Question about Epson RX620 All-In-One InkJet Photo Printer
External hard drive not recognized by computer
    Genius:
  • 1,689 Answers
What is the brand and the model of your HDD? what is your computer's operating system?
Posted on Nov 24, 2008
    Sergeant:
  • 276 Answers
First check that all the cables r connected properly.is the ghard drive new and properly loaded to the pc.
  • smarttech Nov 24, 2008
    Here are a few things to try. If you have access to a secondary PC or laptop,
    try connecting your drive to it using a different USB cable. Also try unplugging
    your drive from the power outlet for a few seconds and then connecting it again------------------------------------------
    Another easy way is to see if the system is seeing a new device but may not
    be warning you
    , is to go into the My Computer (right click)> System
    Properties> Hardware (tab)> Device Manager, and see of you are showing any
    yellow question marks. These yellow marks are for unknown attached devices
    Windows does not know what it is, and can not install because it has no driver
    in it's data base to recognize it.
    If the hard drive is plugged in, do a
    re-start of the computer, navigate to the above mention Device Manager and see.
    If it still does not show any new devices. Plug and Play has been disabled. If
    not in the System Bio's, then possibly in the Administrator's System Services
    File.----------------------- the problem is being caused by the Logical Disk Manager Administrative service
    and possibly the logical Disk Manager service not being started or the services
    might be disabled. to solve the problem, click on the "Start" menu, click the
    "Run" command, and type in: services.msc , scroll down until you see both these
    services. right click on each of the services about and select properties, on
    the general tab, change the startup type to "automatic" and click the start
    button under the service status. do this for both of the services, and it will
    fix ur problem----------------------------------------------------Right click on My Computer.Choose Manage (This will open the Computer
    Management window).
    Go to the Storage category and select Disk
    Management
    Right click the new drive (usually listed as Hard Disk 1) and
    "initialize"
    You now have the option to partition and format the
    drive.
    The default settings of Primary Partition and NTFS- Quick Format are
    recommended for most users.
    Enjoy your new drive
    Genius:
  • 1,550 Answers
What is the brand of external hard drive .
Are there any light flashing on the drive .
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
How to recove Seagate external hard drive data?
Probably, the new operating system cannot recognize your Seagate external hard drive. You can connect the Seagate external hard drive to another computer to copy data to another device. If the problem still exists, you might need to perform data recovery. You can free download the data recovery software: http://www.icare-recovery.com/seagate-recovery/seagate-external-cannot-be-recognized.html
May 14, 2014 | Seagate FreeAgent Pro 500GB External USB...
My hard drive is not being recognize
A Hitachi USB external hard drive is a device that acts as portable, removable storage for your personal computer. If you need additional space to house files on your computer but don't want to go to the trouble of installing an internal drive inside the case, a USB external hard drive is your best option. These drives are "plug and play" devices, which means that very little can actually go wrong. If you're having problems, fixing them shouldn't take more than a minute or two.
Check your connections. A USB cable needs to be connecting your Hitachi external hard drive to your computer. Your external hard drive's power cable also needs to be plugged into a functional wall outlet, surge protector, extension cord or power strip. Make sure your Hitachi USB external hard drive is turned to "On." An "On/Off" button is present on the front of the unit. If the indicator light around said button is not illuminated, the drive is "Off" and your computer won't be able to recognize it. Press it to turn it on and then try to access your drive again. Format your hard drive. If your Hitachi USB external hard drive doesn't currently have a file system on it, you won't be able to use it to store data. Open up the "Computer" icon in the "Start" menu. Right-click on your USB external hard drive's icon and click "Format." Click "Start." This will install a file system on your Hitachi USB external hard drive. After this process is finished, you will now be able to use your drive. Restart your computer. Certain models of computers (especially older models) won't recognize new hardware unless your computer boots with the hardware already connected. Leave your USB drive plugged in and restart your computer. Once you do this, your Hitachi USB external hard drive should appear as normal in the "Computer" folder with all of your other drives. Hope this helps.
Jan 06, 2013 | Computers & Internet
My computer will not recognize the external harddrive so I can't access it
Connect it to a different computer. If it is not recognized, then it has a problem.
If it is recognized, then your computer has a problem recognizing it.
Apr 10, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
External hard drive is not detected
Check Following Instructions:
1. Check your USB cable properly connected to the computer.
2. Go to My computer - right click on property - Hardware - Devices Manager - in below - USB Mass storage device - right click on this - and Uninstall - then again right click - click on Scan - it should be reload your USB drivers
your External Hard Drive will be detected
Apr 25, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
My computer no longer recognized my hard drive
did your computer device manager recognized your external drive? did disk management recognized you external drive? let me know.
Apr 05, 2010 | LaCie (300770) 250 GB Hard Drive
The computer stopped recognizing the external drive
please check if it is a new external drive.
If it is new external drive, please format.
Note: all of the data would be lost on it.
How to format a newly brough hard drive:
http://www.xpmaximized.com/archives/xp-usb-hard-drive-format-.html
Dec 05, 2009 | Dell Computers & Internet
My compure wont recognize my external hard drive.
check if your external hdd connect to the pc.. cables is important..
Aug 24, 2009 | Computers & Internet
Computer does not recognize new 1TB ext HD
First I had to reseat one of the drives which had worked loose and become unseated during shipping. Then I had to format the hard drive and finally I had a 1TB external hard drive I could use. The light is still red.
Jul 31, 2008 | Cavalry Storage Cavalry CADB001U32 1TB...
Epson RX620 All-In-One InkJet Photo Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
