Question about Caliber Tech Force Pellet Rifle Model 34 .22 With Scope
Cross hairs keep turning
My cross hairs keep turning on me after 4or5 pellets shot .need to find someone in my area who could repair yubacity,calif 95991
530-713-0435
    Problem Solver:
  • 8 Answers
I don't shoot BB guns, but I looked up your gun/scope combo. It' a $65 Chinese product. At this price level you cannot expect a decent scope or rifle. It just can't be done. The scope will not be worth fixing.
Posted on Nov 26, 2008
I have a Sheridan blue steak that need the tube assembly replaced or repaired. Is there a replacement for this. I have the part number from the handbook.
Contact the authorized repair facility in your area. It is listed in the back of the manual By Blue Streak I am assuming you have a C9 which is .20 caliber. They will direct you as to what can be done to fix or repair your air gun. I have a Benjamin Sheridan C9 Blue Streak from circa "95" when they still ad walnut stocks. I have shot maybe 20 pellets out of the 500 rounds in the red Diablo pellet box I bought with it. Paid a hefty $170 or so for it new. It is still like new. Bought a Beeman .177/.22 switch barrel barrel cocker. I hate all the pumping.
Feb 28, 2015 | Crosman Benjamin Sheridan 392 Air Rifle...
How do i take a screenshot
Command-shift-3 will take the whole screen
Command-shift-4 gives you a cross-hair so that you can select a smaller area.
The pictures are automatically saved on the Desktop with a name like:
"Screen Shot 2014-07-27 at 11.57.31 AM"
Jul 27, 2014 | Apple iMac Computers & Internet
My daisy powerline 201 bb gun has jamed up what can i do to fix it?
If it is stuck in the pellet hole just put a magnet over the hole boom pellet out
Sep 26, 2011 | Simple Shoes Daisy 4x Bb Gun Air Rifle...
Which direction do you turn windage and elevation
To raise the point of impact, turn the elevation screw counterclockwise. To shift left, turn windage screw clockwise. If you raise the horizontal cross hair you will lower the point of impact of the bullet. If you move the vertical cross hair to the right the shot placement will go to the left. Make small adjustments tap the scope with a screwdriver handle to give it a shock, not to hard to help move the cross hairs and try to bore sight first. Hope this helps Fix ya up.
Jun 22, 2011 | Tasco 22 Riflescope
My bsa sweet 17 6-18 is shooting about 2 inches high at 100 yards. on the adjustment turret it has an arrow that shows which way to turn for up. What is moving up? the point of impact relative to the...
Jun 02, 2011 | Bsa Optics Sweet 17 Target Riflescope...
How to sight in crosman extreme g1 pellet rifle scope
You would sight in an air rifle scope in the same manner as any other standard scope that you might find on a rifle:
You want to secure the rifle as best you can with the sights pointed towards a target, which should be set at the desired distance.
Reduce the error of your sight adjustments either by mounting the rifle in a gun mount or simply resting the stock (not the barrel!) on a solid surface such as a table.
Make sure that the weight of the rifle is carefully supported and the **** is firmly pressed into your shoulder. Looking through the sights, aim at the very center of the target (which for your purposes can be as simple as a piece of paper with a dot drawn in the middle).
Take time to ensure a careful shot, and be sure to avoid any shaking, utilizing the support of the mount/table (try resting the fore-grip of the stock on a roll of paper towels if you're having trouble keeping the rifle steady).
Once you are confident with the placement of the cross-hairs over the center of the target, gently squeeze (don't pull) the trigger.
Determine where the pellet struck the target, and adjust the scope accordingly; while every scope is a little different, the same basic principles for adjustment apply. Unscrew the caps on the top and side of the scope, and carefully read the markings on the adjustment dials.
If the pellet struck low, twist the dial on the top of the scope 'up' (the markings should specify clockwise/counter), and if the pellet struck high, twist in the opposite direction. If the pellet struck to the left or right, follow the same procedure for the dial on the side of the scope.
If the pellet struck low and to the side, make the vertical (up/down) adjustments first, repeat the shot, and only move on to make adjustments left/right once the pellet strikes in vertical alignment with the center of the target.
Take your time, and adjust in increments of only 2-3 clicks to start. Repeat the procedure until the pellets are striking consistently in the center of the target (if you're having a hard time remembering which shot went where, replace the target and continue.
Once you are satisfied with placement of your shot groupings on the targets, replace the dial covers on the scope.
Tips and Notes:
- In order to maintain the accuracy of your rifle, try to avoid resting the rifle on its scope and try to prevent the barrel from contact.
- Take note of your rifle's range, and be aware that the further away you place the target, the less consistent your results will be.
- Be realistic; don't attempt to sight in an air rifle at 50 yards. Remember that even with a rifle that has been professionally sighted, good results still come down to the accuracy of the shooter.
-Sight in your rifle at a range where you are confident in your own abilities; start with a closer target and only move back (i.e. sight in at a greater distance) if necessary.
Further Instruction:
http://www.chuckhawks.com/sight-in_rifle.htm
http://www.youtube.com/watch?v=lLirsAFpsfE
May 05, 2011 | Sport & Outdoor - Others
How do you make adjustments, towards the shot or towards center of the target?
You move the cross hairs to the shot. Set up your gun on a bench and start by firing at a target out at about 15 yards. Once you are "on paper" set your cross hairs on the center and fire a 3 shot group Adjust the scope to the group. if the group is down 3 inch and left 4 inch. Adjust your scope accordingly. Then Fire another 3 shot group, until you are shooting center. Every time you adjust your scope tap the barrel of the scope with a screwdriver handle to keep the cross hairs from sticking. Once on at 15 yards move out to your max range and adjust to that.
Mar 19, 2011 | Brunton 2x20mm NRA Sports Optics Rifle...
When I raise the cross hairs on the scope on the graft the bullet goes down and when i lower the cross hairs the bullet goes up is this correct. When I bought my pursuit boar sight from Basspro I only...
That is right. If you had the rifle held in a vice aimed at a particular point and without moving the rifle you raised the cross hairs you would now be aiming above the point. To get your aim back onto the same spot you would have to loosen the vice and lower the barrel of the rifle. This would mean that the next shot would hit the target lower down. The same is true if you lower the crosshairs which means the bullet would rise.
Likewise moving the crosshairs to the left brings your shot to the right and moving them right brings your shot to the left.
Sep 15, 2010 | Sport & Outdoor - Others
Cross hairs sideways?! BSA scope HM39X50RGBD Only 50 shots threw new Gamo Socom Extreme. Gun came with scope pre-installed.
If you are seeing an X you need to loosen the scope rings, re-level your scope and re-tighten the scope rings. 10-20 in/lbs on the ring screws, 15-30 in/lbs on the mounting screws. Typical configuration of the turrets is one on the top, one on the right side.
Mar 21, 2010 | BSA Optics
Crosshairs look like an x instead of a cross got back from ABO repair for stripped tube, where eye bell fits on. they said they changed the tube. I shot about 50 rds with it when problem developed tasco...
You can get to the cross hairs of a scope, but not much further without some special tools. Take off the rear lens, just unscrew the whole thing, and you will see inside there a ring with slots in the side? A small screwdriver in one of the slots should spin the threads out. You should be able to remove the cross hair tube, inside of it on the front, you should have another lock ring with the slots, spin the cross hairs straight and lock them down. This is a basic scope, I'm sure they are all different, but basically the same. Try it. You cant hurt it, it's already broken, and you will have to send it back out again if you fail. I don't know what they charged you, but there is a guy on ebay advertising scope repair, $45, all scopes.Hope this helps.
Oct 02, 2009 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Caliber Tech Force Pellet Rifle Model 34 .22  With Scope Logo
324 people viewed this question
Top Caliber Optics Experts
George Merkley
George Merkley
obsteiner
john h
Are you a Caliber Optic Expert? Answer questions, earn points and help others
