Monitor not working
Want to use Aux. monitor, butit keep going inot power saving mode. Syntax A530. What keys do I need to hit for Aux monitor too work. I t works on start up but then shuts off
Power Save Mode & PS3
restart the computer HOLD the keys CTRL+ f11 or f12 depend from you mark, and go to restore factory defaulty and ready.
God bless you
Jun 23, 2013 | Computers & Internet
My HP A735W is turning on but stays in power save mode and no key board or mouse function
I think the issue is your monitor. If the monitor constantly says Power Save Mode and not let anything else display then the monitor might be bad. See if we can isolate the problem by the steps below.
Try booting up in Safe Mode and see if the monitor works ok.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. If it works ok in safe mode then the monitor is ok and we might have an issue with a setting.
Try connecting another monitor to your computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor works ok, then your original monitor is bad. If the Borrowed monitor does the same thing as your original monitor then the issue is with the computer (possibly the video card).
May 20, 2012 | HP Pavilion a735w (PL308AAR) PC Desktop
How do I get the monitor off power save?
it will allow you to enter the selection screen to pick safe mode, you just need to keep hitting the F8 key repetedly as soon as you hit the power button to turn the pc on.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 13, 2010 | Gateway FPD 1510 15.1" Flat Panel LCD...
I have a dell monitor (2002) and all of a sudden when I try to turn the computer on I get blinking yellow light and (took to Best Buy and computer is fine) when I hit the buttons on monitor I get (power...
Hi Tomccaw,
In this case your monitor is working fine. Your system is going to power saving mode. To resolve that remove your RAM and insert it. It will fix your issue.
Jun 15, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
My monitors sleepy
Go to the control panel on the computer and look for power options. On the first page there is power schemes, make sure the scheme is on "Home/Office Desk", below that make sure everything is set to "Never". If you don't want the computer "Hibernating", Go to the "Hibernate" tab and uncheck the box. Hit apply and OK. No more sleepy monitor.
Sep 11, 2009 | LG L1919S LCD Monitor
Unable to get monitor out of power save mode
turn your moniter off waite 30sec back on this should get your screen on. Try this Rigth click on your desk'top >properties
>screen saver, click Power then change the turn of monitor tab
Jan 24, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
In power save mode
The monitor is not receiving signal from the computer. Is the power light on on the computer? If so - press and hold power button on computer until the power light goes off, then press again to restart. If the computer starts and you still have no picture it is most likely a video card or motherboard problem.
Nov 17, 2008 | Dell E173FP 17" LCD Monitor
Monitor shuts off during boot. Let the machine boot full up, hit the power button, the monitor flashes windows for a split second, and goes back to power saving mode
Hey there Celius,
Chances are the 'Refresh Rate' somehow got set too high for the monitor. On flatscreens , the result is a black screen.
If you have an old monitor (crt type) hook that up temporarily and reboot.
  • Right Click the Desktop
  • Click Properties
  • Click Settings
  • Click Advanced
  • Click Monitor
  • Lower the refresh rate or set at optimal
  • Check the box 'Hide refresh rates this monitor can't display'
Shutdown, Switch back monitors and try it now.
Good luck
Mike
Oct 29, 2008 | LG Computers & Internet
Monitor in Power Save Mode
The inverter power logic is probably going bad. You can get it here as well as look at instructional videos on DELL monitors.
http://www.lcdrepair.us/e176FPf-inverter-power-logic.html
May 04, 2008 | Dell E176FP 17" LCD Monitor
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
