Question about Bose SL2 (17817393904) Wireless Adapter
SL2 Receiver does not light up/rear speakers do not work
SL2 receiver does not light up. All connections are secure. Transmitter blinks. We tried resetting both, transmitter first, then receiver, to no avail. The rear speakers are dead and no light is on the receiver. Help! :)
  • 1 more comment
  • armyofJZ_759 Dec 22, 2008
    I connected the Bose Lifestyle home system with the SL2 wireless link for the rear speakers. Initially the wireless setup worked perfectly with sound coming out of the rear speakers, but, after finally installing all of the A/V connections, the rear receiver was no longer receiving a signal from the transmitter. Transmitter is trying to establish a connection (flashing green light), and receiver is in power save mode (solid orange light). I have checked for secure connections, powered on/off, and used the reset button located on the bottom of the transmitter/receiver bases, but still no action. NEED HELP ESTABLISHING A CONNECTION AGAIN!!!!
  • khareaa Feb 16, 2009
    SL2 transmitter is not able to connect to the receiver. The transmitter light stays flashing green. Any help would be really appreciated.
  • Anonymous May 06, 2009
    My read speakers were working just fine, great I may add. Currently is not working, but found a way to go around. If I switch from the Cable source or DVD when is not working to FM the speakers wake up and then it works fine until I turn them off again.
Reveres the poleley
if it uses led s and wires are backwords no go
Posted on Sep 26, 2009
Just purchased SBHS100AE-K rear speakers to connect to my SC-BT100. I want to connect them wired rather than purchase the wireless transmitter, but I can't figure out how to connect the wired rear speakers...
This unit is not as flexible as traditional receivers are as far as speakers are concerned. Speakers are labeled and *must* be connected to the correct speaker terminals.
Upon reading the manual - it is quite apparent that the only provisions for rear surround speaker connections is <i>only</i> via the optional wireless transmitter / receiver hardware. The optional digital transmitter is connected via a proprietary plug on the rear of the SC-BT100. The optional receiver amplifies the received signal and passes it to the connected surround speakers. I would bet that there are no provisions for amplifying a surround L and R speaker channel inside the SC-BT100, and that it only provides a low level (like a "tape out") or un-amplified signal to the transmitter plug. Even if you were to manage to get the surround speaker connections made up there - you would not be able to hear anything from them - as there is no amplifier. The amplifier is contained in the wireless receiver, and is largely why it requires a connection to house current.
Unfortunately, I doubt you'll find a way to listen the surround channel audio from the SC-BT100 without the optional transmitter / receiver and the integrated amplifier.
You can review the manual like I did here:
http://service.us.panasonic.com/OPERMANPDF/SCBT100.PDF
I hope this answered your question.
Jun 11, 2010 | Panasonic SC-BT100 Theater System
Have a Pioneer VSX-1018 receiver. When I connect
You speakers are out of phase. Check to see if the polarity is correct on the receiver and the speaker. Positive (red) with positive, negative with negative (black). Also check the impedance of the speaker, it should be located on the back of the speaker measured in ohms. Make sure that your receiver matches the impedance of your speaker. You can find this in the settings of the receiver.
Dec 08, 2009 | Pioneer VSX-1018AH-K Receiver
Wireless digital transmitter doesn't work
I'm having this same problem; it worked all ok in the beginning then one day it didn't and no matter what I try it doesn't seem to connect. Similarly im getting the W1 flashing and even when I take the receiver and move it closer (even within a few feet) it still wont pick it up. I've removed the wireless home phone and baby monitor from within the room without any result. I cannot think of anything else that could be interfering. Any advice or resolution would be much appreciated.
Oct 06, 2009 | Panasonic Audio Players & Recorders
Place for connecting transmitter ot reciever..cable plug does not fit anywhere on receiver
If you just using them for stereo, use the "main pre-out" on the receiver. if your using them for surround, they need to go the 5.1 pre-out rear. Hope this helps.
May 09, 2009 | Yamaha RX-V2600 Receiver
Wireless speakers not communicating to Receiver
Speakers have a unique RF frequency that needs to pair with the receiver (kind of like a blue tooth headset with a cell phone). At times, the signal may reset, so, you may have to go through the initial pairing sequence. Try this:
1. Unplug rear speakers
2. Make sure the sound signal connector is plugged in to the back of the system properly.
3. Press and hold the ID button for 3 seconds until the blue LED light flickers.
4. Connect the power chord to the rear speakers.
May 03, 2009 | NexxTech DP3222 DVD Player
Connecting rear Wireless Speakers on Panasonic Home Theatre Kit
Hi
Just push and hold the fast forward button on your receiver and push the button number 3 on your remote simultanously
your unit cames in pairing mode a P appear in the display
after, goes to your wireless receiver and push the reset button on the back
normally after that the unit must connect with your receiver
Dec 29, 2008 | Televison & Video
No sound from rear speakers on the lifestyle 18
The SL2 works in such a way that the speaker satellite out put from the bass modules is fed to the input of the SL2 transmitter (remember, transmitter) then the sattellitespeakers are connected at the other end of the room to the receiver. An initial blinking green light should be seen and once the system is turned on this turns into steady green. Both the SL2 transmitter and receiver operates via WIFI.
Glad to be of service...
Dec 21, 2008 | Bose Lifestyle 18 System
Scpt950k wireless speakers don't work
there may be some loose connections or connections may get lost inside the speakers or it may blown due to high voltage so check that
Jun 30, 2008 | Panasonic Home Theater System System
Acoustic Research Model AW871 wireless sterio speakers
Your connection between the AR transmitter and the ONKYO receiver sounds solid. I'd guess it's the wireless speakers that are the wrong point, or at least that's what I'd look at first. Doing a bit of research, I noticed a couple minor points. First, these seem prone to RF interference from other RF devices. Have to tried switching channels on them? Second, someone reported theirs would not work properly unless the speakers were turned on just before the transmitter, and turned off shortly after the transmitter. Apparently you have to hold the button on the front in for 5 seconds to turn the speakers on or off. I know that's rather basic, but it's been a few days and no one else has responded, so I figured we should start somewhere.
Aug 27, 2007 | Audio Players & Recorders
Bose SL2 (17817393904) Wireless Adapter Logo
1,084 people viewed this question
Top Bose Computers & Internet Experts
Ben Armstrong
Carlos L. Burgos
Carlos L. Burgos
Are you a Bose Computer and Internet Expert? Answer questions, earn points and help others
