Question about 3Com OfficeConnect ISDN Lan Modem Router
Router problem Hello bc, I have a 3com office connect wireless router. I am not using the wireless features (cat5) anyway... I am having problems with games disconnecting, virtual online software (second life). It will say I have no connection? It seems like I can play about 10 mins. the it happens (also happens in games). An online gaming host called: GameRanger says some people will not be able to connect because I am behind a NAT router. I went in the router and disabled the NAT and then nothing works, I cant connect to the internet? I am not too worried about security, I am more interested in playing games!!! :o) We have two PCs on the router a PC and a Mac Pro. Any suggestions?
  • dennyayers1 Nov 27, 2008
    Hello, Thanx for the suggestions but:
    I have my firewall disabled on my router
    And everything works fine if I bypass my router.
    Thanx for trying but:
    I have turned off the firewall for my router
    also everything works great if I bypass my router
    So it has to do with something in my router settings.
  • 57 Answers
Try to disable any firewall you have, disable windows firewall if its enable and try to lower your Internet Security or use default if set to custom.
Posted on Nov 27, 2008
I forgot my admin password for Wirelles Router 3Com "Office Connect ADSL Wireless 11g Firewall Router" what i have to do ? i don't want to reset my Wireless Router couse that make's me have to reconfigure...
if you havnt changed the password to the router then it should either be "PASSWORD" "ADMIN" "ADMINASTRATOR" in the worst case senreio you may have to reset the router.
Apr 20, 2010 | 3Com OfficeConnect Wireless Router
Need to know what i need to connect my prewired home (with cat5 cable running from box in garage to jacks in 4 rooms) to the internet. currently just have cable modem in office.
You would need a 4 - 8 port router... with a wire going to each Jack... and these would plug into the Router ports, The router plugs into the Modem. You have to put the Ethernet plugs on each end of the Cat5 cable. Then you setup your network. But if you have a wireless router you simply need each PC WiFi enabled, IE: A wireless card in each PC, that way you do NOT need Cat5. Then each PC, simply connects to the Router/Modem.
Mar 05, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I have used my 3com office connect for router with
from my own expierence ive learned that vista supports very few programs. why i dont no. ive had the same problems my husbands pc runs windows xp and the router links to his no prob. try goin on thte router site and down load a new driver from the vista pc. and try reloading if not im sorry but you will have to purchae a newer router vista compadible
Sep 13, 2009 | 3Com OfficeConnect Router
Automatic restart of the router
try checking ur modem button or reinstall windows .if problem presists then contact me at afzaalafridi@rocketmail.com
Apr 30, 2009 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Is it possible to have 2 pieces routers to expand the distribution of internet connection instead of using router to hub? what type of cabling should i used to do it? please help thanks
I guess you have a single incoming internet connection and wish it to be shared.
You only require one DSL / Cable router. To share this connectivity you will need Ethernet / Cat5 or wireless.
An ethernet switch or hub will enable you to extend connectivity.
All cable should be CAT5e or CAT6.
Suggest you consider the slightly more expensive switches that have auto-uplink. The negates the need of crossover cables.
Regards B.
Mar 21, 2009 | 3Com Computers & Internet
Router problems
Hi!
The default password is admin.
Please see this link for the default settings and password for your 3com router---
Default Password
Please rate this solution
Thanks
Rylee
Feb 14, 2009 | 3Com OfficeConnect Wireless Router
XP compatable
then you have to used the wireless g router for wireless
Dec 30, 2008 | 3Com OfficeConnect Wireless 11g 802.11g/b...
Wireless connections
Please you write more detail to problem.
Thank you.
Mar 27, 2008 | Computers & Internet
USB modem cable quandary
i am new too --may this trigger more people to help
from my limited experience
yes u need a NIC card in your pc
isp signal--->isp modem---->rj45 cable---->wireless (switch/access point/ Router--->NIC(PC)
---->wireless adapter (notebook)
----->wireless adapter(PC)
nowaday with a Gigabit Nic
u can match 802.11b 11mb/s
802.11g 54mb/s
802.11n 300mb/s
i use verizon at first with PPPoE
later Comcast cable dynamic
u need to go to web site ip address assigned by DHCPof your 3com wless router to make sure or/and clone the router so that it has same MAC addtress as your NIC of your PC before u can get CONNECTED with the Web----(u can see the green display on the upper right of the screen of the router page after u get connected) dl
Dec 25, 2007 | 3Com OfficeConnect Router
3Com OfficeConnect ISDN Lan Modem Router Logo
215 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
john smith
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
