My Taylor thermometer just froze on LO for the thermo temp.
I tried replacing the batteries, thinking that might help having a fresh power source, but it won't measure the temp. What's wrong with it? Can I fix it in time for Thanksgiving?The numbers on a little piece of paper on the back of it have the numbers: 1470-33; 3007; P2290 . It is encased in a cream colored casing, with grey buttons and I have had it for about 1 year. I got it last Christmas (2007) for a gift, and I just love it. I use it for everything. Is it possible that the cord to the element is damaged somehow (even tho I don't see any splits in the cord) and as I mentioned above in the summarization of problem the thermo temp area on the lower left side stays frozen in Lo screen. I tried resetting in the back, to no avail. Temp up and down still works, the timer works...just the food temp gauge is on the fritz...the part I need the most!
  • Anonymous Dec 05, 2008
    I have a similar problem, but different
    My remote thermometer froze on high
    The problem, for me, is the probe.
    I took a similiar probe from a competetor's unit and ti worked
    The temperature was exactly the smae - exactly
    Taylor said they no longer made that unit and could not provide a new probe. B S
  • ch1234 Jan 10, 2009
    I have exactly the same problem as described above with the left side frozen displaying "Lo". I have also changed the batteries to no avail.
  • 69 Answers
SOURCE: Burners shut down at set temp but fan continues lowering temp
the reason he told you not to cycle the power is because some where there is a flashing light that he can decode and tell him where to start looking for the problem. Call him next it happens and don't touch the power or the stat until he gets to see the unit.
Posted on Aug 03, 2009
SOURCE: RC1 - New batteries fitted but display still blank.
Hi,Not nessarly shot.The stat uses low voltage from the equpitmemt also.You neea a volt meter to check.Remove stat from mounting plate.Check power at terminals RH&W or at RC&G they should read 24volt.If not check emergency switch off or fuse/breaker.
Posted on Apr 15, 2010
  • 144 Answers
SOURCE: I have an old (14 years) honeywell thermostat,
I subjest the honeywell pro 3000 is a very good stat it comes in programable and non programable their is also a pro 8000 that is great its touch screen and has many options but the 3000 is most cost effective
Posted on Sep 14, 2010
  • 674 Answers
SOURCE: my toyo L-30 reads the
Lo is displayed when the room temperature is below 14F or the heater thinks the room is below 14F, which would be caused by a problem with the room temperature sensor or the sensor is unplugged. 70 is what you have the heater set to maintain. Check the white wire on back of the heater.
Posted on Dec 09, 2010
  • 88 Answers
SOURCE: Our Honeywell programmable thermostat T8132A 1049
The T8132A thermstat requires 2 AA alkaline batteries for operation as the T8131 uses the 24VAC souce transformer with battery back up. If new batteries did not fix the problem follow product user manual to reset and program the thermostat. This should clear any errors or problems. If the problem persists then replace the thermostat. If you do not feel confident you can accomplish the task then you should call a licensed HVAC technician to troubleshoot the issue as the wrong settings could potentially cause permanent damage to your system.
Posted on May 09, 2011
Keep gettinG LO thermometer when taking my son's temp. but quite Ok with others
The actual temperature may be below the calibrated range of the thermometer.
Sep 22, 2016 | Braun Irt 4520 Thermoscan Ear Thermometer
The Thermo temp flashes HHH ....and the thermometer keeps beeping...??? What do I do!?
That means the temp is higher than the unit is able to detect. If it has been exposed to very high heat then it is damaged. It may still have a bad sensor.
Jun 19, 2016 | Taylor Digital Cooking Thermometer
How do I program Taylor in/out thermometer-clock and get outside temp to register? How do I program the clock?
Hit reset next to batteries to have it sync with outside temp sensor. Push mode button to scroll thru date, time. Use up and down button on back to adjust numbers.
Mar 03, 2015 | Taylor Measuring Tools & Sensors
Constant LO reading on Taylor 9200
This might be due to calibration or the thermocouple is bad. You can get new thermocouples here
They also have contact info and calibration procedures.
Jul 04, 2014 | Home
How can i stop the taylor 1341 digital thermometer from beeping.
remove four screws on back of unit,cut red wire going to round beeping speaker inside lower front faceplate. problem solved it will never beep again but still read temp correctly.
May 19, 2014 | Taylor 1431 Digital Wireless Thermometer
Oven thermometer only displays lo
I just had that LO reading. Pulled back on the tip of the thermometer. Seems I had it inserted into my turkey too far. Probably up against a bone or too close to the center. Good luck! Happy Thanksgiving 2016!
Dec 25, 2013 | Farberware New Classic Alert Oven Probe...
The digital thermometer was flashing "lo". I assumed it needed new batteries and then replaced them. It is still flashing lo, but also showing a C reading. What do I need to do to reset it?
there should be a setting on it that changes the temp from Celsius or "c" to ferinheight and lo means that it currently isn't reading a temperature in the normal range. try running it under hot water and see if it says error or high.
Jul 15, 2011 | Prestige Medical Infrared Ear Thermometer
How do I replace the battery in my thermo scan plus ? cna't seem to figure it out Help I need it as my son is ill and the doctor keeps asking for his temp?
Simply press the small recessed button (a small triangle is pointing it ) directly above the battery door with something slender like a ballpoint pen or a toothpick, while pushing the battery door down, away from the thermometer.
Feb 07, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
Scales showing Lo after battery has been replaced
Anytime you have trouble with a Taylor scale - they have a lifetime replacement warranty. You need to call their 800 number and pay for 1 way shipping and they will send you a new one.
Jun 04, 2009 | Taylor & Digital Scale Lithium Scale
Heating & Cooling Logo
2,417 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
