Question about Video Game Consoles & Games
Computer Screen turns black, Computer still runs.
So I was playing L4D on my computer when it suddenly crashed, and then the screen turned black. So I restarted my computer, except after a few minutes the screen turned black again (I did not open up any games this time). This happened several times, I kept rebooting my computer with the power button. I researched a lot online, and I found answers like bad connections, I even replaced the power supply. I'm not sure if its my video card. I do know its not the Monitor, since I Replaced it with another one, which works fine on the other computer.
My video card is an ATI Radeon 1900x, 480w power supply.
I'm not any good with computers and this is the first post I'm making on a forum because I sincerely could not find a solution, which almost never happens.
  • brownsterz Nov 24, 2008
    Thank you for the reply teknowolf,
    I did try the safe mode procedure before, but the screen freezes and
    then blacks out before i can even get to the desktop, this time it
    froze on the start up menu, so i could not even get to safe mode. Any other thoughts you might have on this?
    Thank you again for the help
    Sergeant:
  • 207 Answers
Brownsterz,
This sounds to me like the game, caused a fault in your video driver that somehow adjusted your resolution/refresh rate to something beyond your monitors range.
If this is the case we can fix it. Restart your computer just after the logo screen push <F8> which should bring up the startup options for Windows. Select "Start in safe mode" Once up in safe mode adjust the "Display settings" to a more modest resolution either 1024 X 768 or 800 X 600 ( don't worry this is just temporary)
Then restart the system and this time it should let you get into your desktop without the "Black out".
Now go to AMD.com and go through their support page to find the latest drivers for your ATI card (AMD bought ATI a while back) download and install these drivers. then after the reboot you should be all set to change your display back to what your comfort levels are.
If this gets you back to normal, then you had a driver conflict error that corrupted your video cards driver. Try playing the game again, if you get the same symptoms AGAIN then reduce the resolution that the game runs at and/or turn down or off antialiasing / anisotropic filtering and that should reduce the odds of it reoccuring.
If this procedure doesn't help you, please comment back with your results and I will figure out what else went wrong.
Thanks Dave
Posted on Nov 24, 2008
I was just using my mom's acer aspire when suddenly a blue screen appeared that stated it was preparing for a crash dump. The computer will turn on and sound like it's starting up, but then it stops and...
from what yu say if i infer correctly then
when powered on the system powers up properly and the HDD and CPU are running fine but there is no display on the screen and is black,
first try the this step, try connecting an external monitor to the VGA port (generally in blue color) and see if you have a Display on the external monitor.
the black screen generally means that either the Display section is not getting power or the invertor board is damaged and this needs professional help in fixing / replacing it.
hope could be of help
Mar 28, 2011 | Acer Computers & Internet
If i leave computer on without anyone using it . computer goes to black/dark screen , can't perform any functions. also computer crashes at times during use.
You need to check your power settings. It is being set to go to turn of the drivers after a certain amount of time.
Control Panel\Hardware and Sound\Power Options Then change the power options so it does not shut off the hard drive.
Mar 06, 2011 | Gateway DX4300-03 Desktop PC
It went black but the power is still on
Computer Crash
One of the more complicated reasons why laptop screen goes black is a crash. This could occur for a variety of reasons and is often very difficult to fix. You will have to take the machine to a computer repair shop, and they will open up the laptop there to find the cause. Needless to say, this could set you back by a few hundred dollars as well. The crash could be caused by overheating, or maybe even a loose power supply cable. One solution for you is to play an audio file if the laptop screen goes black. If it does not play at all then something is wrong with the entire system, but if the audio file plays then it is just the laptop screen that is troubled.
Virus
There are a few computer viruses that can cause this problem, but most antivirus programs can effectively deal with such a virus. Update your antivirus software regularly and make sure you download all possible firmwares, and this sort of virus will be successfully thwarted. If your machine is infected with such a virus then your video drivers will most certainly be affected, and even your video card could get contaminated. All this results in your computer screen going black, and in some instances, your laptop screen may even go blue.
Drivers and Programs
The video drivers are crucial for making the computer monitor function properly. On some occasions though, these programs can stop functioning due to some reason. If your laptop screen goes black after startup on a consistent basis, then maybe it is your video drivers that are malfunctioning. To avoid this situation, you should constantly upgrade your video drivers, and should also refrain from using pirated video drivers. Spend those extra bucks on getting licensed drivers, and you will save a lot of unnecessary expenditure in the future. Read more on how to upgrade laptop video card.
Jan 06, 2011 | HP Pavilion F1503 15" LCD Flat Panel...
Emachine W6409 will no longer turn on
Your hard drive is probably crashing or has crashed. You need to start your computer with an XP CD and try to use the repair function. You'll be able to tell if the hard drive is still working or not once you run the repair function. Let me know what happens or if you run into any problems.
Feb 20, 2009 | E-Machines W6409 (7234) PC Desktop
My screen randomly blacks out.
the best method to overcome this problem is format the computer!!! i too used to get the same problem!!i did format it...!
Dec 30, 2008 | Microsoft Windows XP Professional
6000 crashing
sounds like your motherboard fried
Sep 06, 2008 | Dell Inspiron 6000 Notebook
Suddenly crash and cannot reboot
HI do you need my HELP please post
Sony Vaio VGN-SZ440n11-Blank Screen
You have a warranty. You should contact the appropriate people. Do not try to fix this yourself. If you return the machine for service, ask them to get any data off of it that you need. It is possible that your drive has crashed.
Dec 09, 2007 | Sony VAIO VGN-SZ440 Notebook
Video Game Consoles & Games Logo
576 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
