Question about Mitsubishi VS-50501 50" Rear Projection Television
Intermintent picture TV picture will work fine then faint horizontal lines will cross screen and within a few minutes...no picture just audio. Sometimes TV works fine for a week or more and then starts misbehaving.
  • orko512 Dec 29, 2007
    How does one obtain new transistors for fixing this problem?
    Is there a schematic diagram for these models?
Thanks snakehead I'll check it out.
Posted on Jan 28, 2007
    Genius:
  • 1,074 Answers
Check the horizontal output transistor this could be damage and causing the problem.another thing is pilot light that cause the screen to light up.since this is a projection t.v.it does not garry a tube.
Posted on Jan 22, 2007
SOURCE:
TH-42PX75U horizontal lines (flickering black and white)
The controller board for the screen is going bad. check shopjimmy.com for replacement parts. It's not a difficult job to do. Once the back of the TV is removed, you'll see it near the center of the screen.
Feb 21, 2014 | Panasonic VIERA Televison & Video
Red/Orange horizontal lines
it could be that the tv convergence circuit is going bad. One shure way of finding out is to go to the tv feature menu(picture,audio etc.) and select the customer convergence setting, you should get a cross hair pattern(cross in middle of screen). that cross should be white and by aligning the red or blue colors they should move left, right, up or down
Jul 27, 2009 | Akai PT5492S 54" Rear Projection...
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
TV quits after a few minutes-get a blue screen, no picture and no audio
My best recommendation is to pull the back off it and blow the dust out. Dust is electrostatically attraced to the components inside and acts like a blanket. This causes overheating. Remember to leave your tv unplugged for at least an hour before taking the back off as the CRT (picture tube) will store a charge which can kill you.
Bill
Dec 30, 2007 | RCA T19408 19 in. TV/VCR Combo
Red screen
sounds like a picture tube problem its a problem that probably cant be fixed only by a professional
Nov 30, 2007 | Sony KP-51HW40 51" Rear Projection...
Unknown model of panasonic tv problem with picture
Depending on age, it sounds as if picture tube has an intermintent short in the red gun. tap on the center of the screen to see if it goes away, if it does,I would strongly say that the tube is gone; but you could try openning it and check if the crt board is mounted on the tube's neck properly. do this at your own risk since you might get a shock if not familiar on how to handle tv's.
Nov 20, 2007 | Televison & Video
Faint horizontal lines in picture
This is usually caused by a problem in the Horizontal Output section, around the Horizontal Output transformer usually a capacitor or diode going or gone faulty... the line you see are the Horizontal "Retrace" lines that are useually "Hidden" when the circuit is OK..
Jul 30, 2007 | JVC AV-27320 27" TV
Intermittent loss of picture
You'll have to locate the vertical output IC which should be mounted onto a heatsink, then take out a good magnifier under the printed circuit board and examine the solder connections on the pins of that IC and resolder the ones that are cracked.
Mar 12, 2007 | Proscan PS27125 27" TV
Screen white tinted, horiz lines, then shuts off
Not acutally a solution. We are having this EXACT same problem; it started this week. Let us know what you are having done. I've called Toshiba and service reps but they are all quoting a price which is almost half the value of the tv. Have you been able to fix it? We are pretty upset since the 2year warranty recently expired. Obviously, it seems that others are having this problem as well. Email us: briamanda@comcast.net
Dec 21, 2006 | Toshiba 32AF43 32" TV
Televison & Video Logo
83 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
