Question about Sub-Zero 690 Side by Side Refrigerator
Need to change the light bulbs
Sub Zero 690 side by side refrigerator, need to change the light bulbs
  • Anonymous Mar 23, 2014
    what is the part number
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
The light shield has two tabs, one on each side. They may be on the front or back of the shield, It fits either way. Pull the tabs down and slide the shield back and forth a couple of time and it should drop from the four pegs that hold it in place. You will have access to the bulbs. You can go to http://www.subzero.com/locator/locator.aspx?type=0&zip=02030 and find a parts distributor near you or take a bulb to the store and match it. Make sure you get the same wattage rating.
Posted on Dec 03, 2008
Sub zero 690 side by side
Behind the panel and the control unit are light bulbs, They made need to be replaces. Good Luck
Jul 30, 2014 | Sub-Zero Refrigerators
How do you install or change the water filter.
If you model Sub Zero 690 has a filtration system this is what to look for. Thanks John Tripp Appliance 911
Contact Me Here
Sub Zero 690 Service Manual
Sub Zero Installation User Manual
CONTACT INFORMATION Sub-Zero Customer Service:
800-222-7820
Website: subzero.com
E-mail Address: customerservice@subzero.com
Jul 07, 2014 | Sub-Zero 690 Side by Side Refrigerator
On sub zero 690 like to change bulb in lighted electronic control panel
you will have to remove the light shield, remove the plastic trim that says the model number in front of the light shield, then the 2 screws holding the side cover on the left side of the fridge section. Then the cover will need to be pushed towards the rear of the fridge then tipped out at the front. It has springs holding it in the back.That should access the bulb you need to change
Nov 07, 2013 | Sub-Zero 690 Side by Side Refrigerator
Changing the light bulb on display control panel
The bulb is located behind the panel under the light cover and this unit takes four bulbs to light up the refer section. The bulb you seek is directly behind the display and computer unit mounted to the celling of the refer section.
Good Luck
Nov 01, 2013 | Sub-Zero 690 Side by Side Refrigerator
My sub zero 690 has the fridge & freezer light out as well as the screen
Well the most likely cause is 2 bad door switches, though I rarely see the door switch go bad in the freezer. At the top of the door openings you will see 2 switches in the freezer and the fridge. If you pull down the grille and remove the cover over those switches, the light switch will be the one with the white back, and the fan switch will be the one with the black back. I would try changing the switch in the fridge, and maybe start in the freezer by changing at least 1 bulb before blaming the switch. If that 1 new bulb doesn't light, change that switch too.
Mar 24, 2013 | Sub-Zero 690 Side by Side Refrigerator
Light went out on refrigerator side
Your Sub-Zero unit contains standard 40 watt appliance bulbs in all compartments.
You'll need to remove the light shield in the top of the refrigerator or freezer to replace the bulbs. Place your hands under the light shield and release the two clips on the back of the light shield, then lift up and slide back slowly until the key slots on the side of the light shield drop past the mounting studs in the side walls. Then remove the shield.
The bulbs are now accessible.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Oct 27, 2011 | Sub-Zero 690 Side by Side Refrigerator
The light on the refrigerator side of my Sub Zero does not work
The light switch at the top of the door frame is bad. it controls all the lighting including the display for the board. you will have to remove the grille up top, remove the cover over the 2 switches, and replace the switch that is all white. the one with a black back is for the fan and rarely goes bad. Just unplug the unit or at least turn it off before changing this switch, as it is live any time the unit is turned on.
May 05, 2010 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 690 Side by Side Refrigerator light switch intermittent
This is a common problem - replace the left light switch with Sub Zero Part # 3060140.
Nov 25, 2009 | Sub-Zero 690 Side by Side Refrigerator
Fridge side light is off. fridge works
check if your bulb is busted, have it replace
Nov 14, 2009 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 690 Side by Side Refrigerator Logo
660 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal De GO PATS
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
