Question about Pyramid PB681X Car Audio Amplifier
Pyramid PB681X I GOT THIS PYRAMID 1000W AMP AND IT WAS PLAYING FINE UNTIL I SWITCH THE KEY ON TO START UP THE CAR AND THE RED LIGHT CAME ON. THE AMP STOPPED WORKING AFTER THAT.
You didn't say how long it ran before it quite and I assume the red light you are refering to is the protection circuit engaged light and not the power on light. But from the info you did provide, I'd say that it sounds like you may have blown some of the main output transistors/MOSFET's. If so, it's time for a trip to the repair shop. Sorry, for the bad news. If just turning your car on caused the outputs to fry, then I wouldn't be surprised to find that you have either bridged the speakers wrong or by some means you have put the wrong speaker load on the outputs. Ask someone who knows what they are doing, if you have your speaker loading correct. This person might not be a car stereo installer as sometimes they don't know how to load an amp correctly, especilly when it comes to bridging. Good luck.
Posted on Dec 30, 2006
My Pyramid Arctic Amp 1000 watt was working fine for about a month then one day the protective light came on and stayed on as long as the amp had power. So now it wont give any watts to my two 12's....
Troubleshoot to the component level to find out what is causing protect mode. A short in the output stages as a result of overdriving is one likely suspect.
Jan 14, 2018 | Pyramid PB1615X Car Amp
Bought a car and this amp was in it(Pyramid Crystal PB781X 2ch MOSFET). it is missing the fuse. what fuse does it require?
25 to 30 amp fuses are the most commonly used fuses in any amp and since yours is a 1000w amp, I would use the 30a.
Sep 05, 2010 | Pyramid 2CH 1000W CRYSTAL AMP Car Audio...
Pyramid PB1500 vs. Metrik Rem. Bass knob????
Yeah it's probably not going to work because it's not even the same brand
Jan 18, 2010 | Pyramid PB1500 Car Audio Amplifier
I have a pyramid amplifier for my car and i
Professional repair is required.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 28, 2009 | Pyramid PB1281X Car Audio Amplifier
Green and red light are on my pyramid amp and its not working
It could be even simpler than that, yes an improper impedance rating on an amp will cause it to overheat, but should function temporarily until it reaches peak temp. If the outputs were blown the protect light should not light up being that they would need to work to cause the protect light to come on. I would double check all of your connections, one small little crossed wire would cause an amp to immediately go into a protect mode.
May 29, 2009 | Pyramid PB1217X Car Audio Amplifier
Pyramid PB449X In Protect Mode
The protect light is a notification that the amplifier has reached a set temperature and shuts the amp down till it cools off. Look for the thermosister on the heatsink and follow the circuitry back to the control chip. Once you get that fixed the amp should power up until it gets too hot and the protect circuit kicks in. I had one of these amps for a while and the circuit was very touchy. Regards, rcampsr
Feb 20, 2009 | Pyramid 1000W 2CH SUPER BLUE AMP Car Audio...
Pyramid ps-36kx
Generally, the fuse only blows when the rectifiers fail. In other Pyramid supplies, they use a square, 4 terminal bridge rectifier. They probably use the same thing in your supply.
Let me know if you have any other questions.
Nov 15, 2008 | Pyramid - PS21KX 20 Amp Power Supply Car...
Pyramid PB681X Car Audio Amplifier Logo
121 people viewed this question
Top Pyramid Car Audio & Video Experts
Greg Cann
Greg Cann
Steve Sweetleaf
Steve Sweetleaf
Mark Skinner
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
