I will try another brand in the future.
  • sillygirl4 Apr 06, 2009
    We replaced the light panel two years ago and it is happening again. Only now they say they are not manufacturing the parts!!!! Thermador seems to think it is OK to stop making parts for items over 4 years old!!! that is insane.
I found capacitor c3 (68 uf 35 volt) had leaked and dried up, causing the display to fail. I unsoldered and tested c1, c4, c7, and made sure they were good, using a digital multimeter with the ability to test capacitors. C3 also had visible signs of leakage. Works like a charm again, and the display is bright like new!
Posted on Jul 15, 2009
Is this straightforward to replace yourself? It isn't obvious to me how to remove the panel cover/touchpad. Does anyone have instructions on this repair?
Posted on Oct 12, 2008
I had the same problem, I think it took place when my cleaning person washed it as the motherboard and lcd have very little protection form the top of the oven.. where it would be wiped down
Posted on Nov 12, 2007
We are ordering our 2nd replacement from Thermador for our SC272T oven. You need display part number 492071, approx. $220.
Posted on Apr 12, 2007
We had this problem and had it fixed under warrenty with a new mother board before 2 years. But it has happened again now we are at 7 years. (no warrenty this time!) I am hoping to find the part and see if we can replace it ourselves. Will see and get back to you.
Posted on Jan 13, 2007
2 Suggested Answers
SOURCE:
jack_daniels
  • 304 Answers
SOURCE: Dimming temperature and clock light on display window
Check for the fuse on the panel board.
Posted on Apr 16, 2008
Gaggenau oven display clock unreadable.
The display may have to be replaced
Sep 01, 2016 | Gaggenau Ovens
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
How do i operate the self cleaning function
Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
Fault codes F1 and F2
Just two work there:
1.- Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock.
2.- Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Parts replacement coudl look in www.repairclinic.com
Hope helps.
May 02, 2011 | Magic Chef Ovens
Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
May 31, 2009 | Jenn-Air JJW8530C Expressions Collection...
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
Display too dim to see
I purchased a new clock module off the internet to try.
Mar 22, 2009 | Jenn-Air JJW9530C Stainless Steel Electric...
mY 27" WALL jENN air blows cold air out the vents when on cleaning cycle. The red buttons aren't lighted. The door locks, otherwise it bakes fine. I wonder if it is really cleaning?
Feb 16, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Display light faded and now gone
Supposedly the electrolytic capacitors on the display board need to be replaced. See: http://applianceguru.com/forum1/18842.html
Jan 15, 2009 | Thermador SC302T Electric Double Oven
Thermador SC272T Electric Double Oven Logo
1,441 people viewed this question
Top Thermador Ovens Experts
Marvin
Marvin
Sal De
Are you a Thermador Oven Expert? Answer questions, earn points and help others
