Question about Kenmore 15864/15862 Top Load Washer
Kenmore Washer 70 Series - sheets stuck around agitator
Today when doing laundry, bed sheets got stuck around the agitator. When we came back some time later we can smell a burning plastic smell. Sheets were entangled around agitator with tub full of soapy water. I managed to get get the sheets out, but now the washer won't advance to a spin cycle to drain the tub. Is there an internal fuse that is blown? Not sure if its worth fixing or just to buy a new more efficient model.
  • christoph505 Nov 26, 2008
    Thanks. For some strange reason after I cycled the circuit breaker, the washer started working. Your suggestion was going to be my next attempt after I manually drained the water from the tub.
    Chris
    New Friend:
  • 128 Answers
The transmission probably stripped the worm gear that drives the drum - you would have to crack it open and take a peek.
Posted on Nov 24, 2008
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
Series 70 washer make a clicking sound when
could be your motor coupling, something stuck between the agitator and drum, tranny
Feb 14, 2010 | Kenmore Washing Machines
70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 27, 2009 | Kenmore 22422 Top Load Washer
Laundry is trapped under the base of the agitator.
Im not very familiar with that type of top loadign washer,,, but on most agitators there is a bolt that runs down the center of the agitator, connecting it to the transmission/gearbox. Usually there is a cap, or softner dispenser that can be pulled off, revealing this bolt.
Mar 13, 2009 | Washing Machines
Washer keeps filling with water...
you hae a stuck float switch, it shuts water off when it reaches a certain height, fixing it involes removing the top of the washer (not easily done)
Jan 11, 2009 | Kenmore 22422 Top Load Washer
Sheet stuck under washer agitator.
remove agitator top remove 7/16 bolt to remove agitator. tub mounting hub may be worn which allows the tub to drop down. the hub is located on the center post below the agitator.
Dec 20, 2008 | Kenmore 23822 Top Load Washer
Agitator in kenmore elite oasis
Use the bulky bedding cycle for oversize loads.
Oct 05, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 70 series washer
the agitator dogs are problably remove agitator cap remove bolt holding agitator in ..dogs are part #80040
Jul 19, 2008 | Kenmore 22422 Top Load Washer
Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Apr 26, 2007 | Kenmore 22422 Top Load Washer
Kenmore 15864/15862 Top Load Washer Logo
202 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
