Question about Panasonic SC-HT900 System
Color on DVD is wrong
Upon playing the DVD, the color is completely wrong. Lightning McQueen is supposed to red, not blue. How can I fix this problem before my 4 year old has a meltdown. Thanks in advance!
2 Suggested Answers
  • 38 Answers
SOURCE: on screen color
1.Check your component video connection,and see if you are any cable that is not connected properly(most commonly swamp between Pb-blue, Y-green.)
2. If the connection is correct FOR SURE,check your system menu under video connection or output and see if you have switch it to component video output.
Posted on Feb 04, 2008
  • 10594 Answers
SOURCE: can't adjust color
Its connection combination problem of " component video " You have selected/ connected wrong pins with other unit. Always insert same color pin on both unit (TV & DVD player)
Have nice day!
Posted on Jul 20, 2008
0 characters
1 Points
We've had the Sony DAV DX150 for a few years and now all of a sudden when we play a DVD the color is all messed up. It displays in mostly greens and purples. If we adjust our TV settings, by putting the...
Hello ,im curious as to whether your using component cables from the dvd to the tv (red,green,blue) if so than i suggest you check those because it sounds like your missing a color,check the red cable specifically.
Jan 18, 2011 | Sony DAV-DX150 System
No color when playing DVD's on Sony DAV-HDX500.
What's different? The video connection type, maybe? If you're using Component cables (Red, Green, Blue) you might want to check their integrity.
Jul 01, 2010 | Sony DAV-HDX500 System
I have a protron dvd pds 2315, hooked up to a Insignia LCD HDTV, the sceen is completely pink when I turn on the dvd player. I am using the 3 color coded video cable and a regular white/red cable for...
Turn on your DVD player, go to your set up button on the DVD remote, go to TV and select p-scan. It fixed my problem. My screen was all blue before I did that. Hope it works
May 07, 2010 | Protron PDS-2315 Theater System
All DVD movies are bluish. How to adjust color to be natural?
if you are using component cables, check the cables for correct color configuration to your TV and from DVD Player.Example red to red green to green and blue to blue, if they check out,the possible problem might be a defective cable...
Dec 29, 2009 | Sony Home Theater Systems
The color is off on my Bose 321 DVD player. Pictures have a red tinge, and seem to be missing the blue tones. The television displays great color except when playing DVDs.
I just had the reverse trouble, the people were all blue. What happened is that two of the composite jacks were reversed. Check to make sure a cable is not unplugged, and that they are all in their right spots.
Nov 28, 2009 | Bose (321GS) System
Check your "Setup Menu" with NO DVD in the player. Could be the wrong format, should be 720p or 1080i or 1080p. Are you using Component cables to your TV or HDMI? if Component, check your connections, it is color coded but may be hard to see with most installations. Use a flashlight to make sure colors are correct Red to Red, Blue to Blue and Green to Green. Sounds like you've got cables mixed up. It happens to the best of us! and I do it for a living! Hope this helps
May 21, 2009 | Panasonic SC-HT680 System
When I play a dvd it is in black and white how do I get it to be in color
It is very likely that your connectors and cables are causing this problem. I am guessing you have component cables and one of them is either not connected, or that the connectors are not in the proper location (green to green, red to red, blue to blue) or that the cables are of different length. Similar problems occur with S-Video with bent pins and in some cases HDMI has some issues with dirt or that the connector isn't firmly seated.
Feb 24, 2009 | Panasonic REGION FREE SCHT700 5 Disc DVD...
JVC TH-C5 DVD color when playing DVD's, but color
You might have the connections wrong. If there is component in on you tv(red,green,blue) then use the for the best picture. Other wise use the yellow composite video out to the yellow video in on your tv
Dec 12, 2008 | JVC TH-C5 System
Can't adjust color
Have nice day!
Jul 20, 2008 | Panasonic SC-HT700 System
No color
is the dvd menu in color ? if so it could be in the video process circuit if not try different video cables.
Jun 11, 2006 | Sony DAV-C450 System
Panasonic SC-HT900 System Logo
57 people viewed this question
Top Panasonic Home Theater Systems Experts
Richard Roth
Richard Roth
Are you a Panasonic Home Theater System Expert? Answer questions, earn points and help others
