Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80 series won't run after filling up
The washing machine fills up and then just sits there. We have just reinstalled the washer after moving. We ran it thru a test cycle and it worked fine. After attempting to do a load of laundry, it just fills and sits there. Any ideas?
  • mason9017 Nov 28, 2008
    I replaced the lid switch with no problem but it's still not doing anything
  • Anonymous Nov 29, 2008
    Yes, exactly same problem.
  • 5,911 Answers
The symptoms you describe are typical of a lid switch problem. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike.
If the lid switch is broken, you can find a replacement at searspartsdirect.com. If the model number you have this listed under is correct, just type it in the search menu at the Sears website. Type the COMPLETE model number from the washer nameplate (located around the wash tub opening under the lid). You can find the switch under the "Top and Cabinet" heading as item number 11. The lid strike should be listed under the same heading as item number 20. If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
I hope you find this information helpful. If you require additional assistance, please let me know.
NOTE: You can also check repairclinic.com or pcappliancerepair.com for parts as they also offer competitive pricing.
PS You DO NOT have to drain the washer to complete this repair. Once the lid switch is replaced, the washer should drain on its own.
Posted on Nov 24, 2008
This is very useful. However i tried and its hard to open the console to reach the lid switch. since its the lid switch, I took it out to examine its wiring. I also searched the web, its $30+ buck for the switch. its pretty expensive.
For my case, I found the rubber sealant is bad, causing the switch to be loose. So with a super glue and a screw driver, I got my washer back, its up and running now.
This is what i did.
1) Unplug the plug, just in case.
2) The lid switch is located on the right under the cabinet.
3) there's 2 screws, unscrew it and the lid switch will go loose.
4) slowly pull it out. be careful not to damage the wiring. If damaged, you will have to remove the console everything to replace it.
5) Glue around the lid switch to tighten it. Try to press the switch, you suppose to hear a click when you press it down, thats where the switch is connected. You could open it up to see how it works too.
6) Put the switch back, put the screws in, and turn on the power. Check it out.
If you want, you can hold it tight with your hand first, plug the power back, press the switch to see if its working, to make sure thats the case.
Hope this is helpful to all and save some money.
Posted on Mar 23, 2009
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Kenmore series 80 model 110 wont stop filling!
There is a clear plastic hose that runs from the load selection switch to the side of the washer drum. This hose connects the fill sensor to the load switch. without it being in good condition and connected properly the washer won,t get a signal that it's full.
May 09, 2013 | Kenmore Washing Machines
Kenmore washer 80 series stopped draining
So it will agitate and fill but the motor won't run during drain and spin?
If so, the likely cause is a bad lid switch. The paddle that the probe hits when the lid is down moves a small switch. That switch can do two things
1. fail internally. It will look fine outside but it won't close the circuit
2. the screw holes snap and it hangs off the wires, the probe no longer hits the paddle and the switch stays open.
The lid switch is cheap and very easy to repair.
Nov 10, 2011 | Kenmore Washing Machines
Kenmore 80 series washer will not fill. replaced
You will have to have an electrical test done. If it's not filling, that means there's no current getting to the fill valve. Have a qualified technician do an electrical test. But also, have him test the timer, too!
Dec 15, 2009 | Kenmore Washing Machines
Washer fills but does not agitate or drain
Do you hear the motor running but no agitator movement ? If so , then you have a bad motor/trans coupling .
Jul 18, 2009 | Kenmore 22422 Top Load Washer
I have a series 80 top loader. It filled and
Screws holding the lid switch was broken. Had to replace lid switch.
Jun 11, 2009 | Kenmore 24902 Top Load Washer
Kenmore Series 80 Washer Won't Spin
Your timer has failed to initiate a pause for the transmission to lock in.
Replace your timer. Solve your problem.
Feb 21, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 Series will not fill up with water
if your washer will agitate when set to fill but not fill, then your pressure switch is bad.
also you may want to check and see if you are getting both hot and cold to your washer.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
232 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
